  4. '88 E30
'88 E30
savebigmoney
    Rattling is normal after sitting for a long time.  Hold the rpms around 3k for a little while and it will pump the lifters back up.  Almost ready for burnouts/axle breakage!
    For sure!
    Different angle
    • i_love_carsI
      i_love_carsI
      i_love_cars
      yes, i demand many burnouts and axle breakage ! A lot of 'yes' right here. Love the sound of the motor firing up
      2007 Z4MR
      2003 E39 M5
      2002 E46 M3
      2021 X5 40i
        Woohoo! That must have felt good!
        For temp sensors, make sure the connector with only one contact in it is on the brown temp sensor (or single pin, they are sometimes clear).
        I'm stoked to see more of this!
        They both have 2 contacts
          Swapped connectors. Gauge doesn’t jump full hot when I turn the key on now. Should be good.
          FYI, both e36 obd1 harnesses I have indeed are two pin connections for the temp sensors. Only 1 pin sensor I can find that is close (distance wise) would be for the oil pressure switch.
          (Manifold temp sensor may also be 1 pin as well - but I ruled this out because the length of the harness is a dead give away to where it connects to)
            Awesome!  I can't wait for a ride!
              (Manifold temp sensor may also be 1 pin as well - but I ruled this out because the length of the harness is a dead five away to where it connects to)
              Awesome that this thing is so close!
              I know that the way I have my car set up is one connection is for the gauge, the other is for the ecu readout, and if you flip them, the guage would pin itself. Same with my E24, but that has one single pin, and a double pin. I have had the luxury of finding this out with both cars. lol
                Bleeding coolant tonight, also will try and get the head “bled” tonight as well at the same time, it was loud on startup
                  Rumor has it that burnouts (with videos) actually clear this up the quickest.
                  • JeffJ
                    JeffJ
                    Jeff
                    Is like to 2nd this
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      First and last drive of 2017 happened today.
                      Until next spring!
                      • JeffJ
                        JeffJ
                        Jeff
                        Until next spring!
                        How fast where you going when the hood came off???
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          Well, MS3 Pro is on the way.
                          Never really liked the idea of the chiptune and no datalogging capability.
                          Thankfully the turbo Miata has been a good learning experience
                            I have spent a few hours already looking at piggybacks, emulators, and logging systems for OBD1. There just isnt a proper tuning solution that doesn’t involve guess and check.
                            Nothing will run a stock-ish engine better than a stock DME, but a completely different EMS like megasquirt is really the only solution if you want it dialed in 100%
                            Logs are awesome
                              Showed up, now it’s time to get a not crappy laptop and get everything ready to go
                                YESSSSSSSSS.
                                  Picked up some scaffolding from MN this morning40834d4ce12f1834a449c261e6032e5b.jpg
                                  Before install I will fog it black
                                    Image result for jungle gym
                                      Lovely engagement photo, Mr and Mrs Kaiser!
                                        Drove it home from storage today
                                        Promptly folded the mirrors
                                        See you fuckers in 2019
