  4. Calling all M54 gurus! HELP!
m54smokee46m54b30
30 Posts 7 Posters 644 Views 1 Watching
    Tkuhn said:
    Interesting, so even though the catch can is keeping the system sealed and not venting to atmosphere it could still effect it?
    Oh, I stopped reading that sentence early lol.
    I know that they tend to burn oil, and my dad has a 330 that has been burning oil for quite some time so it seems to be consistent across the board.
    • TkuhnT
      TkuhnT
      Tkuhn
      Does his smoke pretty bad on start up? After looking at a few videos my symptoms seem to be that of valve seals. But i also see that the rings tend to get gunked up and are not able to fully expand. A few people used fuel injector cleaner and poured it into the spark plug holes and let it sit for a day and it raised the compression from almost nothing to 120 psi. Once i get down to the garage and do a comp test i may have more insight into this
      • ThatRatRodProjectT
        ThatRatRodProjectT
        ThatRatRodProject
        The m54 is know to burn oil.
        • TkuhnT
          TkuhnT
          Tkuhn
          That's what I have been told and read, but again oil consumption is one thing. The billowing clouds are another I would think.
          • TkuhnT
            TkuhnT
            Tkuhn
            Here are the compression test numbers. Car ran for a little under 10 min before I performed the test.
            Spark plugs were a little wet and it was not fuel.
              Brave soul performing a compression test and posting it here. There's been bad juju all here regarding compression tests lately haha
              • JeffJ
                JeffJ
                Jeff
                Can you post pictures of plugs also a video of the smoke would be helpful.
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  ThatRatRodProjectT
                  ThatRatRodProject
                  As far as I'm aware Oil consumption is mostly caused by burning oil where else is it going to go.
                  • TkuhnT
                    TkuhnT
                    Tkuhn
                    I will try to get the video up after work along with some photos of the plugs!
                    • TkuhnT
                      TkuhnT
                      Tkuhn
                      I believe you took that wrong. Yes oil consumption is caused by burning oil, I think we all can understand that. But when it comes to excessive smoke out the exhaust it's more than a standard "oil consumption" issue and all I was looking for was some people with experience beyond knowing that there are oil consumption issues with the m54. I appreciate the specs but this issue is more than reading the manual.
                      • TkuhnT
                        TkuhnT
                        Tkuhn
                        I wasn't aware buttt I suppose if a person believes in that time will tell haha
                          I know it is a different engine but just for comparison.  My m50 smokes a little, Pretty sure it is ring blowby in my case because it smokes most under WOT.  The m50 has no catch can/ oil separator, it just goes from the valve cover to the intake manifold (stock) and the baffling in the valve cover is not good enough to keep oil from going with the air.  It has 275k on it so I don't feel it's abnormal.  It doesn't hang in the air like a diesel but it is a visible smoke on startup and when romping on it.  I don't keep great records but I think I add a quart every 1000-1500 miles, some is due to leaks though.
                          Compare to a 2 stroke engine.  Assuming 25mpg, 1k miles is 40 gallons of fuel, mixed 50:1 that is 3.2 quarts of oil per 1k miles.  You aren't near that much so I wouldn't think it would cause plug fouling problems.  A little lube for the cylinders is good anyway.
                          How's that for redneck engineering?
                            how many tanks of fuel have run through the engine?
                              At 25mpg about 11000 gallons.
                              687.5 tanks at 16 gallons/tank, I think it is actually a little bigger than that.
                              • TkuhnT
                                TkuhnT
                                Tkuhn
                                Since this started about 2 tanks. One of which was under heavy abuse.
                                • TkuhnT
                                  TkuhnT
                                  Tkuhn
                                  Hahaha I don't disagree there, but to me it's abnormal for alot hanging smoke to be in the air after start up and at idle and when blipping the throttle. I went through a quart in one tank of gas, so something has to be wrong. After a good compression test result im leaning toward valve seals.
                                  • TkuhnT
                                    TkuhnT
                                    Tkuhn
                                    NOTE: while the car was running I removed the oil cap and got the hissing noise as I removed it. Meaning the crank case is under a fair amount of pressure. From research this means the CCV failed, but I have no CCV. Thoughts on that?
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      I would be checking to see if you have any broken ccv hoses first.
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                      • TkuhnT
                                        TkuhnT
                                        Tkuhn
                                        Jeff said:
                                        The CCV is deleted with a sealed system catch can set up, description is in original post
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          How are you pulling ccv gases??
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
