Non-BMW Stuff on a BMW Forum
    So I started it up tonight after putting in the new oil; Liqui Moly 10w40 with the friction additive. Anyway, noise was still there when I started it up. See the video:
    After a few minutes it was gone and sounds like this:
    I did a valve adjustment when I put it back together. Thoughts??? Opinions?
    Going to start it in the morning to see if it sounds any better.
      Not here to argue anything, but to simply point out that this logic isn't exactly sound.
      This would be the case if you were to have the whole surface of the bearing being an oil passage, but it is instead adding oil into the bearing area to provide a fluid film.
      It's not uncommon to see 6-8psi oil pressure at idle, and if you were to be worried about the direct force acting on it you would never see oil going into the bearing.
      But I agree, 20w50 is far too thick for that motor, only M30's seem to need that kind of honey in the summer.
      You could add some zinc additive to the oil if desired, I know @snap should have some suggestions in that department.
      I was illustrating that the logic of oil pressure being what prevents metal contact is ridiculous.  Maybe that wasn't clear.
        I'm not an engine guy so others with more experience will weigh in but what method did you use to adjust your valves, and what settings did you use? The m20 even when healthy will sound a bit like a sewing machine but your does not sound right.
        https://www.r3vlimited.com/board/showthread.php?t=277021
          Using a .010 feeler gauge in between the eccentric and the valve. I guess with the engine cold I can double check them. When its warm it sounds good. Just the first couple mins of that cold start.
          I think I'll readjust the valves to the slightly tighter clearance that that post says and go from there.
            If it turns out to be not valves/rockers, then maybe it's an oil pressure on startup issue? Some oil filters have drain back issues, stock Mann/Mahle are better choices. What happens with your oil pressure light on startup? Granted the light doesn't tell you much compared to an actual gauge but if it is staying on for a bit that could be an indicator. It should go off a second or two after startup.
              I had a Mann filter in at first and this one now is a Bosche. So I don't think it's a filter.
              Oil pressure was my thought and why I went to the thinner oil. My only hope is that there was still some thick stuff left and now that the new oil has made it's way around the block, that it will start up and sound great this morning.
              I haven't looked for the oil pressure light, but I didnt see any dash lights on.
                gilber33 said:
                Back on the ground! Hopefully for a while this time. One of the tie rod securing nuts was frozen, so it got new tie rods. Oil is drained out and new stuff goes in tomorrow. Fixed the hood ground strap. Getting the lights finished. Pretty excited.
                Now my standard question. How would I go about aligning this bumper?
                I LOVE how this car looks. What are the wheels?
                  They're RS reps made by ESM. They make a lot of bbs reps and they're pretty cheap/affordable.
                    The oil pressure light should come on when you turn the key to run before starting the engine.  If the switch is failed open or the bulb is burned out it will never come on.
                      I'll double check that it comes on.
                      Otherwise any other ideas about the noise?
                        Are you sure it isn't an exhaust leak?  It might be sealing up after it gets warm?  I have heard an exhaust leak sound by the manifold sound like that.
                          Definitely louder on the exhaust side. Easy thing to check as well.
                            After running it a while you might see a sooty looking spot where the leak is.
                              All the exhaust manifold bolts had maybe half a turn on them to be tight and a couple had more. The down pipes also had some 1/4 to half turns. The sound was significantly less and went away quicker.
                              Now, if it was an exhaust leak or the new oil getting everywhere, idk. But it was much improved. Finally had it out of the garage and washed down some of the dirty engine bay.
                              And as usual, question time. I put in an e36 rack, new lines, and rebuilt the PS pump, but when I'm parked, it feels like I have zero power steering. As soon as I start moving it feels normal. Is this a normal e30 behavior or is there something wrong?
                                Glad to see it out. Sorry , no help on PS. I've removed it on both of mine.
                                  I thought that sounded like exhaust leakage, strange how it can sound like a knock or tick.
                                  For the power steering, how old is the pump?  I need to rebuild mine because it is similar, just weak and once you are moving it doesn't need as much help.  Mine makes a whining noise.  I am going to get the rebuild kit and take it apart in class the week I teach my fluid power class about hydraulic pumps.  Mine comes and goes too, sometimes it works pretty well and sometimes not hardly any assist.  I wonder if the relief valve is sticking open sometimes.
                                    I actually rebuilt it while it was. Talking to others, it sounds like the system just needs to be bled. I had it completely apart.
                                      Ahh, yea several lock to lock turns should work the air out of the system.  The reservoir might need to be topped off a couple times.
                                        Well, after lots of lock to lock turns it seems like nothing really happened. Fluid level didn't go down. I confirmed there was fluid going to the pump and after the pump. There were noticeable are bubbles coming out of the reservoir.
                                        One thing that seemed weird is the fluid didn't get warm. I understand there wasn't any force to turning the wheels, but I would assume it'd get a little warm going through the pump.
                                        I guess I'll drive it and see if anything happens. No leaks at the pump or anything.
                                          If there is a leak on the suction side of the pump it will suck in air.  That would be the large hose to the bottom of the reservoir from the pump.
