  4. Calling all M54 gurus! HELP!
m54smokee46m54b30
30 Posts 7 Posters 642 Views 1 Watching
  • JeffJ
    JeffJ
    Jeff
    Can you post pictures of plugs also a video of the smoke would be helpful.
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
    • ThatRatRodProjectT
      ThatRatRodProjectT
      ThatRatRodProject
      Tkuhn said:
      ThatRatRodProject said:
      The m54 is know to burn oil.
      That's what I have been told and read, but again oil consumption is one thing. The billowing clouds are another I would think.
      As far as I'm aware Oil consumption is mostly caused by burning oil where else is it going to go.
      • TkuhnT
        TkuhnT
        Tkuhn
        I will try to get the video up after work along with some photos of the plugs!
        • TkuhnT
          TkuhnT
          Tkuhn
          I believe you took that wrong. Yes oil consumption is caused by burning oil, I think we all can understand that. But when it comes to excessive smoke out the exhaust it's more than a standard "oil consumption" issue and all I was looking for was some people with experience beyond knowing that there are oil consumption issues with the m54. I appreciate the specs but this issue is more than reading the manual.
          • TkuhnT
            TkuhnT
            Tkuhn
            Brave soul performing a compression test and posting it here. There's been bad juju all here regarding compression tests lately haha
            I wasn't aware buttt I suppose if a person believes in that time will tell haha
              I know it is a different engine but just for comparison.  My m50 smokes a little, Pretty sure it is ring blowby in my case because it smokes most under WOT.  The m50 has no catch can/ oil separator, it just goes from the valve cover to the intake manifold (stock) and the baffling in the valve cover is not good enough to keep oil from going with the air.  It has 275k on it so I don't feel it's abnormal.  It doesn't hang in the air like a diesel but it is a visible smoke on startup and when romping on it.  I don't keep great records but I think I add a quart every 1000-1500 miles, some is due to leaks though.
              Compare to a 2 stroke engine.  Assuming 25mpg, 1k miles is 40 gallons of fuel, mixed 50:1 that is 3.2 quarts of oil per 1k miles.  You aren't near that much so I wouldn't think it would cause plug fouling problems.  A little lube for the cylinders is good anyway.
              How's that for redneck engineering?
                how many tanks of fuel have run through the engine?
                  At 25mpg about 11000 gallons.
                  687.5 tanks at 16 gallons/tank, I think it is actually a little bigger than that.
                  • TkuhnT
                    TkuhnT
                    Tkuhn
                    Since this started about 2 tanks. One of which was under heavy abuse.
                    • TkuhnT
                      TkuhnT
                      Tkuhn
                      Hahaha I don't disagree there, but to me it's abnormal for alot hanging smoke to be in the air after start up and at idle and when blipping the throttle. I went through a quart in one tank of gas, so something has to be wrong. After a good compression test result im leaning toward valve seals.
                      • TkuhnT
                        TkuhnT
                        Tkuhn
                        NOTE: while the car was running I removed the oil cap and got the hissing noise as I removed it. Meaning the crank case is under a fair amount of pressure. From research this means the CCV failed, but I have no CCV. Thoughts on that?
                        • JeffJ
                          JeffJ
                          Jeff
                          I would be checking to see if you have any broken ccv hoses first.
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                          • TkuhnT
                            TkuhnT
                            Tkuhn
                            Jeff said:
                            The CCV is deleted with a sealed system catch can set up, description is in original post
                            • JeffJ
                              JeffJ
                              Jeff
                              How are you pulling ccv gases??
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                You shouldn't have a dead end system, it needs to vent somewhere. Preferably into the intake. A quart per tank of gas is a lot. The crankcase should ideally have a vacuum when idling from the intake sucking from it. At minimum it should vent through a catch can to atmosphere.
                                  Quick hook up a vac gauge and see what it pulls at idle
                                  • TkuhnT
                                    TkuhnT
                                    Tkuhn
                                    The system was described in the original post. The valve cover goes to the catch can. Then the other input on the catch can runs to the 2 ports on the intake. The oil drain is plugged.
                                    Also JC,that's what I was saying. The amount of smoke coming from the exhaust is not by any means a "natural" amount. I'm not new to engines or building them even, just made this post incase I was missing something I may not know about with all the accessories on these engines.
                                    I planned to once I can get down to the garage
                                      I read that wrong sorry. Seems like it is hooked up right. Maybe pull the line off the valve cover with the engine running and see if it is sucking a decent volume. Maybe something is plugged up in the hoses or can itself?
                                      • TkuhnT
                                        TkuhnT
                                        Tkuhn
                                        Pulled the valve cover line and tested the vacuum on the VC - zero in.hg. and tested the vacuum on the hose going into the VC (so measuring through the can and into the intake manifold) got a reading of 18in.hg. Which to my knowledge is good vacuum. There's none of the white gunk or buildup in the hoses or the can. The can didn't have much in it (definatly not enough to be sucked back into the manifold by the vacuum).
                                        • TkuhnT
                                          TkuhnT
                                          Tkuhn
                                          Heres a start up video, hopefully it loads and plays. This is my first time uploading a video to the forum.
                                          cold_start_up__possible_valve.seals-
                                          • cold_start_up__possible_valve.seals-
