  4. chit chat thread
chit chat thread
    It's interesting how a feature starts at the top end cars like 7 series and over time trickles down.  I worked on an e32 740iL that had an aux electric water pump so that you could continue circulating coolant and heating the interior for a while after shutting the car off.
      snap said:
      Thats very cool! So does it just keep the blower running while the car is off until the heater blower temp matches the interior temp?
      Criteria to run REST is as follows:
      • Ignition switch off
      • Ambient temp less than 59f*
      • Left heater core temp is greater than 158f*
      • Battery voltage is at least 11.4 volts
      • The time elapsed since the ignition was turned off is less than 15 minutes
      Once the function is activated, the REST button LED illuminates, the blower runs at medium speed, the auxiliary coolant pump runs, the air distribution flaps are positioned to provide maximum heating. Blower speed, flaps positions, and desired temperatures cannot be changed while REST is active.
      The system runs until any one of the following occurs:
      • Ignition switched on
      • Battery voltage drops below 11.4 volts
      • Coolant temperature drops below 86f*
      • The REST button is pushed again 15 minutes pass
      GB-335xiCoupe said:
      Probably until your battery dies. LOL
      It won't work if your battery is low, and I know that from personal experience, lol.
      Jeff said:
      Ya know, I used that one time and it didn’t seem like it did much. I guess it wasn’t ice cold but didn’t seem that warm
      Really? That's weird. Mine is always toasty warm! Might help to set the dial to maximum hotness before using it.
      I thought it was a 2006+ feature, but someone commented saying they have it in their E39! I was surprised and amazed at the same time.
      • JeffJ
        JeffJ
        Jeff
        I will give this knob another try with hotter temps. I could be letting to much warmth out of the car also. It takes a minute to get the kids and wife out of the car.
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          I wish I had a rest button in my office today.  The furnace quit yesterday and is still not working, it's nearing 50 degrees.  I have my coat on my lap and my stocking hat on.  Pretty awesome.
            That sounds horrible :(
              Efff that. I would go home.
                I'm hourly, so I'm the one that gets screwed then.  I got a space heater now.  If one of you jokers is an engineer for Carrier... They used a composite pulley and it eats belts every month because it gets hot and now finally exploded.  The unit is only 2 years old...
                  sounds like you already know the problem. You should be said engineer and fix it! :lol:
                  • JeffJ
                    JeffJ
                    Jeff
                    Re tried the rest button today. Apparently key to the warmth is turn the dials up to 84 before using it
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      Carriers go through belts like crazy. On newer TKs thier belts are on a 10,000 hour maintenance interval.
                        If you hold the rest button while the car is running you can scroll through what all the sensors are reading.
                          Sent from my SM-G950U using Tapatalk
                          • GB-335xiCoupeG
                            GB-335xiCoupeG
                            GB-335xiCoupe
                            Selling it? I might buy...
                              could you imagine that thing as your transportation around road america? :wub:
                                Seems to fit right in...
                                • GB-335xiCoupeG
                                  GB-335xiCoupeG
                                  GB-335xiCoupe
                                  Too much time on his hands this one has... Hmmmph
                                    Me? Nahhhhhhh that took 5 seconds.
                                      Dudes got unprecedented graphics skills
                                      • GB-335xiCoupeG
                                        GB-335xiCoupeG
                                        GB-335xiCoupe
                                        Now Yoda as a driver, you must add.
                                          killing me, you guys are. Yes.
