  3. Parts Wanted
  4. WTB: 24V/M54 swap parts
58 Posts 12 Posters 1.1k Views 2 Watching
    Updated first post, found a gas pedal for cheap.
    Im not keen on the going rates for MAFs but this is an OE unit  https://www.ebay.com/i/272885069168?chn=ps
    Thanks! I haven't shopped around on these yet since I don't need it right away, but that doesn't seem unreasonable for an OE one
      List updated:
      The DISA valve on my engine is not an OEM part and is shot, so I'm looking for an OEM one to rebuild.
        https://www.ebay.com/itm/BMW-M54-DISA-Valve-11617544805-7544805-E46-E39-E60-E61-E65-E66-X3-X5-Z3-Z4-OEM/172979174601?hash=item28465cbcc9:g:i-4AAOSwXxhaCjvI&vxp=mtr
          Some bits acquired, list updated!
            Added 325i coding plug for the tach
              If I find a spare cluster soon I will let you know. I wont need 2 coding plugs
                Updated, added E36 OBD2 exhaust manifolds
                  I bought the blocking plates for OBD2 manifolds from Hard Motorsports recently.  Quality was good and shipping was fast.  You can't have my manifolds though.
                    https://www.google.com/search?q=st+francis+auto+wreckers&rlz=1C1AJZK_enUS770US770&oq=st+francis+auto+wreckers&aqs=chrome..69i57.3087j0j7&sourceid=chrome&ie=UTF-8
                    St Francis Auto Wreckers shows 1997 528i exhaust manifolds for $35 each (front/rear).
                      The headers aren't going to fit? =(
                        I am going to be buying an m3 midpipe that comes with stock headers.If you are interested I can sell you the headers. Only problem is I'm quite far away.
                          Not without some work, they'll bolt to the head but one of the mid-pipe flanges hits the block and I'll need to add O2 bungs. This wouldn't be a problem but I don't have the capability to weld stainless at the moment. I'm thinking I can make the OBD2 manifolds work much easier, and then some time in the future I can modify the shorty's to work
                            Tubular OBD2 manifolds? If they're cheap enough I'd pay for shipping
                              Do you have a mig with gas? You can buy spools of stainless and mig it.
                                I have a mig that can be set up for gas (just need to buy a tank). I've never made an exhaust before, so I'd like to give it a go in mild steel instead of screwing up a bunch of nicer stainless parts
                                  You might need a different gas mix for stainless MIG, not sure.  I have had no problem welding stainless stuff together with regular wire and 75/25 gas but the welds will rust.  The weld itself looks fine and doesn't have any strength issues from what I can tell.
                                    I think you need Tri-mix  (Argon Helium Carbon Dioxide)
                                    Paging @Bassboy3313
                                      You have to buy a certain stainless wire that will work with standard 75/25 gas. When I get home I will look at the stainless spool I have and let you know the number.
                                        That would be awesome, thanks!
                                          Better late than never. So, I use ER309L stainless mig wire. Some main reasons are I mostly weld mild steel with 75/25 gas. The ER309L can be used with 75/25 gas saving me from having to buy another tank with tri-mix. Makes it easier to swap from mild wire to stainless wire. Also, the ER309L can be used to weld stainless to dissimilar metals, such as mild steel and other forms of stainless steel too. This makes it the most convenient stainless mig wire type imo.
