  4. Calypsorot '90 325i Coupe
85 Posts 19 Posters 1.6k Views 1 Watching
  • MattYM
    MattYM
    MattY
    did you do the trans selector when you were in there? tough to do with it still on the car?
    we did just bushings and washers (garagistic delrin carrier shifter + rear) and that alone made a huge difference considering how sloppy it was. if we had more time it could've been done possibly but it took quite a bit to get it all in because the bushings were seriously rotted. lots of torching
    but the good news is i'll have all new hardware on my alpine since it's a manual swap, and chris sourced me a z3 shifter for that guy. (i REALLY should make a build thread for that soon)
      Couldn't remember if I did it or not when we swapped this motor/trans in but it didn't feel sloppy. I've done them in the car before, it isn't too bad.
      • MattYM
        MattYM
        MattY
        the calypso has risen. and promptly fallen back down
        we did this quick test drive last week after fixing a fuel leak (o ring in the fpr was forked), but i took the rear subframe apart to swap in the poly bushings i picked up last year. currently working on getting those swapped in.
        after that it should just be interior. it seems to be running pretty solid.
          So for a second there were 2 running/driving M20s in the state. Now its just Mr. Hundley again. Its nice to see progress on the Young BMW fleet nonetheless
          • MattYM
            MattYM
            MattY
            AFAIK my sedan is the only one in the Madison area. I believe there are two coupes downtown but they're relatively stock. I'm of the belief that the calypso should be kept as stock as possible visually, it wasn't meant for the works with is lips and skirts
            • MattYM
              MattYM
              MattY
              Didn't have time to update until now!
              The bushing swap finally happened, and we also ran brand new nickel brake lines while the subframe was dropped (we literally tried EVERY method, and ultimately ended up dropping the whole thing.)
              Also got the interior back together Friday night for the picnic. Carpet still needs a little cleaning, but I did do some carpet cleaning a while ago and it cleaned up real nice.
              The first test drive with everything back together ran great! We made it to Waukesha without a hitch.
              Next on the list is fixing the minor lower coolant hose leak, speedo sensor in the diff, odo gears, obc clock swap (current obc screen is smashed), and looking into the bumper. I have a brand new bumper in green/teal, just gotta see how it mounts up and then i'll look into getting it painted.
                Hey that old subframe bushing still kind of resembles a bushing. From hearing about the removal at the picnic I was expecting much more destruction. Wish mine would have come out with that much intact material to grab onto.
                Good to see the progress!
                  Look at you driving a running e30 on wibimmers.  That's a small club to be in!  Congrats!
                    Pat.
                    Eat crap
                      there were 5 wibimmers e30s on Saturday. That means we're batting over .500, which in baseball if freakin amazing. But baseball sucks, so, bad analogy. BUT STILL.
                      good job getting the car out there, Matt, and nice to finally meet you.
                      • MattYM
                        MattYM
                        MattY
                        thanks a ton guys! leaning on getting that bumper fixed asap, we gotta properly rep the calypso crowd.
