<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Anyone good at bodywork?]]></title><description><![CDATA[<p dir="auto">Hello, I am looking for someone that is experienced at bodywork or knows of any good body shops in the oshkosh area. I have a dent and some scratches that need to be taken care of and also some rust. I will be posting pictures later.</p>
]]></description><link>https://wibimmers.com/topic/551/anyone-good-at-bodywork</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 05:36:29 GMT</lastBuildDate><atom:link href="https://wibimmers.com/topic/551.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Mar 2012 21:38:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Anyone good at bodywork? on Wed, 27 Jun 2012 00:12:18 GMT]]></title><description><![CDATA[<p dir="auto">Btw, link didnt work for me... are you talking about the snap on underslung blaster? I could see this being much more stable in hand....</p>
<p dir="auto"><a href="http://buy1.snapon.com/catalog/item.asp?P65=&amp;tool=all&amp;item_ID=642433&amp;group_ID=675781&amp;store=snapon-store&amp;dir=catalog" rel="nofollow ugc">http://buy1.snapon.com/catalog/item.asp?P65=&amp;tool=all&amp;item_ID=642433&amp;group_ID=675781&amp;store=snapon-store&amp;dir=catalog</a></p>
<p dir="auto"><a href="http://buy1.snapon.com/catalog/OBJECTS/images/PSB500AR.jpg" rel="nofollow ugc">http://buy1.snapon.com/catalog/OBJECTS/images/PSB500AR.jpg</a></p>
]]></description><link>https://wibimmers.com/post/8059</link><guid isPermaLink="true">https://wibimmers.com/post/8059</guid><dc:creator><![CDATA[quillbro]]></dc:creator><pubDate>Wed, 27 Jun 2012 00:12:18 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Wed, 27 Jun 2012 00:05:17 GMT]]></title><description><![CDATA[<p dir="auto">well clearly most here have much more knowledge than myself with this. That is fine, i understand i'm a total noob. haha. But that being said im still gonna give it a go. I dont think the car is worth getting done professionally as it is probably only worth about 8500 or so. And im sure it would be well over 1500 dollars in work.</p>
<p dir="auto">I do REALLY appreciate the comments however.</p>
<p dir="auto">Thanks. I'm going to try to tackle this in the next 3-4 weeks.</p>
]]></description><link>https://wibimmers.com/post/8058</link><guid isPermaLink="true">https://wibimmers.com/post/8058</guid><dc:creator><![CDATA[quillbro]]></dc:creator><pubDate>Wed, 27 Jun 2012 00:05:17 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Tue, 26 Jun 2012 15:39:25 GMT]]></title><description><![CDATA[<p dir="auto">You can always change your blast media too. Walnut shells, soda, aluminum, ect.</p>
]]></description><link>https://wibimmers.com/post/8054</link><guid isPermaLink="true">https://wibimmers.com/post/8054</guid><dc:creator><![CDATA[rampelsauce]]></dc:creator><pubDate>Tue, 26 Jun 2012 15:39:25 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Tue, 26 Jun 2012 14:45:38 GMT]]></title><description><![CDATA[<p dir="auto">Sandblasting can heat the metal causing it to warp. Try to find a practice piece to get the pressure setting correct. Best to start 50-60 psi and work up if needed</p>
]]></description><link>https://wibimmers.com/post/8053</link><guid isPermaLink="true">https://wibimmers.com/post/8053</guid><dc:creator><![CDATA[Hammerdown]]></dc:creator><pubDate>Tue, 26 Jun 2012 14:45:38 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Tue, 26 Jun 2012 13:44:23 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>quillbro said:</strong></p>
<p dir="auto">noted.... start around what 60 psi? Go up from there as needed?</p>
<p dir="auto">or lower. Just play with it an just turn it up/ down as you go. <img src="/assets/uploads/files/emoticons_default_smile.png" alt=":)" class=" img-fluid img-markdown" width="20" height="20" /></p>
]]></description><link>https://wibimmers.com/post/8052</link><guid isPermaLink="true">https://wibimmers.com/post/8052</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Tue, 26 Jun 2012 13:44:23 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Tue, 26 Jun 2012 12:05:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Yeah i had planned on masking all area with painters plastic and tape just to keep the mess out. Something heavy mil most likely. I was planning on using this gun:</p>
<p dir="auto"><a href="http://www.eastwood.com/speed-blast-gravity-feed-blaster.html" rel="nofollow ugc">http://www.eastwood.com/speed-blast-gravity-feed-blaster.html</a></p>
<p dir="auto">10cfm 100 psi, my compressor can do that. Saw this gun in use on a few DIY videos and it looked just about perfect for the job, pretty cheap too.</p>
<p dir="auto">Do you suggest a specific rust preventive primer?</p>
<p dir="auto">From the DIY's i have read, and some books I rented on the topic, it kinda went like this as far as steps:</p>
<p dir="auto">Sandblast</p>
<p dir="auto">Hand sand surrounding area to blend</p>
<p dir="auto">Corrosion preventive primer</p>
<p dir="auto">Filler</p>
<p dir="auto">sand</p>
<p dir="auto">primer</p>
<p dir="auto">paint</p>
<p dir="auto">clear</p>
<p dir="auto">Sound about right? I'm winging this. haha</p>
<p dir="auto">I have used that blaster, its a knock off of the snap on style I believe. Its not as effective. This one is much better.</p>
<p dir="auto"><a href="http://buy1.snapon.com/catalog/item.asp?P65=&amp;tool=all&amp;item" rel="nofollow ugc">buy1.snapon.com/catalog/item.asp?P65=&amp;tool=all&amp;item</a>_ID=636326&amp;group_ID=675781&amp;store=snapon-store&amp;dir=catalog</p>
<p dir="auto">clean work area</p>
<p dir="auto">Sand blast</p>
<p dir="auto">fetheredge sand blasted area</p>
<p dir="auto">Self etching primer</p>
<p dir="auto">filler, short hair</p>
<p dir="auto">sand to shape</p>
<p dir="auto">glaze coat filler</p>
<p dir="auto">sand lightly to perfection</p>
<p dir="auto">high build "2k" urethane primer</p>
<p dir="auto">smooth out minor imperfections</p>
<p dir="auto">sealer</p>
<p dir="auto">light scuff</p>
]]></description><link>https://wibimmers.com/post/8051</link><guid isPermaLink="true">https://wibimmers.com/post/8051</guid><dc:creator><![CDATA[need4speed1299]]></dc:creator><pubDate>Tue, 26 Jun 2012 12:05:42 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Mon, 25 Jun 2012 16:39:38 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>Visionshift said:</strong></p>
<p dir="auto">If you sand blast your body turn the pressure down, or you can dent/ mess up panels. Watched a kid do it at my shop. Needles to say he had to buy someone a new door</p>
]]></description><link>https://wibimmers.com/post/8045</link><guid isPermaLink="true">https://wibimmers.com/post/8045</guid><dc:creator><![CDATA[quillbro]]></dc:creator><pubDate>Mon, 25 Jun 2012 16:39:38 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Mon, 25 Jun 2012 16:38:26 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>need4speed1299 said:</strong></p>
<p dir="auto">The vac is a good idea. Make sure you cover the windshield when blasting or the sand will pit it.</p>
]]></description><link>https://wibimmers.com/post/8044</link><guid isPermaLink="true">https://wibimmers.com/post/8044</guid><dc:creator><![CDATA[quillbro]]></dc:creator><pubDate>Mon, 25 Jun 2012 16:38:26 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Mon, 25 Jun 2012 13:31:21 GMT]]></title><description><![CDATA[<p dir="auto">If you sand blast your body turn the pressure down, or you can dent/ mess up panels. Watched a kid do it at my shop. Needles to say he had to buy someone a new door</p>
]]></description><link>https://wibimmers.com/post/8040</link><guid isPermaLink="true">https://wibimmers.com/post/8040</guid><dc:creator><![CDATA[Brian.]]></dc:creator><pubDate>Mon, 25 Jun 2012 13:31:21 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Mon, 25 Jun 2012 11:21:44 GMT]]></title><description><![CDATA[<p dir="auto">The vac is a good idea. Make sure you cover the windshield when blasting or the sand will pit it.</p>
]]></description><link>https://wibimmers.com/post/8038</link><guid isPermaLink="true">https://wibimmers.com/post/8038</guid><dc:creator><![CDATA[need4speed1299]]></dc:creator><pubDate>Mon, 25 Jun 2012 11:21:44 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Mon, 25 Jun 2012 03:24:14 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">me? <img src="/assets/uploads/files/emoticons_default_wink.png" alt=";)" class=" img-fluid img-markdown" width="20" height="20" /></p>
<p dir="auto">If you go the diy route, get wax and grease remover and clean good. Also, since your doing plastic, take your time. Paint really likes metal more. I would recommend using a slightly courser sand paper vs what the paint product would specify for plastics. As for sandblasting, make sure you get all the blackness out of the pitting otherwise it will come back. Snap on sells a nice little blaster called the speedblaster and you can get the correct sand at menards for cheap. Its messy and the dust is dangerous to breath. Lastly, get some finishing glaze after using bondo. Usc makes good products. And use a big sanding block, ex. durablock, to get it all even. Pm me if you have any questions.</p>
<p dir="auto">Yeah i dont think im doing any plastic areas... I have a spot on the passanger door, the whole underside of the driver door sill area. A spot on the door sill. A spot on the rear valence by the tow hook, and a spot on the windshield wiper window panel.</p>
<p dir="auto">So a few spots... well kinda alot... haha the car is nice, not a rust bucket at all. But its got alot of money into it. S50, ZF trans, a bunch of other stuff... and I want to get the surface rust off before it rots.</p>
<p dir="auto">But i have a repirator, and am going to do the blasting with a shop vac hooked up to try to reduce mess... not sure if it will work very well or not, we'll see. Thanks for the tips though. This is not a show car... so i dont car if the painwork is perfect. Its a good car to learn on i figure.</p>
<p dir="auto">Maybe I'll post a thread once i commit to it.</p>
]]></description><link>https://wibimmers.com/post/8029</link><guid isPermaLink="true">https://wibimmers.com/post/8029</guid><dc:creator><![CDATA[quillbro]]></dc:creator><pubDate>Mon, 25 Jun 2012 03:24:14 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Sat, 23 Jun 2012 13:32:13 GMT]]></title><description><![CDATA[<p dir="auto">I used to work over near vernon at Jamies customs. The owner of that place is bat-shit crazy.</p>
]]></description><link>https://wibimmers.com/post/8007</link><guid isPermaLink="true">https://wibimmers.com/post/8007</guid><dc:creator><![CDATA[rampelsauce]]></dc:creator><pubDate>Sat, 23 Jun 2012 13:32:13 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Sat, 23 Jun 2012 09:43:47 GMT]]></title><description><![CDATA[<p dir="auto">I need some paint work done, i jave a place all i need is an experience painter I am in Vernon on hwy 164</p>
]]></description><link>https://wibimmers.com/post/8004</link><guid isPermaLink="true">https://wibimmers.com/post/8004</guid><dc:creator><![CDATA[Ted]]></dc:creator><pubDate>Sat, 23 Jun 2012 09:43:47 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Sat, 23 Jun 2012 03:12:07 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>mystere30 said:</strong></p>
<p dir="auto">whaaa?? quillbro where are you/where is said shop/whats it called? i have a guy who will do body work and paint, just needs a place to do it. hes a certified body tech.</p>
]]></description><link>https://wibimmers.com/post/8002</link><guid isPermaLink="true">https://wibimmers.com/post/8002</guid><dc:creator><![CDATA[need4speed1299]]></dc:creator><pubDate>Sat, 23 Jun 2012 03:12:07 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Fri, 22 Jun 2012 14:21:31 GMT]]></title><description><![CDATA[<p dir="auto">Auto Paint Supply, 164 and Main St. in Waukesha I would assume?</p>
]]></description><link>https://wibimmers.com/post/7998</link><guid isPermaLink="true">https://wibimmers.com/post/7998</guid><dc:creator><![CDATA[wasnt m3]]></dc:creator><pubDate>Fri, 22 Jun 2012 14:21:31 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Fri, 22 Jun 2012 13:39:08 GMT]]></title><description><![CDATA[<p dir="auto">I'm in wales but have a shop in Dousman. The shop is in waukesha somewhere... i forget the name of it. I resprayed the hood on my Z3 about 10 years ago with thier products. They sell good stuff.</p>
<p dir="auto">As always its the prep time that takes forever. I have to take off the rear valence and the front left side skirt to do what I need to do. Never removed either so im gonna have to look into how this is done</p>
]]></description><link>https://wibimmers.com/post/7994</link><guid isPermaLink="true">https://wibimmers.com/post/7994</guid><dc:creator><![CDATA[quillbro]]></dc:creator><pubDate>Fri, 22 Jun 2012 13:39:08 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Fri, 22 Jun 2012 05:33:34 GMT]]></title><description><![CDATA[<p dir="auto">whaaa?? quillbro where are you/where is said shop/whats it called? i have a guy who will do body work and paint, just needs a place to do it. hes a certified body tech.</p>
]]></description><link>https://wibimmers.com/post/7992</link><guid isPermaLink="true">https://wibimmers.com/post/7992</guid><dc:creator><![CDATA[mystere30]]></dc:creator><pubDate>Fri, 22 Jun 2012 05:33:34 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone good at bodywork? on Fri, 22 Jun 2012 03:37:52 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><strong>keeperofchaos said:</strong></p>
<p dir="auto">Not sure... im looking for the same. But i think im gonna break down and DIY it. I have a compressor and a HVLP gun. I just need a portable sand blaster. There is a shop in my area that sells proffesional auto paint products. Im gonna hit them for primer/paint, sand paper and stuff.</p>
<p dir="auto">I have 3 areas that need some attention before things get really bad.</p>
]]></description><link>https://wibimmers.com/post/7988</link><guid isPermaLink="true">https://wibimmers.com/post/7988</guid><dc:creator><![CDATA[quillbro]]></dc:creator><pubDate>Fri, 22 Jun 2012 03:37:52 GMT</pubDate></item></channel></rss>
