  4. Anyone good at bodywork?
19 Posts 9 Posters 214 Views 1 Watching
    Auto Paint Supply, 164 and Main St. in Waukesha I would assume?
    • need4speed1299N
      need4speed1299N
      need4speed1299
      mystere30 said:
      whaaa?? quillbro where are you/where is said shop/whats it called? i have a guy who will do body work and paint, just needs a place to do it. hes a certified body tech.
      me? ;)
      If you go the diy route, get wax and grease remover and clean good. Also, since your doing plastic, take your time. Paint really likes metal more. I would recommend using a slightly courser sand paper vs what the paint product would specify for plastics. As for sandblasting, make sure you get all the blackness out of the pitting otherwise it will come back. Snap on sells a nice little blaster called the speedblaster and you can get the correct sand at menards for cheap. Its messy and the dust is dangerous to breath. Lastly, get some finishing glaze after using bondo. Usc makes good products. And use a big sanding block, ex. durablock, to get it all even. Pm me if you have any questions.
      • T
        T
        Ted
        I need some paint work done, i jave a place all i need is an experience painter I am in Vernon on hwy 164
          I used to work over near vernon at Jamies customs. The owner of that place is bat-shit crazy.
          • Q
            Q
            quillbro
            need4speed1299 said:
            me? ;)
            Yeah i dont think im doing any plastic areas... I have a spot on the passanger door, the whole underside of the driver door sill area. A spot on the door sill. A spot on the rear valence by the tow hook, and a spot on the windshield wiper window panel.
            So a few spots... well kinda alot... haha the car is nice, not a rust bucket at all. But its got alot of money into it. S50, ZF trans, a bunch of other stuff... and I want to get the surface rust off before it rots.
            But i have a repirator, and am going to do the blasting with a shop vac hooked up to try to reduce mess... not sure if it will work very well or not, we'll see. Thanks for the tips though. This is not a show car... so i dont car if the painwork is perfect. Its a good car to learn on i figure.
            Maybe I'll post a thread once i commit to it.
            • need4speed1299N
              need4speed1299N
              need4speed1299
              The vac is a good idea. Make sure you cover the windshield when blasting or the sand will pit it.
                If you sand blast your body turn the pressure down, or you can dent/ mess up panels. Watched a kid do it at my shop. Needles to say he had to buy someone a new door
                • Q
                  Q
                  quillbro
                  Yeah i had planned on masking all area with painters plastic and tape just to keep the mess out. Something heavy mil most likely. I was planning on using this gun:
                  http://www.eastwood.com/speed-blast-gravity-feed-blaster.html
                  10cfm 100 psi, my compressor can do that. Saw this gun in use on a few DIY videos and it looked just about perfect for the job, pretty cheap too.
                  Do you suggest a specific rust preventive primer?
                  From the DIY's i have read, and some books I rented on the topic, it kinda went like this as far as steps:
                  Sandblast
                  Hand sand surrounding area to blend
                  Corrosion preventive primer
                  Filler
                  sand
                  primer
                  paint
                  clear
                  Sound about right? I'm winging this. haha
                  • Q
                    Q
                    quillbro
                    noted.... start around what 60 psi? Go up from there as needed?
                    • need4speed1299N
                      need4speed1299N
                      need4speed1299
                      Sandblast
                      Filler
                      sand
                      primer
                      paint
                      clear
                      I have used that blaster, its a knock off of the snap on style I believe. Its not as effective. This one is much better.
                      buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=636326&group_ID=675781&store=snapon-store&dir=catalog
                      clean work area
                      Sand blast
                      fetheredge sand blasted area
                      Self etching primer
                      filler, short hair
                      sand to shape
                      glaze coat filler
                      sand lightly to perfection
                      high build "2k" urethane primer
                      smooth out minor imperfections
                      sealer
                      light scuff
                      paint
                      clear
                        or lower. Just play with it an just turn it up/ down as you go. :)
                        • H
                          H
                          Hammerdown
                          Sandblasting can heat the metal causing it to warp. Try to find a practice piece to get the pressure setting correct. Best to start 50-60 psi and work up if needed
                            You can always change your blast media too. Walnut shells, soda, aluminum, ect.
                            • Q
                              Q
                              quillbro
                              well clearly most here have much more knowledge than myself with this. That is fine, i understand i'm a total noob. haha. But that being said im still gonna give it a go. I dont think the car is worth getting done professionally as it is probably only worth about 8500 or so. And im sure it would be well over 1500 dollars in work.
                              I do REALLY appreciate the comments however.
                              Thanks. I'm going to try to tackle this in the next 3-4 weeks.
                              • Q
                                Q
                                quillbro
                                Btw, link didnt work for me... are you talking about the snap on underslung blaster? I could see this being much more stable in hand....
                                http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=642433&group_ID=675781&store=snapon-store&dir=catalog
                                http://buy1.snapon.com/catalog/OBJECTS/images/PSB500AR.jpg
