  4. chit chat thread
chit chat thread
    Deep, introspective life thoughts right there bro. Time only travels one direction, so you can never go back.
    Question is, is it better to not be able to go back and cut the wires, or better to not be able to go back and not cut the wires?
      When i've run into this I either unplug the sensor or cut the wire.  This is more frustrating to me when i'm trying to install a sensor.  Then I'll either keep it unplugged or preload the wires so they are unloading in the direction I want to turn the sensor.
        I thought I invented the preload trick!!!
        • GB-335xiCoupeG
          GB-335xiCoupeG
          GB-335xiCoupe
          In a truly circular universe where time is a complete continuum and one could take a shortcut through said continuum, we would all in fact know about the pre-load loading theory. However, Pat and Snap are clearly from the future, and much wiser than any of us mere mortals. Just kidding of course, we all know that Al Gore invented the preload trick. Afterall, he invented the Internet. One smart cookie.
            Also, Merry Christmas everyone!
              If the mirrors are folded in, then it’s stored
                Congratulations, the car has turned into a wasp’s nest
                  Would you congratulate someone if they turned a wasp nest into a car?
                  XIC3DmP.jpgbees 2bees 4bees 3
                    Thats creative. I had to share it with someone.... AutoFashion-VIP-Fest-2017-148.jpg
                      My girlfriend bought a new car maybe two weeks ago, (She bought it in Ohio and drove it back) and yesterday she came home and said her windshield washers weren't working. I thought this was weird since the car is a 2016 with only 11k on it, so we went down to the parking garage to take a look and they're working again, we figured maybe she just didn't pull the lever correctly. Well this morning she was on her way to work, went to wash the windshield shortly after leaving the garage and the washers worked, but the fluid instantly froze on the windshield and she had to stop and scrape it off! Turns out the lines had frozen yesterday and then thawed when it was parked inside and we tested it. The car started life in SC, and it turns out the washer fluid tank is likely filled with "summer" washer fluid that has a much higher freezing point than what they sell here, so I'll be flushing it out and refilling tonight. Pro tip if you buy a new daily from somewhere with a warmer climate: flush your washer fluid before it gets cold!
                        I’ve heard stories of people buying CA cars in the winter and having them shipped to WI and they show up with the freeze plugs pushed out of the block
                          It took her two weeks to drive back from Ohio?  Talk about taking the back roads... Whew! Now that I got that out of the way, I had never heard of "summer" washer fluid.  That's really stupid.  I thought all washer fluid was the same, learn something new I guess!
                            Haha I wouldn't be surprised if there were some back roads on the way home! I'm guessing it just wasn't cold enough till this past week to actually freeze it. Maybe 'summer' is the wrong word, probably a different formula for warmer climates since it wouldn't need as much anti-freeze/alcohol/etc.
                            • stealthbimmerS
                              stealthbimmerS
                              stealthbimmer
                              Varying levels of alcohol to adjust the freezing temp. Places that never see -20 degree temps dont need windshield washer fluid that is good to said temp.
                              1997 328ic
                              • GB-335xiCoupeG
                                GB-335xiCoupeG
                                GB-335xiCoupe
                                That's why we drink a lot of alcohol up in Wisconsin, to keep our lines from freezing.
                                  Most cheap washer fluid is only good to 32 degrees F.
                                  It's always the cheapest, and right next to the stuff good for 0 degrees.
                                  Makes me wonder how many people this happens to, regardless of where the car comes from.
                                    Had this happen to me last year in my white 328i. Car came from Texas. Good times.
                                      I've got 6 gallons of the cheap stuff sitting in my garage that's supposed to be down to -20F and that's the all season formula.  I guess if a manufacturer can save a couple pennies by making a lesser product to sell in regions that don't require them to meet the same standards we need in the colder climates then that's what they'll do.  I guess I'd do the same thing.  I never thought the world of washer fluid would be so diverse!
                                        You can also use certain washer fluids as a “replacement”/alternative in methanol injection systems. It’s nice because It’s cheap and readily available. Some people even mix it with HEET and or dilute it with water.
                                          ^reasons why washer fluid is classified as a hazardous material for transportation haha
