  4. Build Thread?
Build Thread?
    You arent lying. Steering joint r&r and installing a clutch pedal for a manual swap are my most despised e30 jobs.
      Agree, steering joints suck. Is that from Condor?
        Progress is good😁 Going to make the E30 picnic?
          It is! I am curious to see how the steering will feel with the slop out of the upper U joint and the lack of rubber in the middle!
          @Earl I don't commit to anything that way when I don't show up it's no surprise!
          I would like to take one of my E30's, but we all know how that goes.
          • i_love_carsI
            i_love_carsI
            i_love_cars
            god damn I haven't had Rolling Rock since.....college. Fuck I feel old.
            E30 picnic or bust IMO
            2007 Z4MR
            2003 E39 M5
            2002 E46 M3
            2021 X5 40i
              E30 picnic or bust!!
                Busted E30 or picnic
                  Yay progress 😁
                    I could have sworn I followed through for checkout on ECS this Monday for a bunch of gaskets, but apparently I didn't.  So that's lame.
                    I remembered yesterday that I need to do silly head torquing processes for this head gasket setup, and don't look forward to bolting the turbo down after putting the motor in and I'm debating waiting on putting the motor in. We shall see how much ambition I have!
                    I wish I would have dropped the head off at the machine shop earlier so I could be doing the silly torque process this week instead of starting it Saturday!
                      Is it as silly as torquing it in a sequence and then having to wait a determined amount of time to do the next step?
                        Yep. It makes sense though, and I don't feel like risking another gasket combo to something that would be so stupid not to do.
                        At least this time I don't have to take the cams back out after the first heat cycle to torque the head bolts, the socket fits through m52 cam trays.
                          That's a plus lol. I believe you've done enough head gaskets for a lifetime. You and Snap could race to see if it is faster to do an M5X or an M20 headgasket haha
                            [emoji1366]
                            Im sick of head gaskets. Bring on the certified pre-owned Teslas
                              M20 for sure. You don't have to mess with vanos removal stuff.
                              Though the intake manifold removal is much easier.
                              @Snap A gentleman's duel ? Loser is forced to put the winners engine in their car. Some big stakes there.
                                I dont even want to change the head gasket on a lawnmower
                                  Grabbed the head on Friday and the guy that worked on it laughed at me for bringing it in because it was so flat already. Worth the money to know it's perfect and I didn't have to clean the old gasket off!
                                  IMG20170422092754946IMG20170422102440754IMG20170423123433776IMG20170423132938497
                                  Got it timed, which I always find it satisfying when you do the timing and rotate it a couple times and check it again and it's still spot on.
                                  Torquing the head still, and set some other things on it. Got the 85# injectors back in the rail and the manifold, and am waiting on some gaskets before I can bolt the turbo manifold back on.
                                  Slowly but surely going back together.
                                    85# injectors!!?!
                                    RIP smooth idle
                                      Glad the head wasn't a worry this time around=)
                                        85# injectors!!?!
                                        RIP smooth idle
                                        They are known to atomize better than stock injectors, so that's a thing? I was running them the last time the car ran and it was fine!
                                        It was 65 or 85, and 65 was a bit low if I decided to do other fuel sources, so 85er's it was!
                                          I haven't actually had head issues before, it was always block related stuff. But that was decked when I first put this engine together so we are good to go!
