    And so it begins ...
      Pls document this really well, I have to do this soon (rebuilding them)
        don't let the CVs fall apart under any circumstances. once the balls fall out, you'll never get it to work again (unless i'm just unlucky and/or stupid) I have one that's so froze up I can clamp the CV in the vise and hang off the axle and it doesn't budge. e21 CVs are NLA. I managed to find an NOS one for a reasonable price on flea-bay, but it took some digging...
          387c636cbd89515be4893227842a78dc202710fa
            Time to sell your house!
            http://sfbay.craigslist.org/sfc/pts/5991911567.html
              *DROOL*
                Still slowly moving along with the half shafts, but figured I'd do some more body work. Got the old rear valance cut off and the euro one welded on. I also welded up 2 holes I had to cut rust out, but didn't get pics of those. Next step is grinding/smoothing out the welds, skim coat of body filler and lots of sanding. I will be removing the side marker lights and welding up those holes too.
                  Just ordered 4 cv boot/end kits from wallothnesch in the motherland.
                    In progress
                      CV boot replacement kits from W&N came in from Germany
                        you building your own half shafts?
                          I guess you could say that. Since the shop in Waukesha (that I was referred to by multiple people) wouldn't shorten my halfshafts, I took it upon myself to get it done. They need shortening because I am running a medium case diff in a custom subframe I had made. So, my dad and I have been doing it periodically after hours and on weekends at his work shop. Just can't have the bosses seeing is all. I figure since I'm getting all that done, might as well clean out the CV joints and put new flanges/boots/grease in them. W&N was the only place that had a complete boot kit for the e21. Others just had the boot and clamps and would of had to buy the grease and such separate for practically the same price.
                            How are you going to balance them?
                              I hear Ray has a dynamic balancer at his work I will ask him about. Otherwise I will just take them to a driveshaft shop and have them statically balanced. The way we are making them, the fitment tolerances are almost 0, so they shouldn't be too far from already being balanced. The only factor that could potentially throw the balance off is how the welding comes out.
                                Also the speed of the axle rotation is significantly less than the driveshaft.  I don't think you would have any problem just running them.  I might be wrong but wouldn't the forces rise at an exponential rate to the rotating speed?  So if the rotation is 1/3rd to 1/4th the speed of the driveshaft depending on dif ratio the out of balance would have to be very bad to cause a vibration like an unbalanced driveshaft?  Or you would have to be going 200+ mph.
                                  150mph is going to be ~2000rpm axle speed
                                    dave - i once took my first e30 to this truck frame and axle place when my rear frame collapsed at the spring perches. they did a good job, but the thing that stood out is they didn't care what kind of car it was they were willing to just get it done. maybe worth a call for the axle building/balancing?
                                    Frame & Axle Services Co, 4220 N 126th St, Brookfield, WI 53005, (262) 783-4802
                                      Frame & Axle Services Co was the first place I went to see if they would shorten the axles for me. They don't do that kind of work and referred me to Machine Service in Waukesha/Pewaukee that I mentioned earlier. Them and a couple other people referred me to Machine Service as well, but they didn't want to take that project on either. This is why I am now doing it myself. If Ray is unable to dynamically balance them at his work, I was going to go back to Frame & Axle t osee if they can static balance them.
                                      A few people that had the idea of shortening their own halfshafts or have actually done it said they weren't even gonna bother balancing them anyways. This is more of a peace of mind thing for me it seems.
                                        So, I did a thing after a few guys here mentioned to try it.
                                        Tried out some lamin-x on my taillight lenses since new ones are crazy expensive if you can even find them. Turned out decent. Didn't hide the cracks and blemishes as well as I hoped, but still better than nothing. Debated on leaving the reverse light lense white or not (not like they work anyways). What do ya'll think?
                                          looks great! i think it hides the cracks pretty well, at least in that photo
