  4. E30 M52
E30 M52
    That is pretty much all I ever use. It is nicer to grind and smooth out
    Back in the pre-Megasquirt era, the AFM to cone filter adapters I could find had a very poor transition between the round tube and the rectangular afm entry. The air simply runs into a wall. So I packed JB putty in the corners to make a radius, then ground and sanded it smooth as glass after it hardened.
    I keep a stick of it in the car tool kit as it can patch an aluminum oil pan
      Good news: The micro bead of JB putty worked. The master cylinder is installed
      Stupid News: its dark and everything is covered in humidity juice.
      List of things you can do on a 24v swapped e30 without removing the intake manifold:
      - install master cylinder
      - change spark plugs
      - change injectors
      - rotate tires
      - complain
        It's a joy removing the manifold, you will get good at it.  The extra joy in an e36 coupe is removing the wipers, cowl plastic, and blower motor cover firewall thingy so you can get the manifold lifted off of the studs.
        • stealthbimmerS
          stealthbimmerS
          stealthbimmer
          Thats why I love the e34 platform....so much more room for activities.
          1997 328ic
            Progress this week: I popped the beauty cover nut covers in place then went inside.
            I was trying to generate some excitement and motivation by reading up on some peoples experiences with modded  M52 E30s :
            Here's to lowered expectations :D
              The user name just made me think of this again.
              But for real, it'll be fun.
              It won't match an m20 turbo, no, but the m52 alone results in a very respectable e30 power plant.
                it'll be fun!
                you'll have a working, reliable e30.
                that's pretty much all you need for a happy life.
                a family is cool, too, I guess.
                and beer.
                don't forget the beer.
                  I hate this E21 brake booster.
                  It sits closer to the firewall than stock and as i went to attach the clutch feed hose at the reservoir and start bleeding the system, i realized the clutch feed hose is slightly pinched behind the booster where it comes through the firewall.
                  As i loosened the brake booster to see what other angles i might try routing the hose, one of the studs on the interior side of the booster started spinning. I used blue loctite on the nut during install and I think that is a contributing factor. Regardless, the studs shouldnt be this prone to spinning....
                  I dont have a solution for that yet and I dont know if theres enough room to cut the nut off with a dremel like i had to do for the brake master cylinder mounting nut.
                  I ordered 3 feet of new clutch MC feed hose and im going to route the hose through the firewall through a rubber blank near the strut tower. The clutch MC feed hose is old anyways. The pedal area just isnt anyones favorite place to wrench.
                  I made some minuscule progress in other areas but its not worth mentioning.
                  I replaced the belts and noisy idlers on my nissan flagship sedan so at least there was that success
                    As a follow-up to the post about the exhaust fab, here is the Y-pipe with reducers, flex pipe, O2 bung, and V-band flange welded on
                    Its a start!
                      Much appreciated info
                        Skid plate is installed
                          Man it’s clean under there! Nice work
                            Fan.
                              Looks awesome!! I really should get one of those skid plates
                                It was one of my first purchases when i started parting out the M20 since I knew jf I didnt make it a priority I would smash my oil pan before I got around to buying a skid plate
                                  I was talking to the wife during lunch about a possible vehicle change: sell my Infiniti, get a winter beater (the kind you look forward to crashing into shopping carts and snow banks with) and using the price difference to invest towards something I have been wanting to do for a while (no, not gender reassignment surgery). Her counterpoint is that I have complained about driving some of the other cars we have had . I like my infiniti quite a bit, its the first car I have owned in a long time that I really enjoy as a daily driver. My counter to that was that I should be driving the E30 about 7 months out of the year. Her counter was that the E30 isnt reliable enough to drive 7 months out of the year.
                                  I'm a bit annoyed by the car's reputation as it was a reliable daily driver for 4 years with no engine mods, 1 year with megasquirt, and 1 year with megasquirt and the turbo, then I encountered the perils of boost. 1 snafu which is my fault (overboosted/no boost gauge) and the 2nd which was the fault of the engine builder I used on the rebuild.
                                  My wife doesn't understand that this new engine configuration has a higher probability of being reliable than the last couple configurations.
                                  So it appears I have some people to prove something to, and out of spite, I will try my best to but a heap of miles on the E30 this year.
                                  The goal is to have it ready to go for the first of March so long as weather cooperates
                                    Reminds me of an Ollie and Sven joke:
                                    **ollie and Sven are standing atop a hill looking over the city.
                                    Sven says to Ollie, “hey Ollie, see that bridge over there?”
                                    Ollie “yes I do Sven”
                                    Sven “I built that bridge, do you think the towns people call me Sven the bridge builder?”
                                    Sven “see that church Ollie? I built that church as well. Think the towns people call me Sven the church builder?
                                    Ollie “why are you telling me this Sven?”
                                    Sven “they dont call me any of those things Ollie, but if you fuck one pig....”
                                    Point being you have one engine failure on a heavily modified car and all the outsiders are quick to crucify you.
                                      A+++
                                        1)sell the datsun
                                        2)drive the e30 all year
                                        3)pocket some amount of the datsun sale to cover the 'unreliability' in the future
                                        4)invest the rest in bitcoin
                                        5)lose your ass on bitcoin because its just made up money
                                        6)save your marriage by selling the e30
                                        7)share the minivan with your wife in the winter and use a bicycle in the summer
                                        8)get in great shape because you are biking all the time
                                        9)become an olympic athlete with your sveltness and make millions in endorsements
                                        10)buy several s54 powered e30s
                                        Don't forget us little people when  you are rich and famous
                                          A++++
