Joined the Club Today
Sounds more like you guys had a plan all along....
lol, in our defense they were locked away in my trunk for 6 months and totally forgotten about
i was really hoping the pic after the magician was going to have poorly photoshopped bunny, and no engine still.
also, i spy a mini keg
And for my next act ; "____________________" - @GunMetalGrey
Yeah that's my spare bolt bin, maybe someday it will become something cool!
Did you ever get the condor mounts to sit flat or did you just crank down on them?
I used a different set of condor ones that I had laying around.
I think there was issues with header clearance that may not have been noticed before, as the headers are up against the body. This would certainly cause some issues with motor mounts not wanting to sit quite right.
Do a burnout.
Gimme a few days
Gimme a few days hours
Fixed that for you. Better hurry up.
Anyone ever have a CSB break a 3 jaw puller and make a 12ton HF press start leaking fluid past its seals? (Cylinder was leaking before as well in all fairness). It resulted in quite a lot of deflection of the press.
Debating between taking it to a machine type shop and seeing if they can pop it off, or getting out the grinder and making a mess of it. -
Debating between taking it to a machine type shop and seeing if they can pop it off, or getting out the grinder and making a mess of it.Is the whole bearing still there, or just the inner race? Not that it matters much. I would just carefully cut it off. If you're patient, you can cut almost through the race and use a screwdriver or chisel to crack through the little bit of metal that's left and get it off without even a nick in the driveshaft.
Whole bearing is intact yet.
Only trick to cutting it is that one side sits against a flat face, and trying not to cut that face is going to be tricky as it sits fully against the yoke face.
May try a shop with a press, and if the bearing breaks it will get the inner race cut.
You can get tight to the sholder if you cut a spiral. Or just take it to a shop and let them eff it up so you don't have to
maybe stating the obvious here, but have you tried heat? i'd get that bearing red hot
the 3 CSBs (e34 and e30) i've pulled in the last few years came off with a 3-jaw/impact gun
second idea = load up a 3 jaw puller to near the braking point then rap the bearing with as much force as you can to see if the strike pops it loose. autozone/advance auto have some pretty hefty 3-jaws you can rent.
hell just put the bearing against a steel vise or concrete and hit it to try and 'oval' it a bit. i can't see it hurting the steel spindle.
Used the torch, stronger 3 jaw, and a 3lb sledge with a piece of bar to slam the thing off.
It was quite stuck!
