  4. E30 M52
E30 M52
    Continuing on with my MO of spending just a few minutes a day on the project, I finally got the intake manifold off.
    It isnt called a "mess under the intake" for no reason!
    OBD1 will only slightly help with that.
    For those that arent aware of the difference between an M50 manifold (thick and healthy) and an M52 manifold (frail and anemic), here it is
    After I remove the E39 harness, brackets, and accessories I will be plenty busy cleaning the block.
    RealOEM will become invaluable as I make a list of other clips/brackets/hoses that I didnt buy yet to mount the OBD1 harness and accessories.
      X52 manifold looks like ass too
        Scrubbing....
        • JeffJ
          JeffJ
          Jeff
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            Scrubbing...
              Advance Auto had buy one get one free brakeclean today!
                The race is on!
                • The Full BananaT
                  The Full BananaT
                  The Full Banana
                  Try oven cleaner if you haven't already!
                    All you have to do is bolt a supercharger on to win the race (this comment works two ways)
                    I would be very interested to see how this M52 would do against an S50 though
                      Paging dan
                      • JeffJ
                        JeffJ
                        Jeff
                        Found one
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          Jeff said:
                          Found one
                          I'll even make him a deal on it
                            I can't be bothered with used superchargers right now, too busy scrubbing...
                              Injectors are back from Injector-Rehab
                              Turnaround time was great and they returned the old filters and parts as proof that they replaced them. I gave them a fresh coat of paint to finish them off.
                                How much was it?
                                  I think it was $106 after all was said and done.
                                  I first checked into new injectors but enough knockoff Chinese "Bosch pink tops" exist online that I decided it would be best to just rebuild a set of known good ones
                                    I have found refurbished genuine Bosch injectors on Ebay to be the way to go.  Paid 65$ for the flow matched set of ev6 injectors recently.
                                    Information a little too late, sorry.
                                      I was mainly drawn to choosing my own refurbisher since I could get a printout of the test/some sort of evidence to show that they are flowing evenly. It wouldnt surprise me if you had some folks just blasting some brake cleaner through them :P
                                        That is quite possible, although the reviews were good and I think they were cheap because the application was very obscure, Ford SVT 2.5 from 99-00 only so probably trying to get rid of them.  He claimed to do all kinds of stuff, backflush, ultrasonic, etc flow test within 2%.  I have no way of knowing if any of it was true though.
                                          My goal for today is to pull the block and trans from the car and say my final goodbyes to the m20
                                          I have decided to shift my focus away from the M52 refresh for a bit because next up is swapping out the M52 cams for some S52 cams, but as I look into the steps involved it looks really easy to screw it up so i need to do a lot of reading before i dive in.
                                          Once the M20 is pulled i will do some scrubbing, repainting, install the E21 booster, and cut the mounting brackets off that i made for my intercooler.
                                          Im still shooting for the end of august, but I will definitely have to replenish the car fund somehow to buy my last round of parts that I need and pay for some welding
