  4. New ride
New ride
162 Posts 20 Posters 3.0k Views 1 Watching
    Welcome!!!
      Oh... sorry wrong thread.
      • IceddragonI
        IceddragonI
        Iceddragon
        Got it all cleaned up today, paint shined up well. The engine bay was a complete mess, dirt caked everywhere, but even that cleaned up really well. Next thing is cleaning these wheels up if I can, but its caked on pretty good. Also the tires are super cheap general tires, so maybe I'll just run these through the fall and shop for new wheels over winter and next spring, we'll see.
        Also gaining confidence in the third pedal and let myself do a decent pull down an on-ramp, and damn the power is fun.
        • IceddragonI
          IceddragonI
          Iceddragon
          Oh I also found the manual in the glovebox, and that contained the best sight known to any BMW buyer, a treasure of maintenance records!
          Nothing exciting, just HPFP and some work on the front brake rotors around 40k miles.
            Looking good! Those are my favorite OEM 335i wheels.
            Nice to see that the HPFP was done. Plugs are never a bad idea. Coils are probably fine if you're not having any misfires or stumbles. If you are, replace them and take a look at the injectors. Turbos or injectors could be the cause of your startup smoke. Keep an eye on your oil filter housing, if you notice leaking or seeping, those gaskets should be replaced. Do you hear any wastegate rattle on decel?
              Congrats on the purchase! Agreed that these are the coolest e90 wheels.
                Nice! congrats on your buy!
                • IceddragonI
                  IceddragonI
                  Iceddragon
                  No misfires, only one bad thing that happened bad so far; I was leaving a toll booth on the way home and bounced it off the rev limiter (accidentally, forgot to move foot off the go pedal), car immediately went into reduced power mode. Stopped 2 miles later and turned it off, sat for 5 minutes and turned it back on again and everything was back to normal. I guess that could have been from a misfire but idk.
                  I'll keep an eye on the smoking, and I did make an appointment with my local shop to have him do an oil change and check for leaks or anything else that needs attention. I won't be surprised if the gaskets are due.
                  I don't hear any rattle, but would I know it if I hear it? Is it an obvious noise? Keep in mind I've never owned a turbo or a manual car before, so it makes loads of new sounds to me.
                    It sounds like someone is spinning a ratchet under your hood and yes, it's loud.  For limp home mode all you have to do is turn it off then back on and the car will be fine unless something is seriously wrong, in which case you'll turn it off then wait an hour or so for the tow truck to show up.
                    Is your mechanic familiar with n54's at all?
                      Pat did a pretty good job of describing it. You can hear it while driving with just the passenger window down while decelerating next to a curb or wall on that side of the car. Keep the music off. Otherwise you can free-rev it in the driveway and listen for a fast metallic clicking noise on the way down. When I bought my car I thought it was a rattling heat shield.
                      I've put my car into limp mode many times. It always fixes itself if you turn it off and back on again. The one time it was still missing after restarting it was when my motor was shot.
                      • IceddragonI
                        IceddragonI
                        Iceddragon
                        Okay yeah, definitely haven't heard anything like that in the car. I thought I heard something like it the second time I fired it up but it must have been something else.
                        And yeah, I spoke to him about working on these cars specifically before I picked one up, knowing I won't be able to do a lot of this work myself. He's an old BMW guy and actually worked with my last mechanic who worked on german cars almost exclusively, specifically Audi and BMW, for over 30 years. I trust him and he seems like generally a nice guy, they've treated me well on everything else I've done through them including the wheels and water pump on the last car. He likes 335s and thinks they aren't that bad to work on.
                        That's good to know, I'm glad the car is smart enough to protect itself from my screw-ups. I'll definitely keep an ear out for that noise, but is that something to worry about if the rattle does start? I've heard mixed things about it, from needing new turbos to some people saying its completely normal. And apparently MHD can keep them quiet, is that legit? I don't want to tune it until I get more comfortable with what I have now.
                        I'll also be bringing it to the car show in Eau Claire this weekend if anyone is out that way and wants to come see it, should be hanging out with some friends up there all weekend.
                          MHD only hides a problem by holding the wastegate open to prevent rattle. The only fix is replacing the turbos. You can also run this band aid on a 0 map I believe so it's a stock tune but really, who the fuck wants a stock tune?  The problem only becomes exacerbated when you start modding.  I was lucky enough to get my turbos under warranty immediately after buying the car. Welcome to n54 ownership!
                          • IceddragonI
                            IceddragonI
                            Iceddragon
                            That sounds expensive...
                            I guess we'll find out soon enough, fingers crossed. I'd rather not worry about it too much for now, cold air is coming and I want to enjoy it a little first.
                              In my opinion, it's only annoying. If your turbos struggle to hit target boost and start throwing 30FF codes, then it becomes a problem.
                              For what it's worth, my 135i had no problem peaking at 22psi and making 450whp with turbos that rattled like a son of a bitch. They didn't smoke or anything, but had horrible wastegate rattle. You can tune it out with settings in JB4 and/or MHD. I used JB4 to mask the rattle and still made gobs of power.
                              Enjoy the car!
                              • IceddragonI
                                IceddragonI
                                Iceddragon
                                Enjoy the car!
                                Thanks man, I needed that haha
                                  Just turn up the volume, problem solved. 😛
                                  • IceddragonI
                                    IceddragonI
                                    Iceddragon
                                    Experienced a couple of firsts in the car this weekend.
                                    Heard my first wastegate rattle while leaving the hotel, which I'm assuming stemmed from not letting things cool off properly after beating on it a little. It never came back the rest of the weekend but at least I know what it sounds like now.
                                    I also did my first race. A friend of mine owns an 07 300 SRT8 and we've been talking about running it against whatever I buy for a while now, so that finally happened. I should have beat him in a 20 roll but I hesitated going into third, just inexperience on my part. We both agree that I should have won with a better driver, but I'm extremely impressed that it performed that well. I'm still completely stock so he has at least 100 hp on me...
                                      I saw your car at the show this weekend I was going to leave a wibimmers sticker but dumbass me left it at home.
                                      • IceddragonI
                                        IceddragonI
                                        Iceddragon
                                        haha, I'll get one at the october cruise
                                          Wastegate rattle won't have anything to do with you not letting things cool off. However, wastegate rattle is most prominent on cold starts.
                                          Get JB4 or MHD, you'll thank me later.
