    Looking forward to meeting the beast next month
      That tach is so cool! Glad you ended up using it
      • AlpineE30A
        AlpineE30A
        AlpineE30
        Man I just went through this whole thread. SO BADASS.
          Good! I cant wait either, the Devils Drive will be awesome.
          Yeah its really sweet. I wasnt going to use it if it was collectible, but its turns out its really not and you can still buy them new. I have an install video thats hilarious. Alcohol and a 4" hole saw straight to the gauge cluster is always a good time.
          http://www.ebay.com/itm/Vintage-60s-Sun-Super-Tach-10-000-RPM-used-untested/272825393516?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3De3b7b60e44414ac8a04aa062973b9851%26pid%3D100338%26rk%3D4%26rkt%3D30%26sd%3D112544422992&_trksid=p2141725.c100338.m3726
          HA! Glad you are digging it. Thanks man!
            so when is the Paxton happening?
              I live under a rock. Can you explain?
                Paxton is a brand of supercharger developed by Bill Paxton of "Twister" cinema fame.
                The knowledge he gained from studying cyclones for his movie role combined with the successful deployment of the Dorothy measurement probes into the eye of an F5 tornado provided him with enough data to eventually pursue the development of the Paxton line of superchargers.
                  "Paxton is a brand of supercharger"
                  I like that out of everything you wrote, only about 6 words in the first sentence were true.
                    Did some thangs.
                    Tried to do burnouts in the shop, failed because the floor is too slick. (see videos)
                    • Doing so I also mashed the brakes and discovered that the brake fluid reservoir was leaking allowing air into the lines. Good and easy fix even though I need to add the handbrake.
                    I also bought some wheel spacers and a Renown steering wheel from Earl.
                    • Spacers worked great
                    • Steering wheel needs to be closer to me yet
                    IMG_4453.mov
                    IMG_4452.mov
                    Anyone know where I can get lexan windows, or if I will make it past tech inspection with that smashed window??
                    • IMG_4453.mov
                    • IMG_4452.mov
                      Condor Speed Shop sells them
                        https://www.condorspeedshop.com/collections/e36-suspension/products/copy-of-e36-polycarbonate-door-window-kit?variant=1113573553
                        https://www.condorspeedshop.com/collections/e36-suspension/products/polycarbonate-rear-side-window-kit-e36-coupe?variant=16880662657
                          You'll get through tech with a crack but I'm not sure about that mess. Depends on the organization.
                            "That Mess" is from a well placed hood without hood struts prior to my ownership. I figured most places dont care because drift cars get smashed, but you never know.
                            Also- condor only sells side windows.  I am looking for front and rear Lexan. Probably making it myself...http://targamiata.com/tags.php?tag=lexan window
                              why on earth would you do a lexan windshield? buy a used windshield for $100. a sheet of lexan probably costs the same.  save yourself the time and possible throat slashing in an accident.
                                Throat slashing? You have no trust in polycarbonate?
                                If you know of, or have some guidance on a new window, help me out!
                                  yeah, poly is stronger than glass, but, when it breaks you get shards. maybe the break threshold is so high that an accident that bad would kill you anyways, but i'm not an expert so I'd err on 'better not find out.'
                                  https://milwaukee.craigslist.org/pts/d/e36-325is-part-out/6272159242.html
                                    Windows cracked on that one.
                                      wait, what?
                                      Windshields are usually a structural part of the car and it's generally a Bad Idea™ to replace them with plastic if you're not going to cage the car.
                                        wait, what?
                                        This is a fact. Good point.
                                        I just need something that is not cracked and I was thinking of something I could cheaply do myself. I wonder how much I can get a window installed for?
                                          Also, remember that I still plan on putting bars over the windows.....
