Non-BMW Stuff on a BMW Forum
    I would verify that the cable in question is indeed a ground, because it looks all too much like the positive battery cable for a starter. It has the same style blade and all.
    I know that they are classically on the chassis harness, but it just strikes me as odd.
      I think you're right. Damn. I vividly remember only bolting on one large red cable on the post (in addition to the two smaller cables on their individual posts). All the images I can find of the starter on the e30 shows two large cables on the same post; one being a large black cable. That red cable must be going to the alternator.
      That would have been a really frustrating thing to diagnose. Good catch!
        Yea I would assume its a the starter cable. I just assume that since you said ground that it was one. 😉
          I assumed it was a ground. On my past Volvos all the power leads were always red and grounds were black or blue.
            Put in the new swaybar last night. Godspeed off of Ebay for $90 shipped with Installation hardware.
            Old one was done I would say. Also, safe bet that's where most of the front end clunks were coming from.
              Anyone know what this plug is for behind the glove box by the ECU? Putting the interior back together and I don't see where this one should plug in.
              Getting really close to starting this. Transmission is filled with fresh MTL, clutch is bled, engine has oil. The setback came when I filled it up with coolant and the thermostat cover was seeping. The part that sucked was the radiator was so full of crud on the bottom the drain valve didn't even work so I had to drain it by just removing the thermostat cover. Then I pulled the radiator and flushed it. Tons of gross stuff in there. That's back in. Tonight or tomorrow I'll fill it back up and then try starting it. The battery is charging now.
                I believe that is an extra maybe for autos? The car will run without it
                  Works for me! Thank you
                    Okay, so it started up. Took some troubleshooting because I reversed the feed and return fuel lines. It sounded kinda gross at first but once it built oil pressure it sounded really good.
                    Two things I am noticing right now.
                    1. When I blip the throttle it kind of stumbles when the RPMs come back down.
                    2. The temp gauge was creeping past the middle mark on the gauge after about 10 mins of idling on jack stands. It does not have an electric fan, but hasn't had one in who knows how long and it was fine. My thought is maybe the coolant system needs to be bled since it was COMPLETELY drained.
                    Edit: Going to try adjusting the throttle body some to address the stumble.
                      I’ve had issues with the same stumbling, although it was accompanied by a somewhat poor idle. Check for vacuum leaks and make sure the  throttle position sensor is adjusted correctly and work from there. What do you mean by adjusting the throttle body? I wouldn’t touch the adjustment screw, just make sure the cable isn’t sitting too tight so that it holds the throttle open slightly. That’ll screw with the TPS reading.
                      For cooling, I would definitely bleed it and then see what happens. If it was totally empty, there’s probably a good bit of air in there still.
                        I meant adjust the cable and TPS if I need to.
                        And I did a lot more reading on bleeding the cooling system. I'm pretty sure that's what I need to do.
                          Getting the interior cleaned up a little bit. Shampooed the carpets and have some new floor mats coming in addition to a factory parking brake handle to get rid of the M handle thingy.
                            Got the coolant system bled tonight. Some hot heat in the car. Also replaced the ebrake handle and new floor mats.
                            One question I do have: each cold start up the engine was relatively loud, after a couple minutes it quieted down and sounded great. So I guess I'm wondering what you guys run for oil when its cooler out like this? I have Castrol 20w50 in it now per some other forums. But I did read that when it gets to these temps a 10 or 15w40 is recommended. I think I'm going to change the oil to a slightly thinner one and see if that helps.
                              Way too thick, the incorrect general internet advice is to run mega thick oil.  However the thicker the oil it may show high oil pressures on a gauge which people think is good but the oil pressure is not what keeps metal contact from happening.  Think about it this way, there is roughly one square inch of bearing area that a connecting rod journal forces down on.  If 60PSI is your maximum oil pressure, that is roughly what the pressure relief valve vents at, then it would only resist 60 pounds of force when combustion happens.  If you only have 60 pounds of force you aren't going anywhere.  Just from compression pressure say 150PSI x the area of the piston (3.5/2)2 x 3.14 = 9.6 square inches.  You end up with a force down of 9.6*150= 1440 pounds, and that is before combustion starts.
                              The bearings in an engine work on the principle of hydrodynamic lubrication.  Which requires oil FLOW not PRESSURE.  https://en.wikipedia.org/wiki/Fluid_bearing
                              TLDR: The ideal oil weight is thick enough to maintain oil pressure above minimum spec when the engine is idling and fully hot.  Usually a quality 5w30 is not a problem unless the engine is very worn.  I use 5w30 in my M50 that has almost 300k miles and I don't ever have a flicker on the oil pressure gauge.  Thick fluid is hard to pump and will not circulate as well causing a lack of lubrication, even worse when the weather is getting cool.
                              My recommendation is 5w30, use a 10w40 if you are paranoid and don't trust modern synthetic oil.  But never 20w50 no matter how much the internets say to, the noise you hear is a lack of lubrication.
                              And FYI oil pressure spec at idle is only around 7 PSI.
                                Thanks for the input. Then I am going to pick up some 10w40 Castrol GTX to put in there.
                                I also read a lot about people using additives as well. Any need to use something if I'm running 10w40 GTX?
                                  Not here to argue anything, but to simply point out that this logic isn't exactly sound.
                                  This would be the case if you were to have the whole surface of the bearing being an oil passage, but it is instead adding oil into the bearing area to provide a fluid film.
                                  It's not uncommon to see 6-8psi oil pressure at idle, and if you were to be worried about the direct force acting on it you would never see oil going into the bearing.
                                  But I agree, 20w50 is far too thick for that motor, only M30's seem to need that kind of honey in the summer.
                                  You could add some zinc additive to the oil if desired, I know @snap should have some suggestions in that department.
                                    Then I will definitely change the oil to something thinner.
                                    I hate talking about oils because everyone has their own opinion and what they use. But, having not owned a car like this before, I want to make sure I'm using the right stuff.
                                      All oils are categorized by API standards, and that's the easiest way to determine what oil is "best" or equivalent to OE standards.
                                      At this point in time I would be willing to bet that all oils that you can buy off the shelf are better or equivalent to what was available at the time when these motors were designed.
                                        You're probably right. Which is why part of me says I'm entirely overthinking this and go to Walmart and just get some gtx 10w40 and you'll be fine.
                                          People that post on www.bobistheoilguy.com are insane and will fight to the death about how Castrol doesnt have enough ZDDP for their 1998 Duratec V6, meanwhile an Amsoil dealer lies in wait to go in for a sale.
                                          Stick to the owners manual unless extreme circumstances dictate otherwise (racing/heavy modifications).
                                          This was the only photo I could find from the E30 owners manual and its hard to read, but 20w-50 is good for all but our coldest months and 15w-40 is  good for all but maybe an extremely hot summer day sitting in stop and go traffic. Pick a good 40/50 weight oil.   Just dont get down into the 30 weight oils
                                          images?q=tbn:ANd9GcRiXZr4uNMUhVPOo1OmGbAYqvLFpI4GCxlkxye9OXTyKdQdVimA
