E30 M52
Stripped 6 or so with a small beam type torque wrench, went out and bought this Husky click style specifically so that the torque value I need lands right in the middle of the range and includes a calibration certificate.
The other 4 or 5 have been stripped with the new wrench
Out of curiosity, do you have the correct torque value? I have heard that sometimes the bentley/hanes/etc can be off at times
He's right. I checked it against BMW's repair procedures.
Attempt number 6382:
Started torquing intake cam.
Stripped a thread.
(Serenity now!)
Didn't rage.
Repaired stripped thread.
Started torquing cam again and....
1 cam successfully torqued!!!!
Holy crap!!!!!!!!!! How about the other one........
http://www.romraider.com/forum/viewforum.php?f=42
Just learned about the Siemens MS41 Tuning in a E28 swap thread, what is your plan for engine management this time?
New woodruff keys installed on the crankshaft.
Originally I went to grab some keys from ECS Tuning but its $65 for a bayg ('sconsin accent in full effect) of 50 keys. Nah. I got a few from McBastard and when they arrived I gave it ye olde redneck Brinell hardness test with a file and sure enough, unhardened, very soft actually. Soft keys will quickly make for sloppy keyways which cause higher impact loads on the keys than normal which causes them to shear and jump timing and lose oil pressure and the end the end the end.
Dont use un-hardened keys for a critical (timing/high torque) application!
Front timing cover installed with BMW gaskets and black RTV. Hardware torqued to 10 nootonmeaters. Front main seal installed.
so then this will obviously be ready for the fall cruise.
VANOS sprocket wrench arrived today.
-New chain tensioners and guides installed.
-Cams timed.
-VANOS installed
-Timing verified with 2 revolutions
-Water pump installed
-Thermostat installed
-CSB replaced on driveshaft
-updated hydraulic belt tensioner and new idlers installed
I lost (or never ordered) the gasket for the rear main seal so that will be the next step, then i can install the oil pan, flywheel, clutch and trans.
