Alpine White Zender Kit E24 633CSI
I just used buffing compound. If its really bad, you will need to sand through the anodizing and polish them. Its an extremely long and time consuming process.
More progress. I pulled the valve cover off to replace the gasket, paint the cover, paint the air box and AFS, replace the breather hose, and do the oil tube update @YoungCRmentioned earlier.
I used the Evapor-rust to clean the clips and bolts holding stuff together while I strip and paint stuff and bake it on the oven with VHT.
Before the modified oil squirter looked like this( when I finally got it out)
And after I compressed the center. This is a common fix to help add oil pressure to lubricate the front rocker arms during low RPM driving.
I want to do this mod to mine!
Do you know if the e30 lights fit the e24? I want to get some new headlights. Maybe euro ellipsoid's
I would say yes, but it would take some modification. Here is a e24 trim ring over my e30 lights. They are the same diameter, but the spacing between the lights isn't the same. *note the light holes seem larger in the e24 grills because of the chrome trim rings.
Thanks for the photos, now sell me your headlights.
Late model 88-89 had ellipsoids stock, not sure about smilies though.
Waiting on crush washers to come in the mail any minute now....
In the meantime I blasted and painted the valve cover, got some new hoses, and installed a new O2 sensor.
Last night I decided to pull apart the caliper that was sticking in hopes of just cleaning it up and putting it back together to free it up. That was a giant fail as the caliper was froze so bad (probably from me driving it and getting it hot) that I had to spend 30mins just to get it off of the rotor. It was crusty but not as bad as I was expecting. I ordered new pads, clips, and a seal kit for the front calipers.
Still on the search for new front the following parts:
-Exterior-
-US Front bumper side covers (both sides) 51111869769 51111869770
-Tail lights
-Tail light surrounds
-Head lights
-Front grilles and kidneys
-Front valance-Interior-
-Sun visor clips 51161927473
-Radio cut out 51161883811
-heater control knob
-Rear deck lid covers in Cherry-Mechanical-
-Muffler (I might just run pipes from the resonator out the back instead)
-Front springs
-Driver side front caliper(if I cant fix what I have)Dirty:
Blasted:
Painted:
What brand is that new sensor? NTK?
Valve cover looks nice, your wrinkle paint spraying skills surpass mine.
Yes NTK.
The key to nice wrinkle paint is using an oven. Makes it look like I know what Im doing.
They copied you, sue them.
No way, that thing is glorious though.
Still waiting on parts. The first shipment was lost so the seller sent a second set of crush washers. How annoying. Anyways, I did an oil change, painted the AFS, and some more parts since they were off the car. The old oil filter was super gross and the last person that installed the filter smashed the gasket and it doesnt look like it was sealing properly
The oil itself looked far overdue as well so I cleaned everything out really well before adding new stuff. I replaced all the o-rings and crush washers and added VR-1 because it has the extra zinc levels in it perfect for older bmw motors. I ran this oil in my M20 and loved it.
I also have a lead on a front valance, grills, kidneys, and euro lights. So there's that as well.
Rebuilt the brake caliper last night even though one of the seals was the wrong size. Besides that, I was sent a box with 4 rear inside brake pads instead of new front pads, so I cant install the caliper if I wanted to anyways.
I failed to take pictures of most of my results due to anger and frustration. But here is a not so great picture of the difference in the seal that was incorrect.
It looks like it would work, but would certainly not. Imagine trying to repair a bicycle inner tube using a 26" tube on a kids 16" wheel. It doesn't work.
Always wondered about VR-1. 20W-50 anything is getting harder and harder to find. I will try it out in the poor-mans S50 once its running
Hell yeah its awesome, and I rather run it than just a basic ZDDP/ZDTP additive due to not knowing how the oil you use will "accept" (for a lack of a better term) the extra chemical.
Finally got the crush washers after they got lost in shipping twice. I went to torque the oil rail down and the online specs said 11-13NM. I set my torque wrench to 11.5 but man that felt too tight so I went by feel. I know that rail is delicate, and the crush washers formed to the tube like they were before, so I am not worried about getting it any tighter. I also used some loctite as recommended so they wont back out. I bolted everything back together and it looks a ton better with everything freshly painted.
I also got a new roundel for up front and this afternoon I am meeting a guy with new headlights, grills, kidneys, side markers, gaskets, and hardware. I was really hoping he had a valance but he said he just sold his along with front and rear euro bumpers. DRATS!!
So I met a guy that drove up from Illinois to deliver me some parts as seen below. Super nice guy and we ended up talking for a good 45 minutes. Turns out he has a nice size collection of vintage cars and he shared some pictures with me(also seen below). He convinced me that I need to visit the Windy City Vintage Fest this September on the 16th. Boom, I have a new deadline this car needs to be in perfect roadworthy selling condition.
Overall he sent me about 40 pictures of his collection. Some pretty awesome stuff. That's all for now until I start installing all the goodies he brought me.
Installed and polished the new (to me) kidneys, grills, and lights. What a difference. I cant wait to find a front valance so I can mount the front Zender lip correctly. I also found the new coolest thing about the car; the perimeter lit vanity mirror. There is a metal part inside the visor clip and the previous clip was snapped off. I was able to use the old metal portion but the plastic was destroyed. The metal makes a connection when the visor is in the down position grounding out the light.
