    Haha! This is awesome
      andyhundley said:
      Mitch you should probably put that gallon of strawberry milk in the fridge before it goes bad.
      Yes! Don't want another pb&j incident to happen again.
        Started messing with the rear euro valance install this weekend. Using my brothers awesome snap-on body hammers and dollies I got some areas smoothed out on it. I think it will be easier once it's welded on the car. I went to sand down the edge of the car to bare metal for welding and ran into another Fat Bob curse.
        DAMN YOU FAT BOB!!!!
        Looks like he just chipped away some rust and bondo'd the hole shut. [emoji35] So I got in there and ground away all the bondo and proceeded to weld up the hole like it should of been in first place. Picture looks worse than in person. I basically built up weld beads and ground it flat to form the edge again for the valance to be welded to.
        Progress pic
        Then just for fun I tacked the valance on for how it may look. I need to take it off and get that edge flatter to fit against the car a lot better. Then from there I'll need to figure out the side pieces and it should be good to go.
        • JeffJ
          JeffJ
          Jeff
          I need to know, who is fat bob?
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            The horrible previous owner of this car. Dumb high school kid who lost his license, so he decided to do terrible work to the car I have been discovering since day one of owning it.
              Image result for damn it bobby
                  When it comes to heating the workshed and garage in winter .... ^^^that is definitely me!
                  • JeffJ
                    JeffJ
                    Jeff
                    Propane
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      And propane accessories
                          Been sick all weekend, so couldnt do much outside. I ended up working more on the rear end and figuring out the axle lengths. Turns out, the distance from diff flange to hub flange is different on both ends. Only by 3/8" tho. One side I got 38mm shorter than stock and the other I got 28.5mm shorter than stock. At this point, I'm just gonna split the difference and get 2 axles the same length. Figure it's better to have 3/16" difference on both ends than 3/8" difference only on one end. Gonna be contacting Machine Service in Pewaukee this week for a quote on shortening my axles.
                            I like the jig you made to size up the axles 😄
                              And so it begins ...
                                Pls document this really well, I have to do this soon (rebuilding them)
                                  don't let the CVs fall apart under any circumstances. once the balls fall out, you'll never get it to work again (unless i'm just unlucky and/or stupid) I have one that's so froze up I can clamp the CV in the vise and hang off the axle and it doesn't budge. e21 CVs are NLA. I managed to find an NOS one for a reasonable price on flea-bay, but it took some digging...
                                    387c636cbd89515be4893227842a78dc202710fa
                                      Time to sell your house!
                                      http://sfbay.craigslist.org/sfc/pts/5991911567.html
                                        *DROOL*
                                          Still slowly moving along with the half shafts, but figured I'd do some more body work. Got the old rear valance cut off and the euro one welded on. I also welded up 2 holes I had to cut rust out, but didn't get pics of those. Next step is grinding/smoothing out the welds, skim coat of body filler and lots of sanding. I will be removing the side marker lights and welding up those holes too.
