  4. chit chat thread
chit chat thread
    Made this video today. Anyone else have it, and love it?
      Thats awesome! I had no idea they made something like that. I kind of want one now just because of that. LOL
        Thats very cool! So does it just keep the blower running while the car is off until the heater blower temp matches the interior temp?
        • GB-335xiCoupeG
          GB-335xiCoupeG
          GB-335xiCoupe
          Probably until your battery dies. LOL
          • JeffJ
            JeffJ
            Jeff
            Ya know, I used that one time and it didn’t seem like it did much. I guess it wasn’t ice cold but didn’t seem that warm
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              It's interesting how a feature starts at the top end cars like 7 series and over time trickles down.  I worked on an e32 740iL that had an aux electric water pump so that you could continue circulating coolant and heating the interior for a while after shutting the car off.
                Criteria to run REST is as follows:
                • Ignition switch off
                • Ambient temp less than 59f*
                • Left heater core temp is greater than 158f*
                • Battery voltage is at least 11.4 volts
                • The time elapsed since the ignition was turned off is less than 15 minutes
                Once the function is activated, the REST button LED illuminates, the blower runs at medium speed, the auxiliary coolant pump runs, the air distribution flaps are positioned to provide maximum heating. Blower speed, flaps positions, and desired temperatures cannot be changed while REST is active.
                The system runs until any one of the following occurs:
                • Ignition switched on
                • Battery voltage drops below 11.4 volts
                • Coolant temperature drops below 86f*
                • The REST button is pushed again 15 minutes pass
                It won't work if your battery is low, and I know that from personal experience, lol.
                Really? That's weird. Mine is always toasty warm! Might help to set the dial to maximum hotness before using it.
                I thought it was a 2006+ feature, but someone commented saying they have it in their E39! I was surprised and amazed at the same time.
                • JeffJ
                  JeffJ
                  Jeff
                  I will give this knob another try with hotter temps. I could be letting to much warmth out of the car also. It takes a minute to get the kids and wife out of the car.
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    I wish I had a rest button in my office today.  The furnace quit yesterday and is still not working, it's nearing 50 degrees.  I have my coat on my lap and my stocking hat on.  Pretty awesome.
                      That sounds horrible :(
                        Efff that. I would go home.
                          I'm hourly, so I'm the one that gets screwed then.  I got a space heater now.  If one of you jokers is an engineer for Carrier... They used a composite pulley and it eats belts every month because it gets hot and now finally exploded.  The unit is only 2 years old...
                            sounds like you already know the problem. You should be said engineer and fix it! :lol:
                            • JeffJ
                              JeffJ
                              Jeff
                              Re tried the rest button today. Apparently key to the warmth is turn the dials up to 84 before using it
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                Carriers go through belts like crazy. On newer TKs thier belts are on a 10,000 hour maintenance interval.
                                  If you hold the rest button while the car is running you can scroll through what all the sensors are reading.
                                    Sent from my SM-G950U using Tapatalk
                                    • GB-335xiCoupeG
                                      GB-335xiCoupeG
                                      GB-335xiCoupe
                                      Selling it? I might buy...
                                        could you imagine that thing as your transportation around road america? :wub:
                                          Seems to fit right in...
