  4. E30 Battery Cable Terminal
e30battery cable
19 Posts 6 Posters 261 Views 1 Watching
    Andrew said:
    Genius.  This would allow me to use the current cable like so?
    yup, exactly what i pictured.  be careful on those adapters, though, they may have a different post size which your cable wont clamp to.
    • AndrewA
      AndrewA
      Andrew
      I think i'll try this combo.  JIS post looks small and tapered, but they make shims to adapt to SAE post.
      • AndrewA
        AndrewA
        Andrew
        I have a scored m20 camshaft you can fall on.
        That is very kind of you.  That would be an epic death.
          looks like that should work!
            This thread confuses me. Why do you need to change the end on the stock battery cable?
            Or is it not stock.
              to me, it looks like someone in the past modified the end of the original cable, either because it was damaged/corroded or they used the wrong type of battery.
                Is this the picture of what is actually on your car?
                If so I hate previous owners of that vehicle
                • AndrewA
                  AndrewA
                  Andrew
                  Or is it not stock.
                  Yes, the end on the cable is NOT stock, which is the source of all my issues.
                  Using the SAE to JIS adapter, i'm able to make a stock size battery fit.  I couldn't orient the adapter the way i wanted, but this orientation doesn't put the cable under much strain.  And now it's held down with the OEM clamp.  It's better now.  Hopefully good enough for a tech inspector.
                    Stuff a 20 under the cable pre-inspection and you will be fine
                      If just a tech inspection for autox or a track day as long as the battery doesn't move with the stock clamp setup when the inspector checks it you'll be fine. I ran mine the same way for years.
                        I've been to a few auto crosses were they didn't even open my trunk...
                          if you aren't completely happy, those post extenders i original shared are like $5 at advanced auto parts, saw them when I stopped in the other day.
