Non-BMW Stuff on a BMW Forum
Congrats!
Nice progress! I'll think you'll find a lot of Volvo love here, my wife has a '12 XC90 and we love it! Maybe I missed it but where are you located?
Congrats!
Thank you!
My wife has an 06 XC90. We really like ours as well. Great for trips and will be great for hauling kids and their stuff everywhere.
And I am in Cedarburg.
What two sensors do these plugs go to? They are the two that wrap around the front of the engine. One appears to be an rpm/timing sensor but the other was missing (as in it looks like it broke off or was cut off on the other side of the engine). Thinking maybe the AC compressor since this had an AC delete at some point. .
One is for the crank position and the other is for the pulse sensor on the spark plugs wires
Engine cleanup is satisfying.
I was watching these two Black-Headed Grosbeaks (Pheucticus melanocephalus) the other day splashing about in a bird bath and I thought to myself how neat it would be if an engine could do the same thing!!!
I was going to wheel it into my driveway to power wash it. Good thing I didn't because my driveway would have been ruined.
you need another car project so we can stop muddling through bird watching references.
Quick question:
Can I run the m50 injectors without a chip? I kniw they're a recommended upgrade from the m20 injectors.
Yep, the M50 injectors are 17.5# @ 3.5 bar and close to the stock M20 14.5# at the M20 fuel pressure (3.0 bar)
Perfect. Thank you!
So looking around at injectors I am seeing green tops and blue tops from the M50. Do you know which one I want?
Edit: maybe there aren't two different colors, and the light blue I'm seeing is a faded green? I
They are a light blue/green color. Similar color to the M20 injectors but not identical
These are pretty green. Maybe it's just the lighting?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F232794289615
I most commonly see them in the lighter green, but the darker green are also M50 injectors. Be advised that Volvo 32# also come in that dark green
That bottom one matches what is in the ebay ad. That helps.
The Volvo ones are a different "body". I've used them for a couple builds and that's what is stock in my R.
