  4. Lifted E30 V2
Lifted E30 V2
    Hey guys.
    Guess what I bought.
      Hey Ben. I have a temp gun you can borrow
        Singing Elsa doll from Frozen
          Hey guys.
          Another E30?
            The problem is that I wouldn't be all that surprised if that were the case.
            Nope, that's not what it was.
            It was a pink bunny, just couldn't resist.
              Pulled the thermostat to sanity check and it wouldn't get to temp.
              Put thermostat back in and it was running past 190 degrees after awhile, so it's certainly overheating. Not that this was news to me.
              Going to try a new expansion tank cap as it's the only thing that hasn't been replaced, and if that doesn't do the trick I'll probably just end up swapping motors.
              I did forget how much fun it was to drive.
                Still got a eta with your name on it!
                  ^this
                  I am tossing in the white flag on this engine. I have now replaced about everything and can only assume that when it froze something cracked and is not allowing the cooling system to function properly.
                  Next update will be the motor being changed again.
                    Run a bottle of head gasket/cooling system stop leak for science:P
                      oh, that sucks!
                        Well you might as well at least make the old motor go BANG first..... (please take videos of attempts for science)
                          2017-03-1310-11-38
                          Pulled the motor with the help of the guy that pulled it with me last time lol.
                          I took the stock single mass flywheel off and set it on the bench, I then went and grabbed my m52's flywheel with clutch and pressure plate on it.
                          The stock single mass (228mm) flywheel weighs more than my aluminum (240mm) flywheel WITH the pressure plate and clutch disc. Found that funny as the weight difference is quite noticeable.
                          Motor didn't end up making it here this weekend so it looks like it will be a next weekend project!
                            Switched motors this weekend, and it runs but misses. Going to put in the injectors from the other motor and see if that's the issue as I already transferred the coil, cap, rotor, plug wires, and plugs.
                              That motor has been out for around4 years now, I do have video of when it last ran. Timing belt/water pump is "new" with no miles on it because I fried the dme shortly after and then decided to part the car and shell swap. It has around 168k on it and hadn't really been touched during the 3 years it was driven before part out.
                                I can't quite tell if this was informative or slightly defensive lol.
                                I have no concerns with the motor, as it runs well even though its consistently missing. I'm sure it's something simple otherwise it would sound a lot worse!
                                I look forward to trying to get the fuel rail out with the injectors, as it's quite the snug space!
                                  Did you check the cylinders with a temp gun?
                                    Informative! Sorry haha
                                      You shut your mouth about the temp gun.
                                      Yeah I totally did. It was cyl 2 and 6
                                        Switched injectors out last night and it runs quite a bit better. Not perfect, but better.
                                        I also put the cooling system back together on it.
                                        My plan? Connect the clutch hydraulics (so little space!) and go beat on it and see how it goes.
                                          Man this car is annoying.
                                          Can't drive it because it won't accelerate 90% of the time, just "stalls" and holds speed or slightly decelerates when you are on the gas. Occasionally it will pick up and accelerate for a second.
                                          AFM? I'm running out of thoughts here.
