  4. Fancy Stancy 325is
Fancy Stancy 325is
pssshhhhhmy wife is goin
193 Posts 17 Posters 3.8k Views 1 Watching
    Nice! Have you done any work on your other e36 lately? Last i remember was a lot of rust repair.
    On a stock ecu, a manually set idle speed via TB stop screw will have the engine trying to fuel and time the engine as if its at partial load since it sees a TP and RPM above what it expects for the idle settings. So it is not applying the idle advance and fueling that will help it to have a stable idle
      Nope the other one is sitting waiting for me to get the barn shop ready.  Someday...
      I will check out the TPS and see what it is doing when the throttle is closed, it has probably been messed with because of how I found other things...
        Mine is having idle surges and other weird idle issues lately so I cannot wait to see what you come up with.
          Must have a nasty cam
            I wish..
            Well I had to run home at lunch to pick up 25 chicks from the post office (bring your best jokes), and I got the plates transferred from the old car so I drove it back to work.  Seems to run well, LSD works too.
              I wish..
              I had baby ducks shipped through the mail one time and a bunch of them died from the cold.  I have no jokes and your statement made perfect sense to me.
                Mb they adjusted the throttle cable so its further open at idle.
                  I did check that and it has enough slack to close all of the way.
                  I drove it to work again today, the only problem is some tire rub in the back when hitting a bump.  And that someone threw away the cruise control actuator!!!!!
                  Looking for some uncut lowering springs.  The Billies seem to still work, it isn't bouncy.
                    Glad it is treating you much better than assumed at the start=)
                      Got an actuator in my parts car.
                        Ok, let me see how much of my wiring harness is missing.  I know the plug isn't there either.  But it has the stalk inside.
                          TPS code 1216 today.  I will investigate that this weekend, hopefully that solves the funky throttle action.
                            I have a spare tps sensor if you need to test
                              400ish miles so far, it runs better the more I drive it.  Sitting for 5 years is no good for any engine.  After adjusting the throttle stop it idles properly and has no codes.  It was held open a little.
                              I replaced the rear springs with the Eibach ones from my other car, it raised about 3/4" but the ride is way better and doesn't rub except over big bumps which I can deal with.  The wheels are 17x8 et13.  That explains the rubbing.  The hub bore is also too large, I assume they were intended for an e39?  I also removed the stickers as it isn't stancy enough to have cool guy stickers.
                              I ordered a few parts now that I feel confident that it runs well.  RSM's, hardware for X-Brace, oil filter housing gasket, vanos oil line, cabin air filter, radiator clips, hood release cable, Spal 16" fan ( I can't stand the mechanical fan), and front control arm bushings (centered m style ones).
                              Next up will be some cooling system work to make sure everything is solid.
                              LSD works, I left 2 black streaks each time on 3 attempts.
                                A cylinder quit on me on the way to work.  I am guessing a coil is the problem.  It must have still been spraying fuel because the exhaust was stank and cat was super hot.  Hopefully I can figure it out at lunchtime.
                                  Annoying, but a small hiccup considering where the car was a couple months ago
                                    Good to go, the result of not having the beauty cover or any under panels below the bumper means a ton of water sprays everywhere while driving in the rain.  It fills up the spark plug wells and shorts out the spark.
                                    Soaked it up with paper towels and it is good to go!
                                      Were you driving through a fucking monsoon!?  I have never heard of that happening.  It almost seems to defy gravity lol.  Any pictures?
                                        I've had it happen on the compact in the past. It rolls off of the rain tray and onto the valve cover
                                          This ^ it was very little water, just enough to short out cylinder 5 or 6. Both of them had water around the plug. It ran good when I left the house and got worse the farther I went so I assume the water got in there from driving.
