  4. My latest project
My latest project
18 Posts 10 Posters 164 Views 1 Watching
  • ChrisOC
    ChrisOC
    ChrisO
    Man I really wanted a red one, looks great
    • MPW3RLeeM
      MPW3RLeeM
      MPW3RLee
      Christmas came early 👌🏻
        cool car, cool project!
        btw, those are definitely knock-off wheels. no factory style 5 has stepped lips.
        • MPW3RLeeM
          MPW3RLeeM
          MPW3RLee
          Well, finally made some progress! Been a busy summer but we’re moving along.
          • i_love_carsI
            i_love_carsI
            i_love_cars
            best color is best.
            Looks like a solid project on what appears to be a pretty clean car
            2007 Z4MR
            2003 E39 M5
            2002 E46 M3
            2021 X5 40i
            • MPW3RLeeM
              MPW3RLeeM
              MPW3RLee
              With the help of my wife, finally got the engine on the stand and ready for tear down.
              Any advice on whether or not I should have the head/block machined? Taking the head off to replace head gasket and upgrade valve springs/cams and fix front timing cover. Wasn’t having any sort of head gasket issues so I was debating if I could get by without?
                I'd say if you didn't have problems then don't do it.
                  I also agree with that. If there are no issues I would leave it alone. Inspect it really well and then make the judgment call.
                  • MPW3RLeeM
                    MPW3RLeeM
                    MPW3RLee
                    Well, ran into a bit of a snag. Probably going to start poking around for new head. Need new cam caps/ledges and a few other parts of the head aren’t looking to healthy. At least I’ve got some new cams already 😂
                    On that note, anyone have any M50 or S50 heads laying around?
                      RIP
                        Yikes, thats not good... Did it have oil pressure issues or shavings in the oil?
                          I've got a head floating around, I believe it's got one bent valve.
                          NV head so the valve stems are different dia, I've also got a tray and caps with cams and lifters for an m52 I believe if you need that
                          That think looks messy
                          • MPW3RLeeM
                            MPW3RLeeM
                            MPW3RLee
                            The oil pressure was ok minus the supply to the back 2 caps, both the bearing caps had the nuts that hold the caps on loose. I haven’t found any metal shavings anywhere except around the caps, but I haven’t pulled the pan yet either. The filter didn’t have anything weird in it so maybe it didn’t spread too far.
                            Thanks Ben I will definitely let you know if I need any parts! I found a M50 head from a fellow autoXer that looks like it is in pretty good shape so I will see where that gets me...
                              Ouch.
