e30318is5-lugm54
    Thanks for mentioning that oil distribution block, I didn't know that one existed but I will definitely be buying that one!
      Looking good! Apologies if I missed it above but what are you using for the new hard brake lines to the calipers and bias valve?
        Its a nice solution compared to mixing and matching fittings! My only concern is that with the way it's weighted, it is pulling in the direction of loosening the banjo bolt holding/sealing the whole assembly.  I'm guessing it will be fine if I crank it down, but I may look into a way to either brace it or secure the banjo bolt with safety wire/etc.
        I had ordered a roll of PVF coated steel brake line, but it looks like I got sent the wrong thing and it's just the greenish colored steel line similar to OEM. If it gives me problems I'll probably switch to nicopp.
          Made some progress over the weekend:
          Replaced the rear main seal with a genuine BMW seal:
          I also removed the original baffle from the e34 oil pan to replace it with an Achilles Motorsport baffle. This baffle isn't designed to be used on an M54 but the e38 oil pickup lands in relatively the same spot as the e34 pickup, and after a little trial and error with notching the baffle to clear the bend in the tube I was able to get it to fit without issue. So that's ready to be welded up (and welding the pinhole I accidentally put in my oil pan removing the original baffle like an idiot) and then I can seal up the bottom end!
          Oil distribution block and oil temp/pressure senders are mounted for good and ready to be wired up. E21 booster is cleaned and painted, with the e30 clevis swapped over and set to match the spacing of the old booster. Just need to re-route the brake line and clutch feed and that will be ready to install.
          I also finished cleaning the passenger side of the engine bay, subframe/steering rack, and got part of the way on the driver's side before running out of water. Hoping to get that finished before the end of the week. It won't be pretty between the cosmoline and primer, but its a lot better than all that plus a thick layer of dirt.
            Any groove on the crank from the old seal?  Mine was pretty gnarly so I inset the new seal, so-far all is well.
            Glad you got the baffle to fit. Are you moving the clutch feed line per my experiences or is it just tribal knowledge that it needs to be rerouted?
              There really wasn't anything noticeable on mine to be honest, at least I didn't feel anything significant running my finger over it. I used the genuine bmw replacement kit that has the seal pre-pressed into a new housing, so wherever BMW puts it is where mine is. It wasn't leaking or anything before, so I'm hoping its good to go.
              And the clutch feed relocation is 80% per your experience, and 20% holding the booster up to the firewall and confirming exactly what you found. Did you have any interference with the brake line mounting clip behind there too?
                I trimmed the innermost piece of the plastic clip for the brake line to get it to fit.
                344b3f62eb6b3bd3fd8a53fab2ece990.jpgah yes,
                  More things done!
                  I used some super strong epoxy to bond the gas pedal mounting bracket to the base of an old e30 gas pedal and completed the install of the e46 drive-by-wire gas pedal:
                  I also finished cleaning the engine bay and re-routed the clutch feed hose to make room for the e21 booster. Since I won't have a throttle cable coming through the firewall, I ran the hose through the hole and sealed it up with a grommet. I found that an M54 vanos screw plug worked perfectly for plugging the old hole behind the booster.
                  I also got about halfway done with the ABS delete. Because the brake master cylinder I'm using only has one port for the front brakes I had to join them with a tee fitting before running a single line to the master for both front and rear. I also adjusted the front right line to go around the outside of the booster as it was getting pinched.
                  With the brake lines routed I mounted the booster, e32 750il master cylinder, and a newer reservoir from the parts car
                  I then spent the next two hours trying to make the hard lines from the tee to the master. That line will be pretty short and turned out to be an absolute pain as I was using steel line, I gave up after a couple failed attempts. I will be picking up some nicopp line to try again as it seems to be much easier to work with. I will probably also re-do the line from the front right caliper to the tee as it could be cleaner.
                    What kind of proportioning valve do you have there?
                    Make sure you do a good job on the ABS delete because I will probably demand details and follow your lead
                      Just the stock e30 proportioning valve. The e30 m3 uses the same part so no changes were needed when I swapped the suspension/brakes. I may eventually swap it for an adjustable one though as the larger single diameter MC will likely shift the bias slightly rearward.
                        I'm not sure about e30 ABS systems but the e36 has some proportioning done in the ABS pump assembly.
                          I have probably 5-10 feet of line laying around so you can get this done for the picnic
                            Unfortunately, the brake lines aren't in the way of making it to the picnic, it's the usual time/money/wanting to keep my sanity haha. Thanks though!
                            As far as the proportioning, I did some more research: I wasn't aware that late model e30's use a dual diameter brake master cylinder, so while the front brake bore is around 22mm, the rear is smaller, so when paired with the e30 m3 brakes it likely upset the bias a bit. The stock e30 m3 master is a single diameter 23.8mm and the 25.4mm master that I am using is a common upgrade for a firmer pedal on those cars. Because I have different shocks/springs/tires/brakes/bushings/weight distribution/etc compared to stock, it makes sense to just do the adjustable proportioning while I'm doing this work anyway. That way I can dial in the braking for the best performance, plus it's another adjustment to screw around with at an autocross.
                              ABS delete and master swap complete!
                              I decided that an adjustable bias valve would be a good idea so I picked up a Wilwood part that has M10x1.0 bubble flare fittings. After a bunch of trial and error, I decided to mount it down where the original proportioning valve sat. Originally, I wanted to mount it up by the fuse box for easy access, but I didn't want to have lines running above the master so that got canned. I re-positioned the brake line running to the rear and made a bracket that connects to the stock proportioning valve mount and adapts it to the Wilwood part:
                              The nicopp lines are so much nicer to work with than the steel lines, though they did seem to be a little harder to get a nice flare compared to the steel. Using more oil on the bubble flare tool seemed to help with this, hopefully they all seal well. The lines aren't perfect, but don't look too bad! I have tool access to all the fittings and can install or remove any part without having to take everything else apart.
                                ooo purdy
                                  I agree, looks great!
                                    Is that the check valve connected straight to the booster?
                                    im using an E21 check valve. I had used one on the M20 as well to get rid if the expensive and convoluted check valve situation the M20 comes stock with
                                      That's probably what it is haha. It was on the booster when I got it, and I'm using it to plug the hole for now to keep dirt out.
                                        Is that a 944 booster? It doesnt look like my E21 booster
                                          I'm about 90% sure it's an e21 booster, maybe there are a few different variations?
