  3. Parts Wanted
  4. WTB: 24V/M54 swap parts
58 Posts 12 Posters 1.1k Views 2 Watching
    Im not keen on the going rates for MAFs but this is an OE unit  https://www.ebay.com/i/272885069168?chn=ps
      Updated first post, found a gas pedal for cheap.
      Thanks! I haven't shopped around on these yet since I don't need it right away, but that doesn't seem unreasonable for an OE one
        List updated:
        The DISA valve on my engine is not an OEM part and is shot, so I'm looking for an OEM one to rebuild.
          https://www.ebay.com/itm/BMW-M54-DISA-Valve-11617544805-7544805-E46-E39-E60-E61-E65-E66-X3-X5-Z3-Z4-OEM/172979174601?hash=item28465cbcc9:g:i-4AAOSwXxhaCjvI&vxp=mtr
            Some bits acquired, list updated!
              Added 325i coding plug for the tach
                If I find a spare cluster soon I will let you know. I wont need 2 coding plugs
                  Updated, added E36 OBD2 exhaust manifolds
                    I bought the blocking plates for OBD2 manifolds from Hard Motorsports recently.  Quality was good and shipping was fast.  You can't have my manifolds though.
                      https://www.google.com/search?q=st+francis+auto+wreckers&rlz=1C1AJZK_enUS770US770&oq=st+francis+auto+wreckers&aqs=chrome..69i57.3087j0j7&sourceid=chrome&ie=UTF-8
                      St Francis Auto Wreckers shows 1997 528i exhaust manifolds for $35 each (front/rear).
                        The headers aren't going to fit? =(
                          I am going to be buying an m3 midpipe that comes with stock headers.If you are interested I can sell you the headers. Only problem is I'm quite far away.
                            Not without some work, they'll bolt to the head but one of the mid-pipe flanges hits the block and I'll need to add O2 bungs. This wouldn't be a problem but I don't have the capability to weld stainless at the moment. I'm thinking I can make the OBD2 manifolds work much easier, and then some time in the future I can modify the shorty's to work
                              Tubular OBD2 manifolds? If they're cheap enough I'd pay for shipping
                                Do you have a mig with gas? You can buy spools of stainless and mig it.
                                  I have a mig that can be set up for gas (just need to buy a tank). I've never made an exhaust before, so I'd like to give it a go in mild steel instead of screwing up a bunch of nicer stainless parts
                                    You might need a different gas mix for stainless MIG, not sure.  I have had no problem welding stainless stuff together with regular wire and 75/25 gas but the welds will rust.  The weld itself looks fine and doesn't have any strength issues from what I can tell.
                                      I think you need Tri-mix  (Argon Helium Carbon Dioxide)
                                      Paging @Bassboy3313
                                        You have to buy a certain stainless wire that will work with standard 75/25 gas. When I get home I will look at the stainless spool I have and let you know the number.
                                          That would be awesome, thanks!
