  4. chit chat thread
chit chat thread
  • GB-335xiCoupeG
    GB-335xiCoupeG
    GB-335xiCoupe
    To my knowledge the N52b30 is pretty stout.  I am pretty sure that does use the electric water pump which is a known failure but you don't necessarily replace that as preventative maintenance.
    Not as preventative maint, but I might suggest buying a spare of said water pump, and keeping it in the original box in the trunk. Look at ecstuning.com, print it out and then go to the BMW dealership and ask them to match the price.
    • JeffJ
      JeffJ
      Jeff
      Well that’s good news at least.
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
      • JeffJ
        JeffJ
        Jeff
        Alright I want to change fluids in the X5 and I have got to the power steering fluid
        In the manual it says CHF 11s
        The bottle on the car says ATF oil (assuming dextron III)?
        1 dealer says CHF 11s
        Another dealer says ATF oil and it must be plain ATF? Not really sure what that is.
        Napa says CHF 11s
        What fluid goes in?
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          What color is thr cap on the resevoir? @Jeff
          • JeffJ
            JeffJ
            Jeff
            The cap is black and does not say anything
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              Well that doesnt help lol.  Usually there's a sticker ring on it and depending on the color determines the fluid.  Basically, if you have dynamic drive it takes the chf-11 and if it doesn't then it takes ATF.  Run the vin if you aren't sure.
              • JeffJ
                JeffJ
                Jeff
                Alright concours bmw milwaukee has told me no adaptive drive and does not know what fluid. Fluid in the bottle is yellowish brown tinted
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                • stealthbimmerS
                  stealthbimmerS
                  stealthbimmer
                  Jeff said:
                  What fluid goes in?
                  Canola oil
                  1997 328ic
                  • GB-335xiCoupeG
                    GB-335xiCoupeG
                    GB-335xiCoupe
                    stealthbimmer said:
                    Canola oil
                    Extra Virgin Olive Oil, or KY - whichever you have more of. Stick your finger in there and taste it.
                    Seriously, I'd call BMW NA
                    I didn't read this in detail, but it might be helpful for you:
                    http://www.e90post.com/forums/showthread.php?t=711272
                      If it doesn't have dynamic drive then it should be ATF which shouldn't be brownish yellowish obviously. The chf-11 is that color so I'd have to go with chf-11.
                      • JeffJ
                        JeffJ
                        Jeff
                        If the car took ATF fluid and I flushed it out with chf11s would that be a potential problem?
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          It could be but to be honest im not sure how different the properties of each fluid are to say if damage would be done to seals and other components.  They're both common hydraulic fluids in othet applications.  Its not like the difference between brake fluid and atf for example but I can't say with certainty if they're interchangeable if flushed.
                          • JeffJ
                            JeffJ
                            Jeff
                            My wife sent me this picture when I was on my way to the dmv. Some of you may find this funny
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                              I saw this, since I have kids I know what movie it's from, absolutely hilarious.
                                Getting there. Waiting in centrifugal clutch and seat to come this week. Then it's just figuring out throttle and brake.bc90c019f2f9b2c9d8ec7b90c17a8d72.jpg
                                  @GunMetalGrey Maybe the shike and 420 should be combined?
                                  How much did the axle/bearing/sprocket/wheel/tire setup set you back?
                                    It was a few hundred for the rear axle kit. It's really the only large expense I've had so far tho.
                                      I would think not a big deal, the only problems I have read about are people putting ATF in cars with a central hydraulic system supposed to have CHF 11 and then the leveling suspension starts leaking.  That was on an old 7 series though.
                                        I worked on a friends new to him 2012 Cooper S this past Saturday.  I installed a dp, cai and tune.  It's the first modded cooper S I have driven and it was a blast!  I've always loved the stock Cooper S but with a little more power this thing is a blast!  It does remind me why I hate adding power to FWD though.  No traction and torque steer for days.  It's a great daily and he's using it to commute from Whitewater to Milwaukee right now.
                                        Funny side story, he informed me that he'd have to start shipping parts to my house because his fiance got mad at the number of parts showing up to their house within a week of owning the car.  He had parts at the house before he had possession of the car... can't say I haven't done that!
                                          The struggle is real
