  4. Lifted E30 V2
Lifted E30 V2
    Got some stoof done this weekend!
    Converted the fuel system from feeding fuel to feeding diesel.
    I took the foam out of the bottom of the fuel cell, time will tell if that was a good move or not.
    There was a surprising amount of crap in the bottom of the cell, including some sort of mfg. leftovers!
    I enjoy the color of diesel
    Took out the fuel pump and such from the trunk, and it leaves me with a comically small amount of stuff.
    The weird part to me at this point is that there is no fuel pressure in any of the chassis lines anymore, only in the injector hard lines. It makes my life easier for sure!
    I re-timed the motor and fuel pump as I noticed when switching the timing belt that the crank was not at tdc when everything else was. Brett suggested leaving it that way for the first startup due to potential pump timing issues, and I cleaned up all timing elements.
    This is how you read the engine timing.
    It threads into the back of the pump, and you rotate the motor until you get the highest reading, zero the dial indicator, rotate to tdc again and measure the offset. The timing was a touch too aggressive so I brought it down a little bit, to what most people use as performance timing for the motor.
    Sadly the cam isn't in great shape, quite scored where it rides.
    I find the vacuum pump kind of cool, as it bolts up to the cam and rides on an extra lobe.
    A overall shot for you m20 guys.
    Also found that the starter and flywheel were not playing nice together!
    IMG20171201203022IMG20171201203011
    There was a lot of metal shavings on the bottom of the bell housing, but it looks like the problem resolved itself so I may just go with it.
    Starter doesn't show signs of wear.
    I guess I didn't take a picture, but I got the motor back in the car and have it all bolted up.
      Nice work, excited to see this beast rolling coal!
        strange how the M20  didnt come with bearing caps but the M21 did. I enjoy seeing the guts of this thing though, its so different than what most of us are used to
          Its so simple and mechanical. It seems to like its so easy to work on.
            It is pretty simple which is nice, but the whole thing wont work if there is air in the fuel system.
            It's been a messy process trying to get air out of everything, and I'm pretty sure I am not done working at that.
            I'm pretty sure I get to re-bleed the injector lines again, when I opened the back of the pump fuel came out and I doubt I cleared all the bubbles when I filled it.
            I hope to have it running in the car before the weekend!
              Thats awesome! Im excited to see videos of it running and driving!
                As promised, the installed picture. It looks odd for some reason. Maybe because everything looks old?
                Worked on the glow plug harness last night. I had been browsing the ETM and noticed that in the stock harness there was an 80a fuse for the plugs, and realized my wimpy 30a relay wasn't going to cut it. So I ordered this! Normal size relay for scale. (I know, not a banana...)
                I figured that, along with some 4ga cable running to the battery should do the trick.
                I took all of the individual wires (after stripping them out of the e28 harness) and ran them through the motor and then connected them all together to one terminal.
                I put the relay on the firewall for now, don't know if I will bother moving it because it's a decent spot to begin with.
                Wired up the solenoid for the relay and I was in business!
                Bolted the turbo down, which required taking the EGR valve back off (irritating process), and bolted up the feed and drain line for the turbo.
                I mocked up a quick exhaust by taking part of the old exhaust and welding two washers to it, I don't feel great about it, but I feel better about it than dying from the exhaust filling the cabin. The turbo outlet points straight at the wiring harness pass through on the passenger side, which I will need to plug, but for now the elbow took care of the major problem.
                As promised.
                I think I still have air in one injector line, so I'll have to bleed those again.
                I also don't know about the turbo, it has a tight spot when it spins, so something may have been actually messed up before rebuilding it, not sure if the shaft is too scored or something. There is a used turbo for it on ebay that was stated to have no shaft play so I may just buy that for $150.
                Next step is coming up with an alternator mount and getting a belt for it. The water pump (need a new one) is in a different spot from an m20 and results in a longer belt. The alternator "should" also be different, but I think I can make the m20 one work. The mounting for this stuff is all different.
                You can see that the alternator mounts into that slide bracket deal, and sits up higher.
                I'll likely slot a piece of metal and make it a manual adjustment, as the stock setup would require a new alternator (need to verify that) and waiting 6 weeks for the bracket to come from Germany (according to ECS).
                Overall last night was quite fruitful!
                  It looks like there is more room in front of the engine than with an M20
                    Partly true, partly a deceiving angle.
                    There is no distributor on the front of the engine so that helps.
                    The power steering pump sits almost in the core support, as I believe the M20 one does, so that area is all the same.
                    I thought I was getting away from this boost life, but that didn't work
                    I will need to stuff an intercooler, and oil cooler, and the radiator all in the front of the car again. But this time I have to be more careful with placement so things don't end up impaled!
                      That recess in the valve cover looks perfect for an air-water cooler
                      http://www.siliconeintakes.com/front-mount-intercooler/long-flow-style-water-to-air-intercooler-p-219.html
                      Long Flow Style Water to Air Intercooler
                        It sounds like a school bus and I love it. Glad to see you making quick progress on this swap.
                        I didn't think about carefully mounting the radiator, etc. Although it doesn't look like an intercooler came stock on these cars?
                          you also need something like this in your trunk
                          A Bush Winch. Something that would be fun to make out of a honda compact 4x100 spare wheel or something
                            I think it needs more roof rack and a shovel mount again. And top mount radiator/intercooler... like top of the car mount.
                              Roof rack and shovel will be added down the road! They did not come intercooled from factory
                              Those bush winches are sweet, I'll have to see what kind of spacing would work with the current wheels as the lugs sit fairly deep in there.
                              Just ordered a water pump. Oreilly auto never ceases to amaze. BMW pump was $175 and coming from overseas (5-8weeks), ECS had some weird brand for $65 with a week or so lead time, Oreilly will have one here Saturday for $37 and has a lifetime warranty.
                                Could it be the antenna coming from the valve cover that is giving it that odd look?
                                Man this this is moving along fast. I say shovel and possible roof tent! I mean this is basically an expedition machine now with a lift and diesel power.
                                Image result for roof tent
                                  Haha, all the cool kids are doing it!
                                  It's looking like I need an elbow connector to make the bend so I don't hit the hood, but that will be heading over to the brake booster.
                                  Roof tent is tricky, because I was hoping to get some bike mounts on the roof basket, so I would have to get creative on space.
                                  I was going to comment that it's been moving at a snails pace, but it has only been 2 weeks and a couple of days since I picked up the motor. Hoping to drive it this weekend! Even if it is only down the road and back!
                                    yeah thats not much of a snails pace. unless its this snail:
                                    Image result for turbo snail
                                      The lower hose from an E34(?) fits to a late model radiator!
                                      I need to trim it shorter than stock to get that little kink out of it, but it will work just fine.
                                      The upper hose will either be two stock hoses pieced together, one random find from the parts store, or a flex hose (last resort)
                                      I need to get an expansion tank for the drivers side as the old style expansion tank would get melted by the turbo. If anyone has one laying around I would certainly like to talk!
                                      Drove it about 3 feet last night, so that's a thing.
                                        Napa radiator hose #8484 for the top hose.
                                          I have a new Genuine late model expansion tank, never used. 85$ shipped.  FCPEuro price 105.09.
