  4. E30 M52
E30 M52
    For your health
      Chapter 15: The wild goose chase
      Cliff’s Notes: was running on 4 cylinders, determined 1 coil is bad and 1 injector was stuck. Injector un-stuck and now running on 5 cylinders until i get a new coil
      Kaiser is a good guy. He sent his ECU for me to try out. After plugging it in I expected to fire it up and hear all 6 cylinders running. But it still ran on 4.
      The last piece of the puzzle should be the injectors.
      The misfire was on cyl 2 and 3 so i moved those injectors to 1 and 4 and sure enough the misfire followed.
      I felt a bit ripped off since back in july when i bought the engine they were working fine and i had sent them off to be cleaned and tested by a reputable injector shop.
      I pulled the bad injectors out as well as 1 known good one for reference I checked the resistance. All were good at approximately 14 ohms.
      So i connected the injectors to a 12v power supply (jumper box) and checked for solenoid clicking.
      The good injector clicked, one of the “bad” injectors did not. I kept applying voltage and it suddenly started clicking. All 6 injectors were now clicking when manually applying power to them. So I put the injectors back in and expected to fire it up and hear all 6 cylinders.
      Nope.
      BUT WE UPGRADED TO RUNNING ON 5 CYLINDERS
      So i checked the remaining “bad” injector. Hmm it isnt bad at all. It ends up being a bad coilpack even though I bought all 6 brand new, Bremi brand (OEM). Moving it to other cylinders as well as a resistance test confirmed it was bad. It measures 40 ohms on the outer 2 pins when a good coil should be
      Now in hindsight it can see that the 2 dead cylinders were from 1 stuck injector and 1 bad coil instead of 2 bad injectors as originally thought.
      I just need to replace the coil and I should be in business
      5 out of 6 aint bad
        I've heard bremi coil packs can be duds from the factory, glad it's getting sorted out.
          Good to know its not just me. I dont have a lot of faith in the remaining 5 as a result
            I spent more time than most humans should researching brands and coil information. I hope the new coilpack has you running smoothly.
              Much better!
              All is now well in the world once again
              Gunmetalgrey sent some old coils with the parts I purchased from him and swapped out the one I tested that was bad
                Woot WOot!
                • JeffJ
                  JeffJ
                  Jeff
                  Nice! But where is the burnout video???
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    This^^^ Glad to see its alive and well!
                      Purrs like a kitten!
                      Glad it's firing on all cylinders!
                        Passenger side control arm is in, driveshaft is in with new hardware and new CSB, heat shields are in, car is on all fours
                        • stealthbimmerS
                          stealthbimmerS
                          stealthbimmer
                          Burnout video
                          1997 328ic
                            No brake master cylinder [emoji16]
                            I did order one today though.
                            • stealthbimmerS
                              stealthbimmerS
                              stealthbimmer
                              Cinder blocks in front of the front wheels.
                              1997 328ic
                              • JeffJ
                                JeffJ
                                Jeff
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                  All I see is excuses....
                                  Image result for gif excuses
                                    Thanks to stealthbimmer for the covers. There is some cosmoline action going on so I need to track down something to clean it up with.
                                      Mmmmm. Tidy.
                                      Throw the rest of the M3/318 wiring covers on and you've got a tasty looking bay sir!
                                        That looks great!!
                                          Still in awe that there are 24 valves under that hood😛
