  4. E30 M52
E30 M52
    You really took the wind out of my sails by posting the resistor value... Memorizing the resistor color code is one of the few skills I picked up at my last job.
    A resistor in series with the injectors would limit current through then circuit. It's a bit of a mystery to me why they would want to do that, but my guess is that the DC resistance of the injector when it's on might be too low for the driver circuit.
    Electrically, an injector is an inductive load. Inductance resists a change in current flow through a circuit. So, if you want to turn the current on and off very rapidly, you need to keep the inductance low. In practice, inductance, resistance and magnetic force are all related. So my guess is that to get a high enough magnetic force to open the valve of the injector (which has fuel pressure pushing it closed), and get the injector to open and close very quickly (which means changing the current flow very quickly), they had to lower the inductance (and in turn, the resistance) to a point where, when the injector is fully "on", the DC resistance is too low for the driver circuit.
    Kind of shooting from the hip here, but that's my best guess. Putting the resistor in the harness instead of the ECU means you can change the injectors after-the-fact without having to rev up the ECU, not to mention that it probably generates a fair amount of heat...
    Image result for mind blown gif
    At that, if you said the harness tested alright, and you check the injectors, I would say the ECU. I ran into a similar scenario and it was bad capacitors inside the ecu. Old aged  potting material seeping or cracking out would cause super random injector feed issues. Sometimes only under load.
      “Why do I need a compruter? What does a compruter look like? What does a compruter even do?
      I dunno
      Who cares?!?
      For your swap, ya dangus”
        I dunno
        Who cares?!?
        That was almost more hardest to read that of my post above yurs.
            For your health
              Chapter 15: The wild goose chase
              Cliff’s Notes: was running on 4 cylinders, determined 1 coil is bad and 1 injector was stuck. Injector un-stuck and now running on 5 cylinders until i get a new coil
              Kaiser is a good guy. He sent his ECU for me to try out. After plugging it in I expected to fire it up and hear all 6 cylinders running. But it still ran on 4.
              The last piece of the puzzle should be the injectors.
              The misfire was on cyl 2 and 3 so i moved those injectors to 1 and 4 and sure enough the misfire followed.
              I felt a bit ripped off since back in july when i bought the engine they were working fine and i had sent them off to be cleaned and tested by a reputable injector shop.
              I pulled the bad injectors out as well as 1 known good one for reference I checked the resistance. All were good at approximately 14 ohms.
              So i connected the injectors to a 12v power supply (jumper box) and checked for solenoid clicking.
              The good injector clicked, one of the “bad” injectors did not. I kept applying voltage and it suddenly started clicking. All 6 injectors were now clicking when manually applying power to them. So I put the injectors back in and expected to fire it up and hear all 6 cylinders.
              Nope.
              BUT WE UPGRADED TO RUNNING ON 5 CYLINDERS
              So i checked the remaining “bad” injector. Hmm it isnt bad at all. It ends up being a bad coilpack even though I bought all 6 brand new, Bremi brand (OEM). Moving it to other cylinders as well as a resistance test confirmed it was bad. It measures 40 ohms on the outer 2 pins when a good coil should be
              Now in hindsight it can see that the 2 dead cylinders were from 1 stuck injector and 1 bad coil instead of 2 bad injectors as originally thought.
              I just need to replace the coil and I should be in business
              5 out of 6 aint bad
                I've heard bremi coil packs can be duds from the factory, glad it's getting sorted out.
                  Good to know its not just me. I dont have a lot of faith in the remaining 5 as a result
                    I spent more time than most humans should researching brands and coil information. I hope the new coilpack has you running smoothly.
                      Much better!
                      All is now well in the world once again
                      Gunmetalgrey sent some old coils with the parts I purchased from him and swapped out the one I tested that was bad
                        Woot WOot!
                        • JeffJ
                          JeffJ
                          Jeff
                          Nice! But where is the burnout video???
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            This^^^ Glad to see its alive and well!
                              Purrs like a kitten!
                              Glad it's firing on all cylinders!
                                Passenger side control arm is in, driveshaft is in with new hardware and new CSB, heat shields are in, car is on all fours
                                • stealthbimmerS
                                  stealthbimmerS
                                  stealthbimmer
                                  Burnout video
                                  1997 328ic
                                    No brake master cylinder [emoji16]
                                    I did order one today though.
                                    • stealthbimmerS
                                      stealthbimmerS
                                      stealthbimmer
                                      Cinder blocks in front of the front wheels.
                                      1997 328ic
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                          All I see is excuses....
                                          Image result for gif excuses
