<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[WTB E36 axles]]></title><description><![CDATA[<p dir="auto">Mine are shot. E36 M3 axles would be preferred!</p>
<p dir="auto"><img src="https://static.carthrottle.com/workspace/uploads/comments/165a66ef36d8d98a0f8c614c2f8a7877.JPG" alt="Image result for camber e36 bmw" class=" img-fluid img-markdown" /></p>
]]></description><link>https://wibimmers.com/topic/5468/wtb-e36-axles</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 04:06:23 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/5468.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Nov 2018 23:16:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to WTB E36 axles on Thu, 15 Nov 2018 22:18:18 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95925">SamHolzmann said:</a></strong></p>
<p dir="auto">I have m axles and trailing arms. Shoot me a fb message if you still need some</p>
<p dir="auto">TJ has the goods, but if that doesnt work out, I will shoot you a message Sam!</p>
]]></description><link>https://wibimmers.com/post/95928</link><guid isPermaLink="true">https://wibimmers.com/post/95928</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Thu, 15 Nov 2018 22:18:18 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Thu, 15 Nov 2018 20:39:43 GMT]]></title><description><![CDATA[<p dir="auto">I have m axles and trailing arms. Shoot me a fb message if you still need some</p>
]]></description><link>https://wibimmers.com/post/95925</link><guid isPermaLink="true">https://wibimmers.com/post/95925</guid><dc:creator><![CDATA[SamHolzmann]]></dc:creator><pubDate>Thu, 15 Nov 2018 20:39:43 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Thu, 15 Nov 2018 14:51:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95871">wasnt m3 said:</a></strong></p>
<p dir="auto">I have an entire m3 rear subframe, brakes, etc to go with the axles that I have.</p>
<p dir="auto">Good deal. I will PM you.</p>
]]></description><link>https://wibimmers.com/post/95884</link><guid isPermaLink="true">https://wibimmers.com/post/95884</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Thu, 15 Nov 2018 14:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Thu, 15 Nov 2018 02:54:56 GMT]]></title><description><![CDATA[<p dir="auto">I have an entire m3 rear subframe, brakes, etc to go with the axles that I have.</p>
]]></description><link>https://wibimmers.com/post/95871</link><guid isPermaLink="true">https://wibimmers.com/post/95871</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Thu, 15 Nov 2018 02:54:56 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Wed, 14 Nov 2018 20:15:49 GMT]]></title><description><![CDATA[<p dir="auto">Yes that is a non M axle.</p>
]]></description><link>https://wibimmers.com/post/95862</link><guid isPermaLink="true">https://wibimmers.com/post/95862</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 14 Nov 2018 20:15:49 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Wed, 14 Nov 2018 19:57:30 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95856">jc43089 said:</a></strong></p>
<p dir="auto">The M axles have a thicker shaft, it is quite obvious just looking under the car if you know what to look for.  The non M axles are straight and about 1" diameter.  The M axles get thicker right after the boots on both ends and are more like 1.25" diameter.  The hub difference is because the splines into the hub are larger or more of them on the M axles.  I THINK the bearings are the same.</p>
<p dir="auto">Im guessing I need non-M/// Axles judging by this picture?</p>
<p dir="auto"><a href="/assets/uploads/files/monthly_2018_11_IMG_6411.JPG.655aa8256ca5b5b9564d87d8efbbde0c.JPG"><img src="/assets/uploads/files/monthly_2018_11_IMG_6411.thumb.JPG.63a3198da0070f8b3838065d236ea3c1.JPG" alt="IMG6411.JPG" class=" img-fluid img-markdown" width="1000" height="750" /></a></p>
]]></description><link>https://wibimmers.com/post/95861</link><guid isPermaLink="true">https://wibimmers.com/post/95861</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Wed, 14 Nov 2018 19:57:30 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Wed, 14 Nov 2018 17:53:48 GMT]]></title><description><![CDATA[<p dir="auto">The M axles have a thicker shaft, it is quite obvious just looking under the car if you know what to look for.  The non M axles are straight and about 1" diameter.  The M axles get thicker right after the boots on both ends and are more like 1.25" diameter.  The hub difference is because the splines into the hub are larger or more of them on the M axles.  I THINK the bearings are the same.</p>
]]></description><link>https://wibimmers.com/post/95856</link><guid isPermaLink="true">https://wibimmers.com/post/95856</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 14 Nov 2018 17:53:48 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Wed, 14 Nov 2018 14:20:26 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95842">jc43089 said:</a></strong></p>
<p dir="auto">M axles need M wheel hubs, you probably know that though.</p>
<p dir="auto">Honestly I didn't know that. Here's the other problem, I have no idea whats in/on the car because its a bastard of parts. Any obvious clues to know the difference?</p>
<p dir="auto">All I found online is this: 328 takes a 30mm nut and the M takes a 36mm nut</p>
]]></description><link>https://wibimmers.com/post/95845</link><guid isPermaLink="true">https://wibimmers.com/post/95845</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Wed, 14 Nov 2018 14:20:26 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Wed, 14 Nov 2018 13:40:01 GMT]]></title><description><![CDATA[<p dir="auto">M axles need M wheel hubs, you probably know that though.</p>
]]></description><link>https://wibimmers.com/post/95842</link><guid isPermaLink="true">https://wibimmers.com/post/95842</guid><dc:creator><![CDATA[jc43089]]></dc:creator><pubDate>Wed, 14 Nov 2018 13:40:01 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Wed, 14 Nov 2018 05:22:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95828">Jdesign said:</a></strong></p>
<p dir="auto">Whats your price?</p>
<p dir="auto">Just message me, we can figure something out.</p>
]]></description><link>https://wibimmers.com/post/95840</link><guid isPermaLink="true">https://wibimmers.com/post/95840</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Wed, 14 Nov 2018 05:22:07 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Tue, 13 Nov 2018 14:58:02 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong><a href="/post/95818">wasnt m3 said:</a></strong></p>
<p dir="auto">I've got a pair.</p>
]]></description><link>https://wibimmers.com/post/95828</link><guid isPermaLink="true">https://wibimmers.com/post/95828</guid><dc:creator><![CDATA[Jdesign]]></dc:creator><pubDate>Tue, 13 Nov 2018 14:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to WTB E36 axles on Tue, 13 Nov 2018 01:02:59 GMT]]></title><description><![CDATA[<p dir="auto">I've got a pair.</p>
]]></description><link>https://wibimmers.com/post/95818</link><guid isPermaLink="true">https://wibimmers.com/post/95818</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Tue, 13 Nov 2018 01:02:59 GMT</pubDate></item></channel></rss>
