e24m30633csibmwzenderbbs
    The valence is definitely gone lol oops
      Starting to look even better!
      • e92boostE
        e92boostE
        e92boost
        It's coming along great! I'm wanna come with my 6er to see this thing one day.
        Ben H.
            You need an early valence for that lip
              Early valance and Euro bumper. 😦 thats another $250.
                Was the bumper oxidized, or just scuffed/scratched?
                  Thank you! there is alot of work ahead of me though
                  You should!! It would be great to have the two together for a photo!
                  Oxidized mostly, with a lot of spotting. I still left the clear anodizing on it, just polished it up.
                    Interesting. Any specific product/method you recommend for getting the oxidation off? The rear bumper on my e30 could definitely use some love.
                      I just used buffing compound. If its really bad, you will need to sand through the anodizing and polish them. Its an extremely long and time consuming process.
                      More progress. I pulled the valve cover off to replace the gasket, paint the cover, paint the air box and AFS, replace the breather hose, and do the oil tube update @YoungCRmentioned earlier.
                      I used the Evapor-rust to clean the clips and bolts holding stuff together while I strip and paint stuff and bake it on the oven with VHT.
                      Before the modified oil squirter looked like this( when I finally got it out)
                      And after I compressed the center. This is a common fix to help add oil pressure to lubricate the front rocker arms during low RPM driving. IMG3949.JPGIMG3948.JPG
                      • e92boostE
                        e92boostE
                        e92boost
                        I want to do this mod to mine!
                        Ben H.
                        • e92boostE
                          e92boostE
                          e92boost
                          Do you know if the e30 lights fit the e24? I want to get some new headlights. Maybe euro ellipsoid's
                          Ben H.
                            I would say yes, but it would take some modification. Here is a e24 trim ring over my e30 lights. They are the same diameter, but the spacing between the lights isn't the same. *note the light holes seem larger in the e24 grills because of the chrome trim rings.
                            • e92boostE
                              e92boostE
                              e92boost
                              Thanks for the photos, now sell me your headlights.
                              Ben H.
                                Late model 88-89 had ellipsoids stock, not sure about smilies though.
                                  Haven't been able to put the oil rail back in the car yet because I need new crush washers. I'm hoping zinbrick has some on Monday. Otherwise $10 on eBay and 1 week to arrive. 😦
                                    Waiting on crush washers to come in the mail any minute now....
                                    In the meantime I blasted and painted the valve cover, got some new hoses, and installed a new O2 sensor.
                                    Last night I decided to pull apart the caliper that was sticking in hopes of just cleaning it up and putting it back together to free it up. That was a giant fail as the caliper was froze so bad (probably from me driving it and getting it hot) that I had to spend 30mins just to get it off of the rotor. It was crusty but not as bad as I was expecting. I ordered new pads, clips, and a seal kit for the front calipers.
                                    Still on the search for new front the following parts:
                                    -Exterior-
                                    -US Front bumper side covers (both sides) 51111869769 51111869770
                                    -Tail lights
                                    -Tail light surrounds
                                    -Head lights
                                    -Front grilles and kidneys
                                    -Front valance
                                    -Interior-
                                    -Sun visor clips 51161927473
                                    -Radio cut out 51161883811
                                    -heater control knob
                                    -Rear deck lid covers in Cherry
                                    -Mechanical-
                                    -Muffler (I might just run pipes from the resonator out the back instead)
                                    -Front springs
                                    -Driver side front caliper(if I cant fix what I have)
                                    Dirty:
                                    Blasted:
                                    Painted:
                                    Old vs. New Oxygen sensor:IMG3985.JPG
                                      What brand is that new sensor? NTK?
                                      Valve cover looks nice, your wrinkle paint spraying skills surpass mine.
                                        Yes NTK.
                                        The key to nice wrinkle paint is using an oven. Makes it look like I know what Im doing. 😄
                                          https://m.nettiauto.com/bmw/635/8996293    damn it ❤
