  3. BMW Discussion
  4. Which M3 is Best M3?
59 Posts 17 Posters 1.2k Views 1 Watching
    For you Snap, an E90 M3. Get an LCI if you can, looks much better IMO. After driving @MPW3RLee's for a day, I'd love to have one as a daily driver/weekend car.
    The ultimate family sedan, unless you've got M5 money.
      To be the best it would have to be all around better. The noises that come out of an s54 are awful and almost no one has found a way to fix that.
      http://mywikimotors.com/bmw-s50b32/
      http://mywikimotors.com/bmw-s54/
      Not to mention they aren't too far removed from each other.
      No it doesn't.  To be the best it just needs to be better.  Which it is.  I don't hate the s50b32 but the s54 is a better engine.
        What makes it better?
        Do you believe the S54 is better than the S65? From what I see the 100lb weight difference is more than made up with the 100hp gain. Not to mention that an S65 seems to be more reliable and require slightly less maintenance than an S54.
          Gotta change that thread title since neither of these are the BEST.
            E30 M3's are overrated.  I said it.
              Copied from the link you sent me:
              Cast-iron cylinder block of this engine has been improved: increased bore to 87 mm, forged crankshaft with a stroke of 91 mm and with 12 counterweights. Also applied reinforced forged connecting rods (length 139 mm), new high compression pistons (CR=11.5), their compression height 32.3 mm. The pistons are cooled by oil spray nozzles.
              There were following changes in cylinder head: improved continuously variable valve timing system Double-VANOS, used new cast iron hollow camshafts (duration 260/260, lift 12/12 mm) and decreased weight of the cylinder head. Valves as on S50B32.
                And no, I don't think the S54 is better than the S65.  S65> All other M engines.
                • i_love_carsI
                  i_love_carsI
                  i_love_cars
                  We haven't defined what best means.
                  If we are talking about the best overall package for driving on the street and to/from the track, the E9x wins by a fucking landslide. The tech and creature comforts and interior are a cut above the E46, and as Pat already noted - the lap times are on the same page or better in the E9x.
                  If we're talking about raw driving experience overall - the E46 wins. It is the pinnacle of the "pure driver engagement" factor of the M cars. E30 started it but E46 perfected it.
                  If we're talking about the engine - the S65 perfected what the E46 started with 100+ hp per liter, because the S65 did it with 2 more cylinders and a significantly higher redline. There's no question that the S65 mechanically is the more impressive piece of engineering. It's simply a fact of physics and design.
                  For a dedicated track car it is a no brainer - the E46 wins. But only as a dedicated track car because it's cheaper and parts are plentiful and the aftermarket has had an extra decade to perfect itself compared to the E9x.
                  For literally anything other than a dedicated track car, the E9x is a superior vehicle choice on paper because it retains everything that made the E46 good like hydraulic steering and high revs, and improves everything else inside the cabin. The only reason to get an E46 M3 at that point is because it's cheaper, or if you simply just arbitrarily "like it" more than the E9x. But in terms of facts and engineering achievement, the E9x is just simply better.
                  My next track car will very likely be an E46 M3.
                  2007 Z4MR
                  2003 E39 M5
                  2002 E46 M3
                  2021 X5 40i
                    The E90 DCT is the obvious choice for practicality.
                    E46 M3 is the obvious choice for putting a half cage in, adding suspension, and beating the crap out of.
                    my heart is somewhere in between as it is the difference of what you want vs what you need
                      Man, of money were no object I might say a stripper e9x would be my track car.  Now money is a very real object in my life so I'd take an S54 for a track toy but I really love the e9x chassis.
                      • i_love_carsI
                        i_love_carsI
                        i_love_cars
                        Ok well if we're talking money is no object then I'll bring a GT3 RS and destroy any E9x M3 no matter how many hundreds of thousands you put into the car.
                        Let's keep it realistic because if you think the E9x would be your track toy if money were truly no object, then you're just letting your bias in because you are still high on your recent jump into ownership.
                        The M3 is not even close to the end-all be-all of track cars if money is no object.
                        2007 Z4MR
                        2003 E39 M5
                        2002 E46 M3
                        2021 X5 40i
                          What I meant was between the two options presented.  Yea, if I can pick anything then a 997 GT2 RS or some variant of the GT3 or  Cayman GT4 are my choices.
                            those are opinions, not facts.
                            whats more of an engineering achievement - a single man using a shovel, wood and ropes to tip a 20 ton rocks on its end, or modern crane that lifts it into place? ya, the crane is faster at completing the task, but it took millions of dollars in equipment and tools, thousands of pounds of materials, and hundreds of hours to build it first. the man just ate some tacos,  sawed some trees, and dug a hole.
                            in my opinion a car/motor that is simpler is more of an engineering achievement.
                              So... LS swap?
                                What's the point of owning the Datsun and an e9x M3? Maybe I'm too ignorant for this conversation, but they seem too similar to me. The e46 at least adds a little spice. I have limited experience, but my general impression is that e46s in general are kind of cheap and crappy, whereas e9x is a pretty solid car.
                                I think the e46 will be less reliable, and require more pain and suffering to live with, which results in more frequent and entertaining posts, so that's my vote.
                                  https://www.google.com/amp/www.motortrend.com/cars/bmw/m3/2011/2011-2011-ford-mustang-gt-vs-2011-bmw-m3-comparison/amp/
                                  • damnboy037D
                                    damnboy037D
                                    damnboy037
                                    I would look for a open wheel race car, the grip on those are crazy. I only drove Skippy open wheel on street rubber, but taking the boot in Watkins Glen trying to keep up with the instructor (which he complimented me on) was almost too scary.
                                    I would get the e46 over the e9x, but neither are the best m3, that would be a debate between the e30 & the euro e36 (s50b32).
                                    99 M3 320rwhp @ 6psi
                                    95 M3 s50b32
                                      Poll updated to let you voice your opinion on which M3 is worst
                                        At least the F80 lost weight from the E90, a small step in the right direction.  Also looks awesome.
                                          This is a terrible analogy.  #1. That single mans results are not repeatable nearly as easily as the crane.  #2. By this logic the man who digs his own hole and shits in it has achieved a far greater engineering achievement than the guy who invents the toilet and associated plumbing to shit in because the hole in the ground is simpler.  In your example I can move for more rocks at a faster rate than the single man doing it manually.  I can also operate that piece of equipment for a longer period of time without rest where as the human design has inherent flaws built in such as the need for food, water and sleep.  The piece of equipment also won't age the same way as the human.  In 10 years that man may be dead at which point I need another taco eating, tree cutting, hole digging man to replace him.  Also that man being a man it can be assumed that eventually he'll want to find an easier way to perform this task... which is when he finds the crane and realizes that it's far superior to him doing it on his own.
                                          I'm not for over complicating things but simpler doesn't always mean better.  No intelligent person is out there lauding the superiority of the carburetor and drum brakes because they're far simpler than that blasted electronic fuel injection and disc brake set up.  I can fully understand and appreciate "simplify and add lightness" but it's not an end all be all for engineering achievement.  Relating this back to the topic, the S65 creates more power than the S54 while getting similar fuel mileage.  The S65 creates more energy using almost the same amount of fuel.  That alone is an engineering win for the S65 over the S54 by adding some technowizardry that we never see.
