  3. Services Offered/Wanted
  4. N54 Injector Coding/Install
12 Posts 4 Posters 0 Views 1 Watching
    B12078 said:
    Hello,
     My name is Brandon. I have 08 335i e90. I just brought a set index 12 injectors. Wondering how much for you to install and code.
    Thank you
    Brandon
    Hey Brandon!  It would be $150 to install and code the injectors.  I'm located in Milton just north of Janesville.  Please let me know how you would like to proceed.
      B12078
      Yes i would. When is the soonest your available?
        Ragan
        Hey patsbimmer, just a quick question. Would it be possible to install the injectors and then be able to drive to a certain area to have them code the injectors? Or would the injectors not work at all if not coded? I would be interested in having you code mine as well.
          I would not advise that it be driven but it is possible.  The reason the injectors need to be coded is so the DME can optimize the fuel being applied based on the tolerance the injector is tested at from the factory.  If it's way off you could have a poor running car.  You could also not even notice but it would be slightly off.
            I'll be traveling back from Rice Lake on Friday so I may be able to stop in LaCrosse on my way back to code them if you'd like to set that up.
              Ragan
              i will send you pm when ready. I travel to milwaukee a lot on the weekends and pretty booked until after july.
                That's fine.  I'm just north of Janesville in Milton so about 40 min south of Madison and an hour or so west of Milwaukee.
                  I'm available the next couple weekends and i'll also be in LaCrosse next week and Eau Claire the week after if anyone is interested in me bringing tools.  I'm also fairly profcient in other repairs/installs if there is something you need done!
                    Let's get some beers programmed and coded?
                      Did you even need to ask?  I hear Bug Eyed Betty's calling my name!  I'll be up on the 17th.
