  4. chit chat thread
chit chat thread
7.1k Posts 73 Posters 72.4k Views 4 Watching
    If the mirrors are folded in, then it’s stored
      Congratulations, the car has turned into a wasp’s nest
        Would you congratulate someone if they turned a wasp nest into a car?
        XIC3DmP.jpgbees 2bees 4bees 3
          Thats creative. I had to share it with someone.... AutoFashion-VIP-Fest-2017-148.jpg
            My girlfriend bought a new car maybe two weeks ago, (She bought it in Ohio and drove it back) and yesterday she came home and said her windshield washers weren't working. I thought this was weird since the car is a 2016 with only 11k on it, so we went down to the parking garage to take a look and they're working again, we figured maybe she just didn't pull the lever correctly. Well this morning she was on her way to work, went to wash the windshield shortly after leaving the garage and the washers worked, but the fluid instantly froze on the windshield and she had to stop and scrape it off! Turns out the lines had frozen yesterday and then thawed when it was parked inside and we tested it. The car started life in SC, and it turns out the washer fluid tank is likely filled with "summer" washer fluid that has a much higher freezing point than what they sell here, so I'll be flushing it out and refilling tonight. Pro tip if you buy a new daily from somewhere with a warmer climate: flush your washer fluid before it gets cold!
              I’ve heard stories of people buying CA cars in the winter and having them shipped to WI and they show up with the freeze plugs pushed out of the block
                It took her two weeks to drive back from Ohio?  Talk about taking the back roads... Whew! Now that I got that out of the way, I had never heard of "summer" washer fluid.  That's really stupid.  I thought all washer fluid was the same, learn something new I guess!
                  Haha I wouldn't be surprised if there were some back roads on the way home! I'm guessing it just wasn't cold enough till this past week to actually freeze it. Maybe 'summer' is the wrong word, probably a different formula for warmer climates since it wouldn't need as much anti-freeze/alcohol/etc.
                  • stealthbimmerS
                    stealthbimmerS
                    stealthbimmer
                    Varying levels of alcohol to adjust the freezing temp. Places that never see -20 degree temps dont need windshield washer fluid that is good to said temp.
                    1997 328ic
                    • GB-335xiCoupeG
                      GB-335xiCoupeG
                      GB-335xiCoupe
                      That's why we drink a lot of alcohol up in Wisconsin, to keep our lines from freezing.
                        Most cheap washer fluid is only good to 32 degrees F.
                        It's always the cheapest, and right next to the stuff good for 0 degrees.
                        Makes me wonder how many people this happens to, regardless of where the car comes from.
                          Had this happen to me last year in my white 328i. Car came from Texas. Good times.
                            I've got 6 gallons of the cheap stuff sitting in my garage that's supposed to be down to -20F and that's the all season formula.  I guess if a manufacturer can save a couple pennies by making a lesser product to sell in regions that don't require them to meet the same standards we need in the colder climates then that's what they'll do.  I guess I'd do the same thing.  I never thought the world of washer fluid would be so diverse!
                              You can also use certain washer fluids as a “replacement”/alternative in methanol injection systems. It’s nice because It’s cheap and readily available. Some people even mix it with HEET and or dilute it with water.
                                ^reasons why washer fluid is classified as a hazardous material for transportation haha
                                  First post of the year!!!! Suck it
                                    I pulled the engine and transmission from my Toyota van on Friday night/Saturday morning.  That was a joy...  It was extra fun because it has AWD.  Back story on this, I bought it pretty cheap with a bad transmission and waited until it was freezing outside to work on it.  A friend and I were working on it in a warm shop with a lift though so it wasn't bad other than some rusted bolts.  I have a crazy idea that might involve having an excellent running 3MZ-FE for sale... and a van that is no longer AWD.  It's an '04 Sienna, XLE Limited.
                                    Does anyone have pictures from the side of an m50/52 with an e34 oil pan installed?  I'm trying to figure out whether front or rear sump would work best.
                                    Also any thoughts on the effect of moving a brake caliper to behind the axle in front rather than in front?  I may need to swap the knuckles so that the steering rack is in front rather than behind the axle so that would move the brake calipers as well.
                                      3:00 or 9:00 are the preferred locations for caliper mounting since if they are at 6:00 or 12:00 they can see “pad knockback” which leaves you with the feeling of air in your lines even though they are solid fluid
                                        Excellent pictures, thanks!  I didn't think switching from 3:00 to 9:00 would be a big deal.  Is there a market for RWD Sienna vans with BMW drivetrains?  Also how long with the rear differential hold up?  Factory system was 230hp with full time viscous style with 50/50 front/rear.  The driveshaft and differential look pretty beefy so i would hope for the best.
                                          Only thing is maybe use Right side Calipers on the Left side, to get the bleeder screws pointing up again
