  • stealthbimmerS
    stealthbimmerS
    stealthbimmer
    Needs horns
    1997 328ic
      stealthbimmer said:
      Needs horns
      Like so?
      Related image
      • stealthbimmerS
        stealthbimmerS
        stealthbimmer
        Well, if you are going that route...at least put them in front for some ramming protection
        I was thinking more, since you have the red theme, something like this
        https://www.amazon.com/Red-Devil-Horns-for-Cars/dp/B00IMM5R92
        You know, make em light up if you want to get all ridiculous with it.
        Or, since apparently 'tis the season already
        https://www.amazon.com/dp/B011XM9EKA/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B011XM9EKA&pd_rd_wg=dJhX5&pd_rd_r=ZX3MDVFBK11MRHMYYEP7&pd_rd_w=eGHnK
        1997 328ic
          HAHAHHHA I have never seen those little horns before. How silly. I would do that if I actually had legitimate plates on the car.
          Speaking of which, I applied for another set of hobbyist plates yesterday for this thing. So when they show up in January I can finally "LEGALLY" drive the car come February!
            Added some of the matte/ gloss vinyl and used the car to haul some wooden tire racks I built.
            Blew the PS line apart again. Of course it happened right when I got into the shop. ughhhhhhhhhhhh.
            Where can I go to get a custom line made? I really dont want to use AN fittings and this is super annoying. the place that I took this too makes HP hydro lines and they said this should hold 1000 PSI. LIESSSSSSS
              I will ask around at work tomorrow. Pretty sure I remember someone talking about a local place that does custom hydraulic hoses cheap.
                Please do!!!!.
                I know that most auto parts stores have a press that can make them behind the counter, but this line they were unable to make. Once I get it out of the car I will post a picture of the actual line. Its half OEM Ford and half OEM BMW.
                  The guy at Hyquip said it should be good for up to 3000psi, I don't know if I believe him, but it certainly was a bitch to get on like all push-lok lines.
                  Well I guess he was wayyy off. 😒
                    Please do!!!!.
                    No one knew what I was talking about, so I must have made the whole thing up. Only suggestions I got were to check the farm equipment/bobcat places. Maybe call one of the equipment rental places and ask them where they go for stuff like that?
                      Yeah. So since I am located on the outskirts of Madison surrounded by farms, the auto parts store by me makes hydro lines, but could not make the line I need. They suggested Hyquip, which was a good suggestion, but they couldn't make it either. Instead they suggested doing what I did, and sold me some fittings, but it still continues to fail. 😕
                      • The Full BananaT
                        The Full BananaT
                        The Full Banana
                        I've gone both routes before with success either way. I can see the fittings failing if they are the standard sort of AN fitting, but proper high pressure reusable PS fittings have worked really well for me. I bought high pressure power steering fittings and hose on ebay and made my own line on my first swap (which I put about 13,000 miles on). The second time around I went to Hyquip on 124th in Butler and had them make a similar line, but with crimp fittings, while I waited (and that one has 3,000 miles or so on it now). Why wouldn't Hyquip do it?
                          Its because of the type of fittings I assume? Hyquip in Madison didn't stock anything in the sizes I needed. Maybe I will look online to make my own. I also have a really low non-existent budget, so at this point I might just spend the money on AN fittings and line so I never have to touch it again. Spending 20 mins cleaning a huge mess on the floor gets old FAST.
                          • TkuhnT
                            TkuhnT
                            Tkuhn
                            Message chase bays, they make custom lines as well as pre made kits for some stuff. Unfortunately they usually take awhile but the products are so good lol
                              Ehhhh. Thanks for the suggestion, but not worth it. I dont have anything against chase bays but I rather do it locally, not spend what they would charge, and risk errors and deal with waiting and shipping it back etc.
                              Parker might be able to make it, im going to try there next. I wasn't aware until last night there there was a Parker store a few blocks from Hyquip. Weird they didnt send me there. 😆
                                Pirtek in Menominee falls will be able to do it. I'm 85.3% sure I have the crimping tool for hydraulic lines I can check if you want to make it yourself.
                                  Where were all of you guys with suggestions months ago why I was struggling to make the first hose? Please look that would make my life easier.
                                  • TkuhnT
                                    TkuhnT
                                    Tkuhn
                                    Fair enough haha. Yea there's one on silver spring tucked back in a strip mall.
                                      Just got back from the parker store. Super nice guy, gave me the fittings I need and hose for free (for now). I have to measure for a perfect fit, and come back so he can crimp it together and make the perfect line. It was slightly tricky for him too because one end is american and the other is metric.
                                        Got the line back in last night and re-bled the brakes. I didn't drive it though because I was too lazy to unload the 3 sets of wheels on the roof.
                                        I will say that the hydro line that I had made turned out so awesome that I was so excited to install it that I forgot to take pictures. 😦 Im sure no one will be interested in what a $113 high pressure power steering line looks like anyways. On a side note, that is also probably the most I have spent on 1 single part on this car.
                                        Pics I do have:
                                        The orange tape was for the length mock-up, a different type of hose was actually used. The metal portion under the tape (as seen in the first picture) was compressed with a special press to hold the line into the fittings on both ends and complete the process.
                                          I drove this to work a few days ago because my civic decided to toss an axle about. I realized some more things I need to address.
                                          1. The heat doesnt work for shit.
                                          2. The rear end has a bad bushing or something somewhere as it tosses itself about over larger bumps and cracks in the road
                                          3. The seat belts still dont work well, I need to get a harness bar and install the harnesses.
