  4. Joined the Club Today
425 Posts 20 Posters 0 Views 1 Watching
    Better you than me?
    Good luck. I'd suggest getting the car running and driving as quickly as possible, and worry about everything else later. Obviously the rest of "the club" has been there and knows the dangers of mission creep and subsequently getting overwhelmed/loosing motivation.
    Plus, you're in my spot dude. 😄
    Getting it run as soon as possible is the goal. Ben is grabbing the last parts from Chris at the picnic today. Gonna review what I've got and source the rest of the stuff to get it running. Trans is the main thing I can think of now. Not sure if it has a wiring harness or not.
    Unsure of the status of the M50, being that it's good or not, but I'm sure we will be able to figure it our relatively quickly once it's in.
    Buying coils to replace the blown suspension is the other matter of business, but will not be done until the car runs.
      Get the M50 in and running. Need a 260 and a few other bits, but have the majority of it.
      Replace suspension. Fix other things that might kill me while driving.
      Drive it.
      Wish it had an S50.
      What a trip this was.
      After taking some inventory, getting pricing from @patsbimmer1, and talking with @GunMetalGrey, came to the conclusion that buying @ChrisO S52 would be a better value for only a few hundred more than buying everything to get the M50 that came with the car running. Initially I wanted to only purchase the drivetrain from the car, but after some deliberating figured out that it probably wouldn't be plausible.
      So I got a storage unit so I could put the M3 somewhere while I tore it down and pulled the drivetrain.
      We were trying to figure out the best way to get it from Green Bay to Appleton. Considered driving it, but its gutted, on shitty tires, and no seat. Ended up getting it flatbeded from his to the storage unit. Chris said they had to gas up the truck before heading out so he left a bit after they left to get gas and went to meet me at the storage unit. We got there at the same time, but the car was not there. It had started raining pretty good at this point so were both just sitting in our cars and waiting. 20 minutes go by and it's still not there and now its been like an hour since they left his place. Because he used AAA we didn't have the towing company info. Figured out that the picture he took of the car on the flatbed had the phone number on it, but the number was a disconnected line or was not accepting calls. Waited longer, still raining. Chris has been on hold with AAA for like 20 mins so decided to just drive back down 41 to see if they were stuck on the side of the road. He called me and told me the car would be there soon and it showed up as he was calling me, almost 2 hours after leaving Green Bay.
      But hey, it stopped raining by then, which was nice.
      But yeah, time to start doing some work. Very excited about potentially having an S52 E30.
        Nice!
          Glad this swap is going to good use!
            Score!
              awww yeh.
                Coils and wheels ordered.
                Thank you site wide 20% off, eBay
                  @ChrisO has been a massive help in the whole sale of this car. Between arranging the flat bed, driving down to help unload the car, helping jack the car up(lowered and rusted jacking points), and prep the engine to be pulled this is by far the best car sale I've been a part of.
                  Car is in the air and the the harness is free from the chassis. Last things to pull are the power steering pump, AC compressor(all bolts removed but stuck on, not sure about this, will need to revist), and then some small evap shit. Rad support being completely off will make pulling a lot easier.
                  @GunMetalGrey coming in big time as always and supplying the crane to hopefully pull the motor this weekend.
                    The A/C compressor has sleeve dowels on some of the bolts, just pull/pry straight out from the engine.  Looks good, that will be a piece of cake to pull straight out the front.
                    Edit: did you remove the 4 long bolts that go through the compressor body?  The bracket won't come off unless you get the bolt out that is hidden by the tone ring/front pulley.
                      @ChrisO will have to confirm as he was working on pulling it off, but I believe he pulled all four of the bolts that hold the compressor on the bracket. It just appears to be seized or something to the bracket. We didn’t have any good prying tools so we were only able to hit it with a hammer but didn’t get very far.
                        I think there's a hidden bolt. Did you look at the drawing on realoem? 😐
                          I'm thinking it might be 15/16 in this diagram. There's really no good diagrams that show how the compressor mounts unfortunately...
                            It's out
                            Was a bear, but I'm pretty proud I was able to do it myself. Biggest pain was getting the oil pan to clear the steering column but once I pushed it from the side I was able to manage. 0/10 would not recommend doing this in a narrow storage unit.
                            Let the build begin.
                              Nice work! Those harbor freight load levelers are good to have. Always fun when the red plastic handle loosens up while cranking on it. That generally happens when your harness is getting pinched up against the firewall, shifter is jammed into the trans tunnel, crank pulley is smashed into the radiator support and you are trying to quickly alleviate the impending doom
                                Crane and load balancer curtesy of @GunMetalGrey. I'm not sure how you would pull this out with out a load balancer.
                                  FWIW, I didnt even attempt installing the 24V with the G260 in from above. I dropped the subframe and installed the engine and trans from below. There are a few ways to go about it. Are you installing the engine in the e30 really quickly or are you going to tear into the engine a bit before installing it?
                                    Was thinking about dropping the subframe on the M3 but didn’t want to deal with the steering column.
                                    The E30 is at Ben’s shop so that’s where it will be put into the car. Can’t even get the motor out of the storage unit until the M3 is gone so it won’t be going in immediately. I planned to do a bit of a refresh. It needs a VCG but I’ll probably do a couple of the other refresh bits while I have easy access to it.
                                    Was thinking maybe this winter depending on my garage/shop setup to pull it and do more a full rebuild as it is high mileage.
                                    But I want to drive it this summer so that will wait for now.
                                    • ChrisOC
                                      ChrisOC
                                      ChrisO
                                      Time to roll her on her roof in the parking lot for the subframe and diff
                                        What coilovers did you end up going with?
                                          JOMs for the time being.
