E21 Project Thread - Part 2
Something came in the mail today
She's alive! But of course where there's ups, there's downs. After firing it up, i noticed a huge fuel leak up in engine bay. I shut it down immediately. Garage floor is covered in fuel and the garage smells horrible. I will need another set of eyes to determine where the leak is. For now I have oil dri on the floor and a box fan running. I will let it dry out/evaporate and hopefully the fumes go away too. Then I will diagnose the leak tonight or tomorrow.
I can't see said video
So Brian and I determined the leak to be the hose clamp on the fuel rail supply line. It's digging into the hose and not clamping it securely. I have the leak at the stupid fitting adapter where the hose meets the hard line, so I'll knock out 2 birds with 1 stone and fix both right away.
I have decided to overhaul the (almost) entire fuel delivery system. I have been wanting to get rid of the fuel accumulator that the oem kjet fuel system uses, but is not necessary for EFI and with the fuel hard lines looking a little crusty, now is the time. Here is what I will be replacing..
Remove bosch motorsports external fuel pump and replace with Walbro 255 external pump (ordered).
Remove e21 fuel filter (banjo fittings) and replace with e30 fuel filter (barb fittings).
Remove e21 fuel accumulator, not needed anymore.
Remove crusty fuel hard lines from tank to engine bay and replace with new hard lines. Got a quote from Blunttech for $105 shipped from germany for OEM prebent lines. I will be checking out the napa easy bend lines when I pick up the fuel filter and make my decision then.
Replace fuel hoses and clamps from hard lines to fuel rail and fpr with new.
Had to drop the tanks to completely remove the fuel lines. What a bitch!
I decided to order prebent lines from Germany through blunttech. Going to need a few new mounting clips as well.
Didn't know prebent lines were available for our cars! I searched on a few sites too but not blunts I guess
I've always just messaged blunt and he takes care of the rest. He has found me parts in the past that other places said were unavailable.
Not upgrading to 3/8" lines?
I doubt bigger lines will ever be needed for the power levels I will be at. But please do explain your thought.
Yay!!! Fuel lines and mounting clips showed up today from Germany
I usually buy mine in packs of 100 at menards
I’m talking about zipties Dave
Zipties
Dave
Fucking cheap ass bender kinked the supply line while trying to copy the old one. Now what to do, what to do...
