  4. '88 E30
'88 E30
savebigmoney
    Bassboy3313 said:
    Where do you purchase said wrap?
    Amazon!
    This is the stuff. They have lots of different sizes and lengths.
    https://www.amazon.com/gp/aw/d/B00ZASCTHE/ref=yo_ii_img?ie=UTF8&psc=1
      Sweet! I'll have to remember that when/if I need to redo anything down the road
        Pegasus has it as well. Different diameters (ranging from 1/8" - 1" ) and you buy it by the foot. Self wrapping split braided sleeve.
          AMAZON PRIME!!!!!
          But if there’s a local option I’d jump all over it haha
            so are fender mods/wider wheels coming before or after the first startup?
              I should probably do that eventually
                FYI: not sure what you're planning, but fender mods are a PITA, unless you don't care what it looks like i guess...
                  It's a lot easier when you're just hacking out the fender lip to attach flares that will ultimately cover up your cut job anyways. 😁
                    We will see if more tire is even needed
                      In the rear the inner fenderwell should still be reattached to the quarterpanel to maintain the structure of the car in that area. It's difficult to work in there with the suspension still on the car, so... I stand by my original statement, but yeah...
                      How does one determine when one needs more tire though...?
                        Bassboy3313 said:
                        It's a lot easier when you're just hacking out the fender lip to attach flares that will ultimately cover up your cut job anyways. [emoji3]
                        Cutting it up is last resort type stuff. I would love to shoehorn 245s under the car but I’m not sure that’s doable on a stock fender. Would probably end up settling for 225s on an 8-8.5
                        I have faith in the 205 re71rs for now haha
                          The correct answer is:
                          When you can go WOT and add some steering angle without having a brown pants day
                            Did some more smash bros on the headers 2a647dcd93064245ed243751d773800f.jpg
                            Also slapped in the vac distribution block
                            And added some more drainage capability in the e34 dipstick5ac9df7bb1e4f9fbb11fd7f22a6cc282.jpg
                            3 smaller holes instead of one larger one (tube in background is an OBD2 dipstick that was modified to work as a drain)
                              Awesome. More progress!!
                                All the brake lines are in and routed & fluid was added to the reservoir last night. Dipstick was also permanently reinstalled with a healthy dose of RTV.
                                I need to buy fuel injection hose for the rail & make a mount for the pusher fan and then stuff can get bolted back together I think
                                  So I didn’t take any pictures at all because I completely forgot, but i took one at the end 9ff981d1e260283d783bf677ba3eab6f.jpg
                                  I reeeeeally hope nothing leaks.
                                  Basically it’s down to plopping in the radiator, adding fluids and getting the back of the sc to connect to the throttle body, run some vac line, finish the gauge wiring, put in new injectors, add the exhaust, mount a fan, bleed brakes/clutch/coolant, bolt up other randomness & figure out seatbelts
                                  If I can do that all during the week I mayyyyy have this done for next weekend (doubt it)
                                    Wowza! Sounds promising.
                                      Got some more done last night. Finalized the fan bracket (stock e36 AC condenser fan). Just simple flaststock with some hardware. Not crazy cool but will get the job done and make it so I don’t have to destroy my radiator with those ziptie-Ish fan things. 6246b735de03c468a1b94e15e56aa0b1.jpg
                                      I cleaned it up and sprayed it black
                                      Sits about 1/4” away from the radiator, should work well enough.
                                      Got the rad hoses in and trimmed. Remember the top hose I just took a stock e36 hose, swapped ends and trimmed some fat. Fits like a glove f80f65df2b377fadaf7ecddd42e89f09.jpg544af28c4a2d95aec6a7094992f62d31.jpg bottom is a stock e36 silicone one trimmed up to work in the e30
                                      7b3c82d768e8b0aa211c7bd0231eaa89.jpgfinger width in between the top of the belt and the bottom of the coolant hose. Hopefully that’s enough haha.
                                      My belt routing is a tad different, so it take a different angle on the PS pump. Had to ditch the lock washer and sand down the head of the bolt for some belt clearance. When I turned it over by hand before, it walked the belt one rib because it made contact.
                                      036231335bab4fb7e8125ffc2cc9eb3c.jpg Intake tube routing is finalized & tightened. Ordered a new filter at lunch that’s a bit smaller so it can work in the spot I need it to.
                                      Also ordered a patch kit for this, VF wanted $225 for a replacement piece. I’m going to try some 3M stuff for the hell of it and see if it’ll work. Kind of bummed I have to use it, but the lack of room wouldn’t let me use my other coupler I had made. Oh well, so is the life of a project car.
                                      Belt I ended up with for future reference
                                      I hope someone finds any of this info useful, but no one really supercharges a 24v anymore, let alone in an e30 haha.
                                        I always enjoy these updates! Especially as you get closer to finishing it!
                                        As for your last statement, it has been something I've been thinking about doing for awhile!
                                        Keep it coming, looks like you're real close!
                                          Sanding down the bolt head for added clearance...nicely done!
