400 Posts 25 Posters 0 Views 1 Watching
  • TkuhnT
    TkuhnT
    Tkuhn
    UPDATE
    Welding has been completed on the bay. All of the holes that I wanted to have filled to be shaved are completed as well as the stitch welding on the under sides of the frame rails. Next up is some more grinding then filler, sanding and paint!
    My wiring supplies came in as well and I am super happy with the way things are turning out. Got both of the harnesses finalized where they exit the cabin of the car and are routed up though the fender frames. I learned alot about wiring and my work developed alot over the years that I was building my civic, if there is one thing I learned its do it right the first time (I redid the wiring on my hatch 4 times before I was close to happy with it). So with that being said I am going into this car with every bit of knowledge I have and doing everything right the first time.
    All of the wiring is wrapped in flame resistant tech-flex and the harness connections are Deutsch plugs as well.
    Here is the passenger side connections.
    And on the driver side I was able to use just one 12 pin bulkhead style connector.
    And I was also able to figure out the routing and set up for the heater valve wiring. This car will still have a heater core and heat, because I enjoy driving in fall with the windows down and the heat on haha.
    That's it for now. Grinding, filler and sanding will hopefully start this week. Then once the bay is near ready (or i get sick of not feeling my fingers) I will be continuing the wire tuck with routing to all of the components on the front end.
      Heat on, windows down, in the fall.
      My man
        Never seen the insides of a wire tuck, great work!
        • TkuhnT
          TkuhnT
          Tkuhn
          Thank you! Although not too sure many people do tucks on e46s, atleast that I've seen haha. I'll be doing Nicks as well, but I can gaurentee not many people go this in depth either lol.
            Looking good. All those connectors and bulk heads add up quick. Where are you ordering your wiring supplies from?
            • TkuhnT
              TkuhnT
              Tkuhn
              Wirecare.com ! It's awesome, one stop shop for all my extremely particular wiring needs, even when people are never going to see it lol
              • TkuhnT
                TkuhnT
                Tkuhn
                Quick little update.
                Got all of the final welds ground down and the bay is ready for filler and sanding.
                Also was able to wire up and finalize the driver side wiring for the headlight, corner, horn, coolant level and temp sensor. Pleased with the outcome and next will be the passenger side.
                • TkuhnT
                  TkuhnT
                  Tkuhn
                  UPDATE!
                  First off Ill save the boring photos of all the interior wires that were cut and dead ended. Hoping there wont be any issues with removing all the abs, srs, seat wiring and etc. Theoretically there should be no problems and if there are I am confident they can be sorted out.
                  I was able to finish up the wire tuck on the passenger side.
                  Heres both of the harnesses completely removed from the car. With the deutsch connectors both harnesses are easily depinned from where they connect at the fender near the door. Then they are able to be removed completely.
                  The bay is also starting to get closer and closer to the finish line. Welding is completed along with all filler was lair and sanded. Next up is final sanding to prep for paint.
                  Hoping to get started on stripping some of the sound deadening from the interior soon as well so that the interior can get painted then the entire interior harness can get loomed for final installation.
                    Harnesses and engine bay are looking great! Excited to see paint in that bay!
                    • TkuhnT
                      TkuhnT
                      Tkuhn
                      Trust me I'm about ready to also hahahah hopefully in a few weeks if time permits!
                      • TkuhnT
                        TkuhnT
                        Tkuhn
                        Have had a few parts come in the past few weeks.
                        Got my chase bays brake bias valve and all the fittings needed to make it work. This kit is normally sold with PTFE lines but Chase hooked it up with all the bulkheads, tube sleves and nuts to get it done the way I have it planned.
                        Picked up some clear corners, red tails, some door trim and some M3 door sills.
                        And last but not least my Street Faction front bash bar came in. I ordered just the basic one because I have a few plans for modifications of my own that the website does not offer. Mocked it up and it fits great, going to have to figure out a different way to mount the bumper because the bar is too long to allow the stock bumper slides to push into the plastic mounts. I believe I have a solution to this and I will share it if it works out lol.
                        • TkuhnT
                          TkuhnT
                          Tkuhn
                          Holy shit I have been slacking on the updates. Lots of parts have come in and things are slowly coming together.
                          So here we go.
                          The bay is painted.
                          Once the car was back to my shop I dropped the rear end out of the car along with the fuel tank. With that came some bad news.
                          One of the subframe mounts was ripped out and another loose and plenty of cracks lol. So with the help of a good friend we were able to replace the torn area. and get the confor reinforcement kit welded in and then opened up the upper areas inside the chassis where the tops of the mounts were. We then created a tubing brace that connects all 4 of the subframe mounting points to the rear bar which was welded in to support the rear strut towers that was plated in preparation of the rear true coil set up.
                          I have alot more progress to share and will upload more when i get a chance!
                            Seems sturdy now!
                            • TkuhnT
                              TkuhnT
                              Tkuhn
                              Continued update!
                              Busted out the brake lines for in the bay. Obviously the abs/dsc has been deleted. SO with that being said I used a custom kit that Chase at ChaseBays got me hooked up with. Everything was done with 3/16" nickle copper brake line. I love the way this stuff shines up. All the photos are of before polishing.  I was able to hide the brakeline that runs from the master to the right front and keep it out of the engine bay, I was also able to get the left front line to stay inside of the compartment on the driver side rather than run out of the compartment and through the fender well.
                              And then the lines were ran from the bulkheads to the original mounting spots where the softlines will connect. Also made sure to route them so that the added angle of the MG Solutions maxx angle kit doesnt hit them. Oh and i previously cleaned out the wheel wells and sprayed in some new 3m rubberized undercoating.
                              Now that the rear end is all reinforced and braced I was able to get the subframe cleaned up, old bushings out and installed the new condor subframe bushings and diff bushings.
                              Also got some fun parts in for the rear end.
                              MG Solutions upper and lower rear arms.
                              Stance XR1 rear true coils (also have XR1s for the front)
                              Ill save the boring photos but the front knuckles are cleaned up and re-sprayed black along with starting to clean up and re-paint the used MG Solutions maxx angle steering kit that i pulled off my 330i. Lots of parts came in including motorsports hardware stud conversion for the car, m54 fuel filter, upper and lower bushings for the rear trailing arms, new wheel bearings for all 4 corners. Fuel lines to replace the m54tu ones (completely different), oil adapter fitting for the oil filter housing to put a gauge into the system, Parts Shop Maxx engine vitals gauge (coolant temp and oil pressure configuration), some split loom for the interior harnesses, CSF aluminum radiator, and a few other odds and ends.
                              So i mocked up the new radiator and front end to fab up a bit of protection for the radiator.
                              Also cut the stock tow hook thread mounts off the front and rear bumper mounts with plans to weld them up to the bash bars using the stock locations (still needs to be done)
                              Ordered N54 exhaust studs and new oem exhaust manifold nuts and got them installed as well.
                              And last weekend was able to drop in the engine and trans! Before popping the trans on I threw in a new clutch fork and throwout bearing. Last year when i put this engine and trans into the 330i I had replaced the fork pivot pin with the stainless steel one from condor as well as replaced the clutch. The flywheel was just machined when i installed those parts last summer. The clutch and flywheel looked great still so no need to replace them. While i was at the trans i replaced the whopped out shift carrier bushing with a new condor one and then installed a new turner motorsport rear shift bushing.
                              More progress to come! its crunch time and I am hoping to have the car done by the end of April with a few weeks to get some miles on it before Automotion.
                                You guys are experts. I want to throw my car away after visiting this thread
                                • TkuhnT
                                  TkuhnT
                                  Tkuhn
                                  Hahahaha were no experts. Honestly im just putting alot of the things I learned from building my civic over the past 8 years into this car. Like keeping in mind to do things right the first time so theres no reason for me to redo things over and over haha. And im not even going as in depth with everything that I would like, but id rather have the car done to drive, enjoy and get some more seat time. Its extremely hard for me to not touch everything and make it over perfect in my eyes lol, in time the car will become more is my hopes!
                                    Looking killer man!! Those brake lines are nice!!! What is the reason behind using the copper nickle lines and not steel?
                                    • TkuhnT
                                      TkuhnT
                                      Tkuhn
                                      Thanks!! And honestly they are easier to work with. But they also hand polish really well.
                                        The big upside is that it won't rust and fail catastrophically like steel lines will.  Not to be confused with straight copper lines which can't stand up to automotive brake pressures.  NiCopp is pretty neat stuff!
                                          Sometimes it's called "Cunifer" it is excellent to work with, won't corrode, and is only marginally more expensive.  I think Volvo has been using it since the 70's.  Try it once and you will never use steel again.
