Hello. My name is Dan, and today I doomsday prepped
bp.p.s. joe, we're going to have another epic shootout year in autox. my new tires are grippy compared to last years!
Yes!! This is going to be awesome. More motivation to finish mine by mid summer
Rs's?
I also got a good chuckle out of your "gold theme" pic.
yes, same wheels i've had.
I have a pack of o-rings for that, too late now. I replaced mine last Saturday. I don't know if only early cars had the o-ring seals. My 2/94 has crush washer plugs, I think the same ones as the vanos access plugs. The o-rings came in a pack of 25 so 11.5 more people can have a pair if they want them.
yeah, i see no real point in that, but thanks!. they are machining access holes which can just be welded shut, so putting new o-rings in just will be a point of failure again in the future.
and you are correct, early versions had the plug/oring. not sure if there was a specific cut-off date based on each motor (m50/s50) but mine is also an early 94 date.
the one time each year when the car is actually clean. into daily driving duties she goes!
also, i saved a trapped baby bunny during this photo shoot. highlight of my week.
and an update to my project list:
- find oil level wiring, or add it. SKIPPING THIS. I HAS DIPSTICK.
- find washer fluid pump/sensor wiring, or add it. reconnect washer tank to hood hoses.
- replace windshield with used OEM glass.
- wire in electric fan correctly. https://www.r3vlimited.com/board/showthread.php?t=210783
- permanently mount elec fan with bracket kit. DONE
- Buy ignition cylinder/key to match VIN.
- Fix my antenna. z3 or e36 mast.
- Shadowline window trim.
- Replace rear subframe bushings. Soft poly.
long term wish list
- adjustable trailing arm bushings
- bigger sway bars
- dedicated set of auto-x wheels/tires.
I had a bunny hole in my front yard with about 6 of them. I found this out as I was mowing the lawn and the ground suddenly gave birth to some furry little creatures. Fortunately I didnt mow over them, unfortunately a predatory bird knew this was coming and quick grabbed one as a snack. My wife was also watching as this happened and gave me the Lee Trevino Happy Gilmore look of shock and disbelief that I had somehow caused this travesty.
Love the photos! Excellent use of sepia, I normally am not a sucker for sepia but you have succeeded with it here
thanks guys! wasnt sure about the sepia thing either
I have a z3 style mast from my compact that I won't be using=)
stubby version? sold!
I don't have a short antenna for it but I believe it's in good working order.
cool. shoot me a pic and a price and we'll get this rollin. i was annoyed to be out of milwaukee and have no radio reception this weekend...
ill take it! paypal/willing to ship? i could also come pick it up.
Whatever would work best for you=) Let me quick find it in the garage tonight so I can be sure it didn't get legs and walk off
aaaaand the parts go clunky clunk. my CSB sounds like its dead again. assuming my driveshaft is bad, causing the repeated issue from last year.
link for my referencehttps://www.bimmerforums.com/forum/showthread.php?1834781-Failed-CSB-Bad-u-joint
at least its easy to replace, and I bought it from FCP so ill get a new one for free.
