Build Thread?
Crappy pic, but it gets the point across.
Struggling to figure out a coolant expansion tank, and may resort to just putting one back in the stock location and making some brackets for it.
I also decided to move the oil cooler and that has been providing an equal amount of headaches.In good news the everything else is taken care of, and the ECU seems to be working well and I feel confident that once I get the oil and coolant situation figured out it should fire up first go.
Got it running today, with minimal resistance.
Now to get the coolant expansion tank in place and do some driving! -
^ I had a late lunch with the family, so I don't think tonight will be that night!
In other news, I replaced all of the soft brake lines with braided stainless ones and also replaced all of the brake hardlines over the past year. Holy crap is the brake pedal awesome now!
I'm doing some non driving tuning right meow and hope to be able to give it another test drive soon!
New hardlines you say. Were the old ones rotted?
I needed to replace the soft lines in the rear at the caliper, and the nuts were gross so I figured I may as well replace them.
The ones above the rear subframe were gross and I did those when the subframe was out this winter.
I had done the front's when I deleted ABS. -
Typical summer build thread for me, never being updated.
I had my plugs gapped way too far and was blowing spark out at full boost, brought them down but may go a little further yet.
Tuning takes a lot of time and is tricky, getting annoyed by it. -
Burnout vids
Burnout vids
And now you understand why cars come with the smallest possible injectors from the factory instead of just sending everything out with 42#ers. Big injectors make tuning more cumbersome.
I am not 100% sure that everything is coming down to that, but I'm sure it doesn't help a ton.
just get it dyno tuned and done
Any localish places that you would suggest that will play with megasquirt?
I am pretty sure LMT does. @DrLeadFoot would know better than I would tho. I was planning on taking mine there when that time comes.
DB performance in MN, would would require you to come visit
Shane does most of the Megasquirt there as far as I know. Did Brooke's car. It was neat.
100% duty cycle or bust.
Switched to full sequential the other day and also changed the req_fuel to reflect the new information in regards to the injectors (they were rounded for lb/hr and also rated at 3 bar) and suddenly this thing is a different animal.
No burnout vids, but there has for sure been some tire spin.Oh, my starter solenoid did start acting up hard today. Had to have a friend hit it with a screwdriver while I held the key over. Grabbing a new one today to fix that. Luckily it didn't start when I was at a friends house instead of a gas station or somewhere random.
