  4. My life in the slow lane: Turning a z71 4x4 335I into something respectable.
335isingle turboxdriven54port injectiontwin turbovrsftialfuel-itcomp turboz71still not fast4x4does anyone eve
86 Posts 15 Posters 1.7k Views 2 Watching
    Awesome! Managing underhood temps looks like it's going to be your biggest enemy here.  I hope I get to see see this thing running one day!
    • Chris WelterC
      Chris WelterC
      Chris Welter
      i_love_cars said:
      awesome progress. It looks like there is a light at the end of the tunnel now. Seems pretty plausible that this car will be running well before summer is done?
      That is the plan, I'd like to get it on the track at least once before it gets cold. The engine is almost there, just gotta get the trans and shift linkage in and get the d/s made. The exhaust can be really easy for the time being to just get it to run. Main obstacle with the turbos will be that radiator fan, but I have a few ideas to eliminate that issue.
      Sent from my HTC6545LVW using Tapatalk
      2009 335XI: JB4, DCI, Tein Springs, Custom exhaust, Single Turbo, Port Injection, VRSF 7", ...
      2002 Suburban: DD and toy hauler.
      1996 Jeep Grand Cherokee: Come buy this I dont want it anymore!
      • Chris WelterC
        Chris WelterC
        Chris Welter
        Nice update!
        Access to the front of the engine looks improved over the I6 (obviously), Is there anything that is going to be a royal PITA to work on with this setup that will require pulling the engine, that normally wouldn't (spark plug access etc.)
        It really depends on how the exhaust and turbos all work out. The motor plate has been sheared and I can actually remove the plugs from the front of the engine (reach between the plate and the manifold to access them fairly easy). Compared to a C5 there is a lot of room and I could pull the intake manifold off or change oil or map sensors with engine in the car. The car being a prior Xi has a different front subframe that if the car is lifted there is HUGE access with the skid plate off. As of now I can't see a reason to pull the engine for anything really. It is truly impressive how it fit in there.
        • Chris WelterC
          Chris WelterC
          Chris Welter
          I have been thinking about that a lot recently and have been trying to come up with a solution. I thought about wrapping the headers since they are stainless but don't really want to deal with stressing the materials out with excessive heat and cracking them. It is looking like ceramic coating will be the best option but I've had crap luck with that in the past and it is rare it stays nice for long. Time will tell, might run them unfinished and insulate everything around them.. Hood louvers may be warranted..
            Whenever I do ceramic coating, I top coat them with high temp spray paint so that a) it protects the ceramic and b ) its quickly and easily touched up when it does get scratched.
              I think coatings and reflective tape are usually the most popular options.  Louvers are an option but I know off the shelf options aren't always effective due to pressure variances caused by air flow over the hood/under the body compared to under the hood.  I remember a trick from my 240sx days was to shim the hood so it lifted the rear of the hood up an inch or so to increase airflow under hood.  I know I had read a pretty in depth article about why this worked with data from thermocouples to support it.  I can't find it right now but i'll keep looking.
              • Chris WelterC
                Chris WelterC
                Chris Welter
                I would be interested to read that article if you do find it. I know that with the N54 if you removed the Ecu cover and that shelf that goes over the engine the amount of heat/air that poured out onto the windshield was unreal. Provided rain or washing the car at that point was prohibited but for hot weather and drag racing it worked out well. A good thing though is the wiring and all the heat sensitive components are away from the pipes for the most part now. BMW left the steering shaft hole for the right hand drive cars in the left hand drive chassis and installed insulated plug, that plug gave me a hole to run my Dominator wiring, it was almost meant to be.. 😂
                  Heat wrap will give you better fuel consumption, better turbo spool and wont heat everything in the engine bay to a million degrees. Make sure you get a good brand and soak it in water before you apply it. There is a lot of opinions about wrap on the internet, but if done right it makes a drastic difference. The stuff doesn't exist because it doesn't work. The only way I could see a manifold cracking would be due to weight and vibration without being properly supported. Ceramic coating is nice and I have had it on non-turbo manifolds before(mostly hondas) and it seemed to hold up fine. My issue with it is cost and effectiveness. Besides that though it also looks better than a mummy wrapped manifold.
                  Related image
                  • Chris WelterC
                    Chris WelterC
                    Chris Welter
                    I suppose you are probably correct. I need to take the application into context too. This is strictly a street/strip car. My initial reservation about wrap was it was bad because they material cannot vent the heat that it absorbs and heat cycles badly causing expansion and contraction problems and cracking as well as becoming brittle because of the temps. However this being a street/strip car and not a dedicated track car, it will be hard pressed to run hard enough for long enough to cause a problem. What brands do you recommend? Reccomended process or tips?
                      A lot of times with stainless exhaust cracking is if it wasn't back purged when it was welded, to much weight on it without enough support, or welding the exhaust hangars directly to the car.
                        THIS^!^!^!^!^
                        As far as brands go, the high end stuff with titanium and Lava rock is all going to do a good job. DEI, Ledaut, brands are some good ones. I used DEI on my down pipe on my 1JZ and it works amazing. Its the same stuff we used on all the cup cars and it works great. DEI also offers a few different styles or "levels" so you can get something that will work best for you. Just make sure you do a really good job installing it.
