  4. '88 E30
'88 E30
savebigmoney
  • SamHolzmannS
    SamHolzmannS
    SamHolzmann
    Maybe ill have to come to an auto x event sometime this year, on the downside to that is the car is built to do the exact opposite of auto x and i would probably end up getting kicked out.
      SamHolzmann said:
      car is built to do the exact opposite.
      I avoid drift events for the same reason
        Finally had some free time and dropped the head off today. He pulled vacuum on it while I was there. Intake and exhaust valves he said looked really good. So there's hope. Will be picking it up sometime next week
          Picked it up Friday b8c857c3ca4f253a4316d603c16e08a7.jpge0aa1fabaa7aee57530a6270108dc24c.jpg
            Its interesting the changes they made in the oil and coolant passages between the M20 and M5X/S5X cylinder heads.
            The number of oil feed passages is reduced, the size of the coolant passages is reduced (this doesnt mean less cooling, just look at the pinhole they put in a stock head gasket to meter the coolant flow) and all of the passages locate near a head bolt to maintain sealing when the head lifts ever so slightly. The oil returns also have more real estate around them (inherently from the head being much wider) which allows the gasket to be designed for reduced chance of external oil leaks.
            What im trying to say is, get it back together soon so we can break s'more axles
              Wow. A head.
              I've never seen one before. Thanks for posting this.
                Wow. A head.
                A somewhat douchey comment from Ben, this thread is full of firsts!
                  probably pent up aggression over the temp gun
                    Just lost it rofl
                      You never hang out with Ben, do you?
                        You never hang out with Mitch, do you?
                          Lol yea I have, he made this last night because I called him a lurker.
                            As much as I would enjoy continuing to stir this pot I'll add a touch of context to my comment.
                            Screenshot2017-03-27-10-43-39
                            Pent up temp gun aggression is real tho
                              I am a sarcastic douche most of the time
                              • SamHolzmannS
                                SamHolzmannS
                                SamHolzmann
                                I'm sure the shop did this but make you look over all of the valve retainers super good. From everything I have read s50's built prior to 10/95 have retainer problems. The only reason I know this is because when I blew my motor up there were a couple ready to give out and let the valve drop.
                                  Assuming you replaced with 96+ retainers?
                                    You and I would get along just fine.
                                      He says after bashing me for it 😉
                                        No bashing here, just correcting him 😄
                                          did some VIN decoder stuff.
                                          I have pre 10/95 build date.
                                          new retainers have been ordered.
                                          figure do it once and do it right so I dont have to worry about it
