pistonse30
    Also waiting for burnout videos!!
      When are you and Ben going to get together and kill the trails?
        I think he just Zing'd ya
          Dropped the rear an inch so Earl can start talking to me again!  Lol.
          I've been driving it a lot and not taking many pictures.  I think I have about 350 miles on it so far.  Speedo gears are broken so there's that.
          Oil has been changed once after initial start/warm up, around 30 miles and again around 150 miles.
          Added a moroso vacuum pump that I'm starting to learn and work the bugs out of.  If I took it for a track day I feel the catch can would fill up and overflow in 20 mins in high RPMs.
          "The Black Pearl" does grip and go and is a blast to drive.  Can't wait to get the tune sorted out with a "new" ECU.  The current one locked out after one flash when it was on the dyno.
          Burning gas,
            Good to see you and glad to have seen this monster too!
              If you took it out for a track day you could probably just stay in 3rd the entire time!
                Is there a reason for the ecu locking out? I've never ls'd before.
                  "I've never seen that happen before" is the famous phrase that has unwillingly attached itself to me.  Jesse at Late Model Throttle said the same thing and he can tune LS motors in his sleep.  No clue.
                    That is unfortunate. I Recently just spent 1400 on an ecu so I feel your pain.
                    So this means it's going to be on the dyno again?
                      I bought a used one for $70.00 and have a message into Late Model Throttle to schedule an appointment.  The chevy life isn't too bad!
                        Cheap replacement. NICE!
                          ^This.
                          I get Speedway, Summit, etc catalogs in the mail. Looking at the prices of aftermarket engine components will make you cry. Stroker cranks, cams, rods, pistons, heads.... You could build a 450hp engine with mountains of torque for the price of a used s52...
                            My kustom cam was $300.  Heads were $3600 though.  It gets expensive when you start getting into the valve train.
                              "Cold" start on the 4th ot July!  God bless America and all the LS swaps.
                              20180704_083159.mp4
                              • 20180704_083159.mp4
                                Got an update on the refurbished cluster!
                                  So glad you decided to go to Diego=D
                                    You like him?  Who is the other guy that does them?
                                      Got a new driver's side valve cover off of the 2010-2013 LS motors. Part number:12642655.  It has an updated breather design and hopefully won't suck as much oil through the vacuum pump system.
                                      Also did an oil and filter change. NAPA Gold Filter and Valvoline 10w-30 conventional.
                                        BavRest. Diego says most of his business is redoing their clusters lol
                                          I'm glad I chose wisely!
