  4. E30 M52
E30 M52
    Sssquid Tuning responded today, checked their records and I do in fact have the M52B28 tune as desired, the B25 was a typo, however, the 7400rpm limiter isn't sitting well with me because I know how these 24v engines get a bit crabby about harmonics after the big hand hits the 7 and the tune was for 91 octane anyways so I am having a new tune sent for 93 octane with a 7100 soft limit and a 7250 hard limit. At some point when its in the car I will put it on a dyno and see how its doing and probably get another tune revision.
    I have considered making my core support removable for a while now but I think I need to make it happen for this install. I just don't think the 24V was meant to be lifted at the extreme angles required to fit into an E30. I will be looking into removable core support gameplans and alternate front engine lifting points tonight.
      Put it in from the bottom=)
        That's what Dave suggested too. I HATE installing the steering joint back on the steering rack. Its something to consider though.
          Try and fit an e46 joint and steering linkage?
            let all the air out of your front tires and jack the rear of the car way up in the air.
            insertion angle is all about positioning. car-ma sutra, or something.
              This is the kind of out-of-the-box thinking we need around here!
                Really not needed. I've pulled / installed m5x/s5x motors in e30's 10 to 15 times and only 3 or 4 have been with removable core supports. It's not a terrible fit.
                  Continuing on with my MO of spending just a few minutes a day on the project, I finally got the intake manifold off.
                  It isnt called a "mess under the intake" for no reason!
                  OBD1 will only slightly help with that.
                  For those that arent aware of the difference between an M50 manifold (thick and healthy) and an M52 manifold (frail and anemic), here it is
                  After I remove the E39 harness, brackets, and accessories I will be plenty busy cleaning the block.
                  RealOEM will become invaluable as I make a list of other clips/brackets/hoses that I didnt buy yet to mount the OBD1 harness and accessories.
                    X52 manifold looks like ass too
                      Scrubbing....
                      • JeffJ
                        JeffJ
                        Jeff
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          Scrubbing...
                            Advance Auto had buy one get one free brakeclean today!
                              The race is on!
                              • The Full BananaT
                                The Full BananaT
                                The Full Banana
                                Try oven cleaner if you haven't already!
                                  All you have to do is bolt a supercharger on to win the race (this comment works two ways)
                                  I would be very interested to see how this M52 would do against an S50 though
                                    Paging dan
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      Found one
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                        Jeff said:
                                        Found one
                                        I'll even make him a deal on it
                                          I can't be bothered with used superchargers right now, too busy scrubbing...
