  3. New Member Introduction
  4. From Green Bay!
From Green Bay!
21 Posts 14 Posters 404 Views 1 Watching
  • mkoeppM
    mkoeppM
    mkoepp
    Welcome aboard. Looks much better than when you first purchased. Keep up the good work.
      Welcome! John's build thread will probably be a good resource for you http://www.wibimmers.com/board/index.php?/topic/2092-savin-big-money-project-thread/
        Welcome, This looks like a fun car.  I haven't done much with my lawn ornament lately.  I have taken tons of pics as I disassemble so I will be able to get everything back correctly.  What is your time frame on restoration?  I would recommend some engine maintenance in the meantime, unless you know what has been done, the cooling system is a good place to start.  Poor maintenance leads to a big paperweight.
          Or too much.....
          .....earl
          • C
            C
            CHRIS
            I don't really have a timeframe, it's my only car, so i'm going to try to fix it up as I go. Your build on the Arctic Grey is looking pretty sick! So far the car has the Zionsville radiator, all new coolant hoses, new expansion tank, new fuel filter, new ignition coil boots, and newer rear control arm bushings. Oil, filter and spark plugs changed every 3k, just put in some 15w50. Also just replaced transmission fluid with some Royal Purple Syncromax.That's about it for maintenance. I'm hoping to do the valve cover gasket and brakes this weekend. Both post-cat o2 sensors are throwing codes, so probably those soon along with new front lower control arm's because the right side balljoint is bad.
              Sounds like your cooling system and other maintenance is good to go then.  Check carefully for vacuum leaks, the o2 sensors may be bad, but codes may be caused by the ecu encountering unexpected conditions.
              Also I like the wheels, and there is no such thing as too many pictures.
                Good work so far - looking forward to seeing what you do with it!
                • T
                  T
                  thechickencow
                  Welcome, I'll keep an eye out for you around here.
                  • ChrisOC
                    ChrisOC
                    ChrisO
                    Hey it's 17 year old me.
                    I couldn't have been more lucky to have a M3 at 16 years old, weird to think I took it to high school everyday for 3 years, moved out and went to college with it and took it everywhere. Enjoyed every mile of the 30,000 I put on it.
                    I should be studying for finance but instead I'm in my feels 😞👌
                    Day 1, March 2013, the car looked like an abomination. I remember wanting to return the car to oem, and scrubbing the turn signals with acetone that night to de-tint them.
                    2014
                    early 2015 ft. @Rekpoint current wheels
                    fall 2016
                    Fall 2017
                    Spring 2018
                    Summer 2018 ft. @SteelBlue
                    Fall 2018
                    Summer 2019 coming out hot
                    RIP
                      The rise and fall. The heart still lives on though.
                        :c Good looking wheels though. 😁
                        You forgot the step where they added the dirt..
